i am trying to use bottles but whenever i start it get's stuck on "almost done we need a few more minutes to set everything up" and it has been ~30 mins
while on another system it installed with no issue
Tried to reinstall bottles, reinstall wine etc.. but nothing
garuda-inxi:
Kernel: 6.0.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=b42cd903-93d8-438e-a0ef-18fc5d149721 rw [email protected]
Desktop: KDE Plasma v: 5.26.4 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP 250 G8 Notebook PC
Mobo: HP model: 85F3 v: 40.34 serial: <superuser required> UEFI: Insyde
v: F.53 date: 10/15/2021
ID-1: BAT1 charge: 27.9 Wh (66.6%) condition: 41.9/41.0 Wh (102.0%)
volts: 12.5 min: 11.4 model: COMPAL PABAS0241231 type: Li-ion
Info: model: Intel Core i3-1005G1 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB6
L1: 160 KiB desc: d-2x48 KiB; i-2x32 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2863 high: 3227 min/max: 400/3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 2489 2: 3227 3: 2573
4: 3165 bogomips: 9523
Device-1: Intel Iris Plus Graphics G1 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-11 process: Intel 10nm built: 2019-21 ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:8a56 class-ID: 0300
Device-2: Luxvisions Innotech HP TrueVision HD Camera type: USB
driver: uvcvideo bus-ID: 1-5:3 chip-ID: 30c9:0035 class-ID: fe01
Monitor-1: eDP-1 model: LG Display 0x071d built: 2021 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel UHD Graphics (ICL GT1)
direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_icl
Sound API: ALSA v: k6.0.11-zen1-1-zen running: yes
lanes: 1 port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0
Device-1: Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8
bus-ID: 1-10:4 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 252.93 GiB used: 44.46 GiB (17.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: BC711 HFM256GD3JX013N size: 238.47 GiB block-size: physical: 512 B
rev: HPS1 temp: 38.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Verbatim model: STORE N GO
size: 14.45 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 8.07
ID-1: / raw-size: 178.89 GiB size: 178.89 GiB (100.00%)
used: 44.43 GiB (24.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 26 MiB (8.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 178.89 GiB size: 178.89 GiB (100.00%)
ID-4: /var/log raw-size: 178.89 GiB size: 178.89 GiB (100.00%)
ID-5: /var/tmp raw-size: 178.89 GiB size: 178.89 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.55 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: N/A
Processes: 212 Uptime: 24m wakeups: 1 Memory: 7.55 GiB used: 2.5 GiB (33.1%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1653 libs: 492
running-in: konsole inxi: 3.3.23
Garuda (2.6.10-1):
System install date: 2022-12-03
Last full system update: 2022-12-08
