I am having an issue that seems to happen from time to time to some people, but none of the solutions I have found seem to work.
My wifi is not working.
I was able to connect in the live install environment.
I was able to connect on first boot.
I rebooted without doing anything other than veryfing wifi worked.
Wifi still worked after first reboot.
I then used the garuda assistant to perform a system upgrade, the first step it does. I did not install any of the additional optional software. The upgrade completed with no errors. I then rebooted.
Now wifi does not work and the applet gets stuck at “configuring interface”
Based on searches, I tried the following commands:
[đź”´] Ă— sudo nmcli dev wifi con "Turtle Reef"
Error: Connection activation failed: Secrets were required, but not provided.
I imagine this does not work since by default the password was stored in kwallet, since I initially entered it in plasma as the non-root user.
However, passing the password into the nmcli
command, either with the password
flag or the --ask
switch yields the same result.
â•─igor@kinch in ~ took 561ms
[đź”´] Ă— sudo nmcli dev wifi con "<my-wifi-ssid>" password "<my-wifi-password>"
â•─igor@kinch in ~ took 563ms
[đź”´] Ă— sudo nmcli dev wifi con "<my-wifi-ssid>" --ask
Password: •••••••••••
I have also tried the same commands after
â•─igor@kinch in ~ as đź§™ took 620ms
╰─λ sudo nmcli radio wifi off && sudo nmcli radio wifi on
I then deleted the connection using
nmcli connections # to show connections
nmcli connections delete "<my-wifi-ssid>"
nmcli connections # to confirm deletion
Then I tried connecting again with the same nmcli commands as above with the same resulting error. However, this time it took about 15 seconds for the error to pop up. It was instant before.
I am guessing something got messed up with upgrading from plasma 6.0 to plasma 6.1 and related gear/framework updates that caused kwallet to be confused, but this should not affect trying to connect as root using nmcli
, should it?
I really appreciate any help with this!
Per instructions, posting output of garuda-inxi
â•─igor@kinch in ~ as đź§™ took 623ms
╰─λ garuda-inxi
Kernel: 6.10.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=9e7b3c99-bfc8-48fb-be11-1652976c102a rw rootflags=subvol=@
quiet rd.luks.uuid=9c4b8945-6efe-4294-a025-da52b90526bc
rd.luks.uuid=80cff95d-12de-458c-9f44-2728de874b29
resume=/dev/mapper/luks-80cff95d-12de-458c-9f44-2728de874b29 loglevel=3
Console: pty pts/1 DM: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: Apple product: MacBookPro11,5 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-06F11F11946D27C5
Mobo: Apple model: Mac-06F11F11946D27C5 v: MacBookPro11,5
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 430.140.3.0.0 date: 04/18/2022
ID-1: BAT0 charge: 101.1 Wh (100.0%) condition: 101.1/99.4 Wh (101.7%)
volts: 12.6 min: 11.3 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 7
Info: model: Intel Core i7-4870HQ bits: 64 type: MT MCP arch: Haswell
family: 6 model-id: 0x46 (70) stepping: 1 microcode: 0x1C
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3700 min/max: 800/3700 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3700 2: 3700 3: 3700 4: 3700 5: 3700
6: 3700 7: 3700 8: 3700 bogomips: 39911
Device-1: Advanced Micro Devices [AMD/ATI] Venus XT [Radeon HD 8870M / R9
M270X/M370X] vendor: Apple driver: radeon v: kernel alternate: amdgpu
arch: GCN-1 code: Southern Islands process: TSMC 28nm built: 2011-20
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
chip-ID: 1002:6821 class-ID: 0300 temp: 59.0 C
Display: unspecified server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
compositor: kwin_wayland driver: X: loaded: radeon unloaded: modesetting
alternate: fbdev,vesa dri: radeonsi gpu: radeon tty: 78x16
Monitor-1: eDP-1 model: Apple Color LCD built: 2015 res: 2880x1800
dpi: 221 gamma: 1.2 size: 331x207mm (13.03x8.15") diag: 390mm (15.4")
ratio: 16:10 modes: 2880x1800
wayland: drv: radeonsi inactive: x11
API: OpenGL v: 4.5 vendor: mesa v: 24.2.3-arch1.1
note: console (EGL sourced) renderer: llvmpipe (LLVM 18.1.8 256 bits),
VERDE (radeonsi LLVM 18.1.8 DRM 2.50 6.10.10-zen1-1-zen)
API: Vulkan v: 1.3.295 layers: 9 device: 0 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.3-arch1.1 (LLVM
18.1.8) device-ID: 10005:0000 surfaces: wayland
Device-1: Intel 8 Series/C220 Series High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
Device-2: Advanced Micro Devices [AMD/ATI] Oland/Hainan/Cape
Verde/Pitcairn HDMI Audio [Radeon HD 7000 Series] vendor: Apple
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aab0 class-ID: 0403
Device-3: Broadcom 720p FaceTime HD Camera driver: N/A pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 14e4:1570 class-ID: 0480
API: ALSA v: k6.10.10-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.4 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 04:00.0 chip-ID: 14e4:43ba class-ID: 0280
Device-2: ASIX AX88179 Gigabit Ethernet driver: ax88179_178a type: USB
rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.1:7
chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp0s20u1u1 state: up speed: 1000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
Device-1: Apple Bluetooth Host Controller driver: btusb,hid-generic,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:4
chip-ID: 05ac:8290 class-ID: fe01
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.2
Local Storage: total: 465.92 GiB used: 20.45 GiB (4.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0512G
size: 465.92 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 3A0Q scheme: GPT
ID-1: / raw-size: 448.57 GiB size: 448.57 GiB (100.00%)
used: 20.45 GiB (4.6%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-9c4b8945-6efe-4294-a025-da52b90526bc
used: 728 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 448.57 GiB size: 448.57 GiB (100.00%)
ID-4: /var/log raw-size: 448.57 GiB size: 448.57 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.57 GiB size: 448.57 GiB (100.00%)
zswap: no
ID-1: swap-1 type: partition size: 17.05 GiB used: 0 KiB (0.0%)
mapped: luks-80cff95d-12de-458c-9f44-2728de874b29
ID-2: swap-2 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C pch: 61.5 C mobo: N/A gpu: radeon
temp: 60.0 C
Memory: total: 16 GiB available: 15.5 GiB used: 3.23 GiB (20.9%)
Processes: 373 Power: uptime: 29m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1797 libs: 538 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: Bash v: 5.2.32
running-in: pty pts/1 (SSH) inxi: 3.3.36
System install date: 2024-09-25
Last full system update: 2024-09-25
