Hi,
I am creating a network bridge for VM’s. I have created the bridge successfully using this Network bridge - ArchWiki . VM’s are able to connect to the web. However, the issue I have is that in the Network Manager GUI, the network bridge is created but not the slave. So if I disconnect the bridge if not using VM’s and reconnect, it won’t as it is waiting for the slave to be up. I would have liked it to connect using GUI.
Appreciate the help.
Kernel: 6.6.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=a5618af4-0e9c-45f2-be03-fd616f18681a rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: 5.15.11 wm: kwin_x11 vt: 2
Type: Laptop System: LENOVO product: 20YQ004JUS v: ThinkPad P15 Gen 2i
Mobo: LENOVO model: 20YQ004JUS v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N37ET49W (1.30 )
date: 11/15/2023
ID-1: BAT0 charge: 118.0 Wh (97.4%) condition: 121.2/94.0 Wh (128.9%)
volts: 12.4 min: 11.6 model: LGC 5B10W13958 type: Li-poly serial: <filter>
status: full cycles: 66
Info: model: 11th Gen Intel Core i7-11800H bits: 64 type: MT MCP
microcode: 0x4E
L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 865 high: 1100 min/max: 800/4600 scaling:
driver: intel_pstate governor: powersave cores: 1: 913 2: 800 3: 800 4: 927
5: 800 6: 1100 7: 800 8: 800 9: 861 10: 800 11: 800 12: 800 13: 946
14: 1100 15: 800 16: 800 bogomips: 73728
Device-1: NVIDIA TU117GLM [T1200 Laptop GPU] vendor: Lenovo driver: nvidia
(as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 4 speed: 16 GT/s
lanes: 8 link-max: lanes: 16 ports: active: none off: DP-4,DP-5,eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:1fbc
Device-2: Luxvisions Innotech Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3 chip-ID: 30c9:0014
Display: x11 server: X.Org v: 21.1.10 with: Xwayland v: 23.2.3
alternate: fbdev,nv,vesa gpu: nvidia,nvidia-nvswitch display-ID: :0
Screen-1: 0 s-res: 6400x1080 s-dpi: 143 s-size: 1137x191mm (44.76x7.52")
s-diag: 1153mm (45.39")
Monitor-1: DP-4 mapped: DP-3 note: disabled pos: left model: Sceptre F27
built: 2019 res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2
size: 344x193mm (13.54x7.6") diag: 666mm (26.2") modes: max: 1920x1080
min: 640x480
Monitor-2: not-matched mapped: DP-4.1 pos: right res: 1920x1080 dpi: 93
Monitor-3: not-matched mapped: DP-4.3 pos: primary,center res: 2560x1080
hz: 75 dpi: 96 size: 677x290mm (26.65x11.42") diag: 736mm (29") modes: N/A
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA T1200 Laptop GPU/PCIe/SSE2
memory: 3.91 GiB
API: Vulkan v: 1.3.274 layers: 8 device: 0 type: discrete-gpu
name: NVIDIA T1200 Laptop GPU driver: nvidia v: 545.29.06
device-ID: 10de:1fbc surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.1-arch1.1 (LLVM
Device-1: Intel Tiger Lake-H HD Audio vendor: Lenovo
chip-ID: 8086:43c8 class-ID: 0401
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-3: Lenovo ThinkPad Thunderbolt 3 Dock USB Audio
lanes: 1 mode: 1.1 bus-ID: 5-2.1.1.2:7 chip-ID: 17ef:30c9 class-ID: 0300
API: ALSA v: k6.6.8-zen1-1-zen status: kernel-api tools: N/A
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 09:00.0 chip-ID: 8086:2725
IF: wlp9s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: Lenovo driver: igc v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 1 port: N/A bus-ID: 0b:00.0 chip-ID: 8086:15f3
IF: enp11s0 state: down mac: <filter>
Device-3: Lenovo ThinkPad TBT 3 Dock driver: r8152 type: USB rev: 3.0
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 6-2.1.2:4
chip-ID: 17ef:3082 class-ID: 0000 serial: <filter>
IF: enp34s0u2u1u2 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virtbr0 state: up speed: 1000 Mbps duplex: unknown mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-14:4 chip-ID: 8087:0032
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 1.84 TiB used: 189.28 GiB (10.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: 5123AJLA temp: 44.9 C
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 38.9 C
used: 189.28 GiB (20.3%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:7
used: 588 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6
ID-1: swap-1 type: zram size: 31.14 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 53.0 C mobo: N/A gpu: nvidia temp: 52 C
Processes: 379 Uptime: 1h 52m wakeups: 0 Memory: total: 32 GiB
available: 31.14 GiB used: 4.42 GiB (14.2%) Init: systemd v: 255
pm: pacman pkgs: 1722 libs: 519 tools: octopi,pamac,paru Shell: fish
v: 3.6.4 default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.22-1):
System install date: 2023-04-25
Last full system update: 2023-12-29
