Bluetooth devices wont show up when scanned for.
It does work in Windows, But didn't work in Garuda Linux Gnome and Garuda Linux Kde Dr460nized
System Details
System: Kernel: 5.11.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=1c66e6c9-d4c5-4043-a709-e6ee2d6bd028 rw
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: Sony product: SVF1531GSAB v: C10J5E30 serial: Chassis: type: 10 serial:
Mobo: Sony model: VAIO serial: UEFI-[Legacy]: Insyde v: R1100DB date: 01/26/2016
CPU: Info: Dual Core model: Intel Core i7-4500U bits: 64 type: MT MCP arch: Haswell family: 6 model-id: 45 (69)
stepping: 1 microcode: 26 cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 19155
Speed: 2199 MHz min/max: 800/3000 MHz Core speeds (MHz): 1: 2199 2: 1803 3: 1818 4: 1834
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: Sony driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0a16 class-ID: 0300
Device-2: NVIDIA GK208M [GeForce GT 740M] vendor: Sony driver: nouveau v: kernel bus-ID: 04:00.0 chip-ID: 10de:1292
class-ID: 0302
Device-3: Chicony Front Camera type: USB driver: uvcvideo bus-ID: 2-5:4 chip-ID: 04f2:b3aa class-ID: 0e02
serial:
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel,nouveau unloaded: modesetting
alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 21.0.1 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio vendor: Sony driver: snd_hda_intel v: kernel bus-ID: 00:03.0
chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Sony driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20
Sound Server-1: ALSA v: k5.11.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.24 running: no
Network: Device-1: Broadcom BCM43142 802.11b/g/n vendor: Foxconn driver: wl v: kernel port: 5040 bus-ID: 02:00.0
chip-ID: 14e4:4365 class-ID: 0280
IF: wlp2s0 state: up mac:
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Sony driver: r8169 v: kernel port: 4000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac:
Bluetooth: Device-1: Foxconn / Hon Hai BCM43142A0 type: USB driver: btusb v: 0.8 bus-ID: 2-4:3 chip-ID: 0489:e062
class-ID: fe01 serial:
Report: ID: hci0 state: up address:
Drives: Local Storage: total: 465.76 GiB used: 22.61 GiB (4.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500325ASG size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: rev: APM1 scheme: MBR
Partition: ID-1: / raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 22.61 GiB (4.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-2: /home raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 22.61 GiB (4.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-3: /var/log raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 22.61 GiB (4.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-4: /var/tmp raw-size: 465.76 GiB size: 465.76 GiB (100.00%) used: 22.61 GiB (4.9%) fs: btrfs dev: /dev/sda1
maj-min: 8:1
ID-1: swap-1 type: zram size: 2.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 2.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 2.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 2.9 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 46.0 C mobo: N/A gpu: nouveau temp: 43.0 C
Info: Processes: 205 Uptime: 38m wakeups: 1 Memory: 11.59 GiB used: 2.57 GiB (22.2%) Init: systemd v: 248 tool: systemctl
Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1427 lib: 359 Shell: fish v: 3.2.1 running-in: konsole
inxi: 3.3.03
Output from 'bluetoothctl'
Agent registered
[bluetooth]# show
Controller 0C:84:DC:FD:05:EA (public)
Alias: Hakai
Class: 0x003c010c
Powered: yes
Discoverable: no
DiscoverableTimeout: 0x000000b4
Pairable: yes
UUID: Message Notification Se.. (00001133-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: OBEX Object Push (00001105-0000-1000-8000-00805f9b34fb)
UUID: Message Access Server (00001132-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: IrMC Sync (00001104-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (00005005-0000-1000-8000-0002ee000001)
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
UUID: Headset AG (00001112-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Phonebook Access Server (0000112f-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: Device Information (0000180a-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: OBEX File Transfer (00001106-0000-1000-8000-00805f9b34fb)
Modalias: usb:v1D6Bp0246d0538
Discovering: no
Roles: central
Roles: peripheral
Advertising Features:
ActiveInstances: 0x00 (0)
SupportedInstances: 0x05 (5)
SupportedIncludes: tx-power
SupportedIncludes: appearance
SupportedIncludes: local-name
[ bluetooth]# list
Controller 0C:84:DC:FD:05:EA Hakai [default]
