first of all, i made a post yesterday thinking i resolved this but the issue remains. my wifi will randomly drop and require me too restart the service or reconnect too my wifi. i've attempted too disable the random mac address but the config file i made did not seem to do anything.
i placed it at /etc/NetworkManager/conf.d/wifi_rand_mac.conf with the following inside>> [device]
wifi.scan-rand-mac-address=no
and restarted my networkmanger several times, and after a few reboots i still have the aforementioned issue. I'm stumped on what to do next.. any tips or help would be much appreciated
here is my inxi
Kernel: 5.19.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=3b256a22-dfc4-4368-b2cd-a07dceb3840a rw rootflags=subvol=@
splash amd_iommu_on rd.udev.log_priority=3 vt.global_cursor_default=0
loglevel=3 vfio-pci.ids= 10de:1b80,10de:10f0
Desktop: sway v: 1.7 info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5220
date: 09/12/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Gaming Mouse
Info: model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen level: v3
built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1 stepping: 1
microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3811 high: 3850 min/max: 2200/3850 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3850 2: 3850
3: 3850 4: 3850 5: 3850 6: 3850 7: 3235 8: 3850 9: 3850 10: 3850 11: 3850
12: 3850 13: 3850 14: 3850 15: 3850 16: 3850 bogomips: 122963
Device-1: NVIDIA GP104 [GeForce GTX 1080] driver: nouveau v: kernel
non-free: 515.xx+ status: current (as of 2022-08) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s ports: active: DP-3,DVI-D-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0a:00.0 chip-ID: 10de:1b80
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: sway v: 1.7 driver: gpu: nouveau d-rect: 5360x2520
display-ID: 1
Monitor-1: DP-3 pos: primary,top-left model: Acer Z35P serial: <filter>
built: 2017 res: 3440x1440 hz: 60 dpi: 107 gamma: 1.2 scale: 1
size: 819x346mm (32.24x13.62") diag: 889mm (35") modes: max: 3440x1440
min: 640x480
Monitor-2: DVI-D-1 pos: bottom-r model: ViewSonic VA2246 SERIES
serial: <filter> built: 2014 res: 1920x1080 hz: 60 dpi: 102 gamma: 1.2
scale: 1 size: 477x268mm (18.78x10.55") diag: 547mm (21.5") ratio: 16:9
Message: Wayland GBM/EGL data currently not available.
Device-1: NVIDIA GP104 High Definition Audio driver: snd_hda_intel
v: kernel pcie: bus-ID: 3-1.3:9 gen: 1 chip-ID: 0d8c:0005 class-ID: 0300
speed: 2.5 GT/s lanes: 16 serial: <filter> link-max: gen: 3 speed: 8 GT/s
bus-ID: 0a:00.1 chip-ID: 10de:10f0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
Device-3: C-Media Blue Snowball type: USB
Sound Server-1: ALSA v: k5.19.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.58 running: yes
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter
vendor: ASUSTeK driver: wl v: kernel modules: bcma pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14e4:43a0
IF: wlp6s0 state: up mac: <filter>
Device-2: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 08:00.0
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 3-1.2:8 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Local Storage: total: 3.64 TiB used: 489.39 GiB (13.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000LX001-1RG174
type: HDD rpm: 5400 serial: <filter> rev: SDM1 scheme: GPT
ID-1: / raw-size: 914.11 GiB size: 914.11 GiB (100.00%) used: 201.21 GiB
(22.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 27.2 MiB
(9.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 914.11 GiB size: 914.11 GiB (100.00%) used: 201.21
GiB (22.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/log raw-size: 914.11 GiB size: 914.11 GiB (100.00%) used: 201.21
ID-5: /var/tmp raw-size: 914.11 GiB size: 914.11 GiB (100.00%) used: 201.21
ID-1: swap-1 type: zram size: 15.55 GiB used: 80 MiB (0.5%) priority: 100
ID-2: swap-2 type: partition size: 17.11 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 26.5 C mobo: N/A gpu: nouveau temp: 34.0 C
Fan Speeds (RPM): N/A gpu: nouveau fan: 1356
Processes: 342 Uptime: 9h 53m wakeups: 12 Memory: 15.55 GiB used: 2.68 GiB
(17.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1396 libs: 401
tools: pamac,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: alacritty inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-09-22
Last full system update: 2022-09-25
