Shortly after landing on the desktop and after the initial updates I launched Opera and adjusted it's volume to 60%, but after a second or two it's jumped back to 100%. I thought it might be something to do with JamesDPS cause Operas icon under had a lock on it that I've never seen before, so I uninstalled JamesDPS, logged out, ran Opera upon login and the lock on Opera's icon is now gone when I click the volume control app in the systray. However that did not fix Opera's sound jumping back to 100%. I just tested with Vivaldi and the sound is doing the exact same as with Opera. I have not had this issue with any other OS so I have to figure it is a Garuda issue. Any suggestions? Thanks
╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 5.17.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=4006dde4-6bac-4717-80cf-77ccd2da5135 rw [email protected]
Desktop: KDE Plasma v: 5.24.4 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B450-F GAMING v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 4204
date: 01/28/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M325
Device-2: hidpp_battery_1 model: Logitech Wireless Keyboard K360
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3604 high: 3885 min/max: 2200/4208 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3599 2: 3590
3: 3598 4: 3612 5: 3431 6: 3369 7: 3597 8: 3594 9: 3597 10: 3885 11: 3824
12: 3560 bogomips: 86400
mitigation: Retpolines, IBPB: conditional, STIBP: conditional, RSB filling
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: eVga.com.
driver: nvidia v: 510.60.02 alternate: nouveau,nvidia_drm pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 08:00.0 chip-ID: 10de:2187 class-ID: 0300
Screen-1: 0 s-res: 2560x1080 s-dpi: 97 s-size: 670x283mm (26.38x11.14")
s-diag: 727mm (28.63")
Monitor-1: HDMI-0 res: 2560x1080 hz: 60 dpi: 97
size: 673x284mm (26.5x11.18") diag: 730mm (28.76") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650 SUPER/PCIe/SSE2
v: 4.6.0 NVIDIA 510.60.02 direct render: Yes
Device-1: NVIDIA TU116 High Definition Audio vendor: eVga.com.
link-max: lanes: 16 bus-ID: 08:00.1 chip-ID: 10de:1aeb class-ID: 0403
bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound Server-1: ALSA v: k5.17.4-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.50 running: yes
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
Local Storage: total: 20.7 TiB used: 11.54 TiB (55.8%)
model: WD Blue SN570 500GB size: 465.76 GiB block-size: physical: 512 B
rev: 234100WD temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: MZNTY128HDHP-000L1
type: SSD serial: <filter> rev: 3L0Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate
model: Expansion HDD size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 1801 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
model: ST330006 51NS size: 2.73 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: 7101 scheme: GPT
ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Seagate
model: ST8000AS0002-1NA17Z size: 7.28 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5980 serial: <filter> scheme: GPT
ID-6: /dev/sde maj-min: 8:64 type: USB vendor: PNY model: USB 3.0 FD
size: 115.38 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: PMAP scheme: MBR
ID-7: /dev/sdf maj-min: 8:80 type: USB vendor: Seagate
model: ST3000DM 001-1E6166 size: 2.73 TiB block-size: physical: 4096 B
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 20.7 GiB (17.4%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 23.45 GiB used: 2.2 MiB (0.0%)
System Temperatures: cpu: 42.0 C mobo: 32.0 C gpu: nvidia temp: 40 C
Fan Speeds (RPM): cpu: 1300 case-1: 0 case-2: 0 case-3: 0 gpu: nvidia
fan: 0%
Power: 12v: 9.97 5v: N/A 3.3v: N/A vbat: 3.18
Processes: 392 Uptime: 17m wakeups: 9 Memory: 23.45 GiB
used: 4.44 GiB (19.0%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1931 lib: 549 flatpak: 0 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.15
Garuda (2.6.2-1):
System install date: 2022-04-27
Last full system update: 2022-04-27
