greetings everyone, after recent installation of garuda now i’m having issues with bottles, at first i tried running it normally, just start it classically it starts right away without any setup, but upon clicking create new bottle absolutely nothing happen, no matter how much i click it
after that i switched to the terminal and used the bottle cli, tried to create the bottle from there, and i got this output
[🔴] × bottles-cli new --bottle-name lghub --environment application
11:03:55 (INFO) Forcing offline mode
Missing essential components. Installing…
No managed runners found.
No dxvk found.
No vkd3d found.
No nvapi found.
No latencyflex found.
No dxvk found.
No vkd3d found.
No nvapi found.
No dxvk found.
No vkd3d found.
No nvapi found.
Fail to install components, tried 3 times.
now trying to install lghub through wine is an experiment of mine, piper simply doesn’t offer what i need, but that’s outside the topic
anyhow, since this installation of bottles came preinstalled with the system i thought that perhaps some dependencies were missing, so i spun up octopi and just hit reinstall, and noticed that it asked me to install wine together with it, but, when i tried to install it, it conflicted with wine staging, so it means, i already have wine, so what i did is i uninstaller it and reinstalled it without checking the checkmark on wine, but once again, no success
as a last resort i tried to install bottles through flatpack, although i know it’s unsupported, however… still nothing, it installed just fine, launched it and same thing happened
Kernel: 6.12.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=60d751d8-c832-45e9-9bce-3558ee236afa rw rootflags=subvol=@
quiet resume=UUID=167c07eb-15e4-48ef-a6aa-01fc6749207f loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.4 tk: Qt v: N/A info: frameworks v: 6.8.0
Type: Desktop Mobo: Gigabyte model: A520M H v: x.x
UEFI: American Megatrends v: F10 date: 09/10/2020
Info: model: AMD Ryzen 5 5600G with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500011
desc: 6x512 KiB L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3867 min/max: 400/4464 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3867 2: 3867 3: 3867
4: 3867 5: 3867 6: 3867 7: 3867 8: 3867 9: 3867 10: 3867 11: 3867 12: 3867
bogomips: 93422
Device-1: NVIDIA GA106 [Geforce RTX 3050] vendor: ASUSTeK driver: nvidia
v: 565.77 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-09; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 3 speed: 8 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: DP-2,DP-3,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0 chip-ID: 10de:2507
Device-2: Advanced Micro Devices [AMD/ATI] Cezanne [Radeon Vega Series /
Radeon Mobile Series] vendor: Gigabyte driver: amdgpu v: kernel
active: none empty: DP-4, DP-5, DP-6, DP-7, DP-8 bus-ID: 09:00.0
chip-ID: 1002:1638 class-ID: 0300 temp: 33.0 C
gpu: nvidia,amdgpu d-rect: 5760x2160 display-ID: 0
Monitor-1: DP-2 pos: bottom-l res: 1920x1080 size: N/A modes: N/A
Monitor-2: DP-3 pos: top-center res: 1920x1080 size: N/A modes: N/A
Monitor-3: HDMI-A-1 pos: bottom-r res: 1920x1080 size: N/A modes: N/A
API: OpenGL v: 4.6.0 vendor: nvidia v: 565.77 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2
API: Vulkan v: 1.4.303 layers: 16 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 driver: N/A device-ID: 10de:2507
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: N/A device-ID: 1002:1638
Device-2: Advanced Micro Devices [AMD/ATI] Renoir Radeon High Definition
Audio driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637
vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6
Device-4: SteelSeries ApS Arctis Nova Pro Wireless
lanes: 1 mode: 1.1 bus-ID: 3-2:2 chip-ID: 1038:12e0 class-ID: 0300
API: ALSA v: k6.12.4-zen1-1-zen status: kernel-api with: aoss
lanes: 1 port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp7s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-1: ASUSTek Broadcom BCM20702A0 Bluetooth driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-1:2
chip-ID: 0b05:17cb class-ID: fe01 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.0
Local Storage: total: 3.86 TiB used: 1.16 TiB (30.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
lanes: 4 tech: SSD serial: <filter> fw-rev: ELFK1N.1 temp: 45.9 C
model: WD20EZRX-22D8PB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Kingston model: SHFS37A240G
tech: SSD serial: <filter> fw-rev: BBF0 scheme: MBR
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 337.24 GiB (18.4%)
used: 337.24 GiB (18.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 30.76 GiB used: 1.52 GiB (4.9%)
ID-2: swap-2 type: partition size: 33.83 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 45.1 C mobo: 32.0 C gpu: amdgpu temp: 34.0 C
Memory: total: 32 GiB note: est. available: 30.76 GiB used: 11.5 GiB (37.4%)
Processes: 452 Power: uptime: 15h 55m states: freeze,mem,disk
reboot, suspend, test_resume image: 12.25 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2000 libs: 583 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.36
System install date: 2024-12-11
Last full system update: 2024-12-12 ↻
