Hi everyone.
I did a garuda-update this evening and when I try to launch Bottles nothing happens. I tried reinstalling, tried restoring a snapshot but the issue persists.
╭─heinrichjvr@heinrich in ~ as 🧙 took 1ms
╰─λ garuda-inxi
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0ea6273c-a032-4ce8-84f0-1b79a7478883 rw rootflags=subvol=@
quiet rd.luks.uuid=dcc1ea46-1aab-4939-a45f-663f176541ee
rd.luks.uuid=9afc6940-3bc6-4720-81f2-cf42479ac3f5
resume=/dev/mapper/luks-9afc6940-3bc6-4720-81f2-cf42479ac3f5 loglevel=3
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.41 wm: Muffin v: 6.0.1 tools:
avail: cinnamon-screensaver,xautolock vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: Micro-Star model: B450 TOMAHAWK (MS-7C02) v: 1.0
Megatrends LLC. v: 1.I0 date: 07/25/2022
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics bits: 64 type: MCP
arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 2986 high: 3500 min/max: 1600/3500 boost: disabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1445 2: 3500
3: 3500 4: 3500 bogomips: 27948
vendor: ASUSTeK driver: amdgpu v: kernel arch: GCN-4 code: Arctic Islands
process: GF 14nm built: 2016-20 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: lanes: 16 ports: active: DVI-D-1 empty: DP-1,DVI-D-2,HDMI-A-1
bus-ID: 10:00.0 chip-ID: 1002:67df class-ID: 0300 temp: 46.0 C
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.6 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.65x9.37")
s-diag: 485mm (19.11")
Monitor-1: DVI-D-1 mapped: DVI-D-0 model: Samsung SyncMaster
serial: <filter> built: 2009 res: 1600x900 hz: 60 dpi: 92 gamma: 1.2
size: 443x250mm (17.44x9.84") diag: 509mm (20") ratio: 16:9 modes:
max: 1600x900 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 570 Series (radeonsi
polaris10 LLVM 17.0.6 DRM 3.57 6.8.7-zen1-2-zen) device-ID: 1002:67df
memory: 3.91 GiB unified: no
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 570 Series (RADV POLARIS10) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:67df surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
lanes: 8 link-max: lanes: 16 bus-ID: 10:00.1 chip-ID: 1002:aaf0
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 30:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api with: aoss
Message: No PCI device data found.
IF-ID-1: enp18s0f0u2 state: unknown speed: -1 duplex: half mac: <filter>
Device-1: Spreadtrum Unisoc Phone driver: rndis_host v: kernel type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:6 chip-ID: 1782:5d20
Report: This feature requires one of these tools: hciconfig/bt-adapter
Local Storage: total: 2.05 TiB used: 653.64 GiB (31.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Mushkin model: MKNSSDHL250GB-D8
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: S1111A0L temp: 41.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABD100
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1U scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABD100
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter> scheme: MBR
ID-4: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler G3
size: 7.46 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP
scheme: MBR
ID-1: / raw-size: 215.49 GiB size: 215.49 GiB (100.00%)
used: 26.6 GiB (12.3%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-dcc1ea46-1aab-4939-a45f-663f176541ee
used: 728 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 215.49 GiB size: 215.49 GiB (100.00%)
ID-4: /var/log raw-size: 215.49 GiB size: 215.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 215.49 GiB size: 215.49 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
mapped: luks-9afc6940-3bc6-4720-81f2-cf42479ac3f5
ID-2: swap-2 type: zram size: 15.54 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 36.9 C mobo: N/A gpu: amdgpu temp: 46.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 603
Memory: total: 16 GiB available: 15.54 GiB used: 1.78 GiB (11.5%)
Processes: 265 Power: uptime: 5m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: csd-power,upowerd
Packages: pm: pacman pkgs: 1499 libs: 507 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1
running-in: gnome-terminal inxi: 3.3.34
System install date: 2024-04-22
Last full system update: 2024-04-27
╭─heinrichjvr@heinrich in ~ as 🧙 took 1s
╰─λ
I tried launching Bottles in terminal with sudo, gave this error:
╭─heinrichjvr@heinrich in ~ took 1ms
╰─λ sudo bottles
[sudo] password for heinrichjvr:
File "/usr/bin/bottles", line 45, in <module>
from bottles.frontend import main
File "/usr/share/bottles/bottles/frontend/main.py", line 36, in <module>
from bottles.frontend.windows.main_window import MainWindow
File "/usr/share/bottles/bottles/frontend/windows/main_window.py", line 30, in <module>
from bottles.backend.managers.manager import Manager
File "/usr/share/bottles/bottles/backend/managers/manager.py", line 31, in <module>
import pathvalidate
ModuleNotFoundError: No module named 'pathvalidate'
╭─heinrichjvr@heinrich in ~ as 🧙 took 2s
I’m not sure if this ‘pathvalidate’ is related to a package by the same name but I checked Octopi and I do have that package installed. Perhaps this is an issue with Bottles itself, devs probably changed something or I messed something up somewhere.
Thanks
