Browse network
I use Tunar to browse files including network shares. Noticed that Network → Browse Network window is empty. Need help restoring capability to browse network without domain controller.
  Kernel: 6.9.1-2-cachyos arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=b8c044ba-3855-4296-80c1-38218b0791fd rw rootflags=subvol=@
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
  Type: Desktop Mobo: Compulab model: fitlet2 v: 1.31 serial: <filter>
    uuid: 3d7d3c80-921c-11ec-8c75-fb3e412e0700 UEFI: American Megatrends
    v: FLT2.TPM.0.46.02.01 date: 05/24/2021
  Info: model: Intel Atom E3950 bits: 64 type: MCP arch: Goldmont level: v2
    built: 2016 process: Intel 14nm family: 6 model-id: 0x5C (92) stepping: 9
    microcode: 0x48
  Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 224 KiB
    desc: d-4x24 KiB; i-4x32 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 1938 high: 2000 min/max: 800/2000 base/boost: 1600/2400
    scaling: driver: intel_cpufreq governor: performance volts: 1.2 V
    ext-clock: 100 MHz cores: 1: 2000 2: 1843 3: 2000 4: 1910 bogomips: 12748
  Device-1: Intel Apollo Lake [HD Graphics 505] driver: i915 v: kernel
    arch: Gen-9 process: Intel 14n built: 2015-16 ports:
    active: HDMI-A-1,HDMI-A-2 empty: DP-1 bus-ID: 00:02.0 chip-ID: 8086:5a84
  Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 3840x1092 s-dpi: 96 s-size: 1016x289mm (40.00x11.38")
    s-diag: 1056mm (41.59")
  Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: top-right model: HP 25es
    serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 88 gamma: 1.2
    size: 553x309mm (21.77x12.17") diag: 633mm (24.9") ratio: 16:9 modes:
  Monitor-2: HDMI-A-2 mapped: HDMI-2 pos: primary,bottom-l model: HP 25es
    serial: <filter> built: 2017 res: 1920x1080 hz: 60 dpi: 88 gamma: 1.2
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.7-arch1.3
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 505 (APL 3)
    device-ID: 8086:5a84 memory: 7.23 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
    HD Graphics 505 (APL 3) driver: mesa intel v: 24.0.7-arch1.3
    device-ID: 8086:5a84 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
    (LLVM 17.0.6 128 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
  Device-1: Intel Celeron N3350/Pentium N4200/Atom E3900 Series Audio Cluster
    driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
    snd_sof_pci_intel_apl bus-ID: 00:0e.0 chip-ID: 8086:5a98 class-ID: 0403
  API: ALSA v: k6.9.1-2-cachyos status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.6 status: n/a (root, process) with:
  Device-1: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 01:00.0 chip-ID: 8086:1539
  Device-2: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 02:00.0 chip-ID: 8086:1539
  Device-3: Intel I211 Gigabit Network driver: igb v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: c000 bus-ID: 03:00.0 chip-ID: 8086:1539
  IF-ID-1: eno1 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 119.24 GiB used: 45.93 GiB (38.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: BIWIN model: SSD size: 119.24 GiB
    serial: <filter> fw-rev: 2A scheme: GPT
  ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
    used: 45.93 GiB (38.6%) fs: btrfs block-size: 4096 B dev: /dev/sda2
    maj-min: 8:2
    used: 584 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
    maj-min: 8:2
  ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
    maj-min: 8:2
  ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
    maj-min: 8:2
  ID-1: swap-1 type: zram size: 7.4 GiB used: 6.5 MiB (0.1%) priority: 100
  System Temperatures: cpu: 45.0 C mobo: N/A
  Memory: total: 8 GiB available: 7.4 GiB used: 2.57 GiB (34.7%) igpu: 256 MiB
  Processes: 268 Power: uptime: 15h 51m states: freeze,mem,disk
    suspend: s2idle wakeups: 0 hibernate: shutdown
    avail: reboot,suspend,test_resume image: 2.94 GiB
    services: upowerd,xfce4-power-manager Init: systemd v: 255
  Packages: pm: pacman pkgs: 1545 libs: 453 tools: pacseek,pamac,paru
    Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi (sudo) default: Bash
    v: 5.2.26 running-in: xfce4-terminal inxi: 3.3.34
  System install date:     2024-05-20
  Last full system update: 2024-05-21
  Failed units:            samba.service
This is probably the cause.
Check the status, logs, etc.
Read also
https://wiki.archlinux.org/title/Samba
