I recently mentioned that the bottom toolbar was not always automatically hiding. It was suggested to change it from “dodge windows” to “auto-hide”. While that seems to have helped, it’s still not consistently hiding. Which is annoying when I need to read the bottom of webpages or apps.
Inxi
Kernel: 6.8.8-1-cachyos arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Type: Laptop System: Acer product: Predator PH315-53 v: V2.04
Mobo: CML model: QX50_CMS v: V2.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 2.04
date: 08/20/2021
ID-1: BAT1 charge: 43.5 Wh (100.0%) condition: 43.5/58.8 Wh (74.0%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1084 high: 2300 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1268 2: 901 3: 800 4: 898
5: 1653 6: 900 7: 800 8: 900 9: 891 10: 2300 11: 900 12: 800
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 550.54.14
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: HDMI-A-2 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-1-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x82ed built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.5-arch1.1.1
device-ID: 8086:9bc4 memory: 15.09 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 11 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: mesa intel v: 24.0.5-arch1.1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.54.14
device-ID: 10de:1f15 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.8.8-1-cachyos status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
Device-2: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
bus-ID: 08:00.0 chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
Info: services: NetworkManager, smbd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 3.19 TiB used: 1.63 TiB (51.1%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 53.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 57.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 560.63 GiB (30.3%)
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 560.63 GiB (30.3%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 1.21 GiB (7.8%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:4
System Temperatures: cpu: 64.0 C pch: 77.0 C mobo: N/A
Memory: total: 16 GiB available: 15.45 GiB used: 8.86 GiB (57.3%)
Processes: 405 Power: uptime: 11h 30m states: freeze,mem,disk
reboot, suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2256 libs: 576 tools: octopi,pamac,paru
pm: appimage pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 alt: 11
Shell: garuda-inxi default: Bash v: 5.2.26 running-in: konsole
inxi: 3.3.34
System install date: 2021-11-24
Last full system update: 2024-04-29
