This is my journal log in Garuda Diagnostics, not sure what to do to resolve these. I’ve tried searching nvidia-uvm and vboxpci via default and aur repositories, none were found. Guidance would be appreciated, thanks!
Nov 09 22:34:47 PHOENIXATE systemd-modules-load[317]: Failed to find module 'nvidia-uvm'
Nov 09 22:34:47 PHOENIXATE systemd-modules-load[317]: Failed to find module 'vboxpci'
Nov 09 22:34:48 PHOENIXATE kernel: r8168 Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
Nov 09 22:34:50 PHOENIXATE systemd-modules-load[667]: Failed to find module 'nvidia-uvm'
Nov 09 22:34:50 PHOENIXATE systemd-modules-load[667]: Failed to find module 'vboxpci'
Nov 09 22:34:51 PHOENIXATE kernel: Bluetooth: hci0: No support for _PRR ACPI method
Nov 09 22:34:55 PHOENIXATE 30-systemd-environment-d-generator[4771]: /home/pyro/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignoring.
Nov 09 22:34:55 PHOENIXATE dbus-broker-launch[4784]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.freedesktop.FileManager1.service'
Nov 09 22:34:55 PHOENIXATE dbus-broker-launch[4784]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Nov 09 22:34:55 PHOENIXATE dbus-broker-launch[4784]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.xfce.Thunar.FileManager1.service'
Nov 09 22:34:55 PHOENIXATE dbus-broker-launch[4784]: Ignoring duplicate name 'org.freedesktop.Notifications' in service file '/usr/share//dbus-1/services/org.xfce.xfce4-notifyd.Notifications.service'
Nov 09 22:34:55 PHOENIXATE sddm-helper[4762]: gkr-pam: couldn't unlock the login keyring.
Nov 09 22:34:55 PHOENIXATE 30-systemd-environment-d-generator[4977]: /home/pyro/.config/environment.d/firefox.conf:2: invalid variable name "env MOZ_USE_XINPUT2", ignoring.
Nov 09 22:34:57 PHOENIXATE plasmashell[5350]: aurorae: Couldn't find QML Decoration ""
Nov 09 22:34:59 PHOENIXATE org_kde_powerdevil[5396]: busno=6, All features that should not exist detected. Monitor does not indicate unsupported
Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=59989984-de13-4dab-af72-bdf1a83ee251 rw rootflags=subvol=@
quiet loglevel=3 splash ibt=off
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A wm: kwin_wayland tools:
avail: cinnamon-screensaver dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop Mobo: ASUSTeK model: TUF GAMING X570-PLUS (WI-FI) v: Rev X.0x
serial: <filter> part-nu: SKU uuid: ae53cc50-ddaa-324b-6791-c87f54ac95ba
UEFI: American Megatrends v: 5020 date: 08/30/2024
Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
Topology: cpus: 1x dies: 1 clusters: 1 cores: 16 threads: 32 tpc: 2
smt: enabled cache: L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB
desc: 16x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1743 min/max: 550/5084 boost: enabled
base/boost: 3400/5050 scaling: driver: amd-pstate-epp governor: powersave
volts: 1.1 V ext-clock: 100 MHz cores: 1: 1743 2: 1743 3: 1743 4: 1743
5: 1743 6: 1743 7: 1743 8: 1743 9: 1743 10: 1743 11: 1743 12: 1743
13: 1743 14: 1743 15: 1743 16: 1743 17: 1743 18: 1743 19: 1743 20: 1743
21: 1743 22: 1743 23: 1743 24: 1743 25: 1743 26: 1743 27: 1743 28: 1743
29: 1743 30: 1743 31: 1743 32: 1743 bogomips: 217594
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3,
HDMI-A-1, Writeback-1 bus-ID: 09:00.0 chip-ID: 1002:744c class-ID: 0300
Device-2: Logitech BRIO Ultra HD Webcam
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo type: USB rev: 3.1
speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-2:3 chip-ID: 046d:085e
Display: unspecified server: X.Org v: 24.1.4 with: Xwayland v: 24.1.4
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-1 model: Dell AW3423DWF serial: <filter> built: 2023
res: 3440x1440 hz: 165 dpi: 109 gamma: 1.2 size: 800x337mm (31.5x13.27")
diag: 868mm (34.2") modes: max: 3440x1440 min: 720x400
device: 1 drv: swrast gbm: drv: radeonsi surfaceless: drv: radeonsi x11:
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.6-arch1.1
navi31 LLVM 18.1.8 DRM 3.59 6.11.6-zen1-1-zen) device-ID: 1002:744c
memory: 23.44 GiB unified: no
API: Vulkan v: 1.3.295 layers: 12 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: mesa radv v: 24.2.6-arch1.1
device-ID: 1002:744c surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.6-arch1.1 (LLVM
bus-ID: 09:00.1 chip-ID: 1002:ab30 class-ID: 0403
lanes: 16 bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech BRIO Ultra HD Webcam
API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.6 status: n/a (root, process) with:
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 04:00.0
vendor: ASUSTeK driver: r8168 v: 8.054.00-NAPI modules: r8169 pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0 chip-ID: 10ec:8168
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-5:3 chip-ID: 8087:0032
Local Storage: total: 1.82 TiB used: 693.79 GiB (37.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO with
Heatsink 2TB size: 1.82 TiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7
temp: 51.9 C scheme: GPT
SMART: yes health: PASSED on: 182d 0h cycles: 2,468
read-units: 48,460,270 [24.8 TB] written-units: 46,407,125 [23.7 TB]
ID-1: / raw-size: 1.57 TiB size: 1.57 TiB (100.00%) used: 693.76 GiB (43.0%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5 maj-min: 259:5
used: 31.7 MiB (33.0%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 1.57 TiB size: 1.57 TiB (100.00%)
used: 693.76 GiB (43.0%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-4: /var/log raw-size: 1.57 TiB size: 1.57 TiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 1.57 TiB size: 1.57 TiB (100.00%)
maj-min: 259:5
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 48.1 C mobo: 41.0 C gpu: amdgpu temp: 57.0 C
mem: 64.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 942 fan-3: 0 fan-4: 0 fan-5: 3146
fan-6: 2156 fan-7: 0 gpu: amdgpu fan: 0
Memory: total: 32 GiB available: 31.25 GiB used: 6.15 GiB (19.7%)
Processes: 571 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2342 libs: 601
tools: gnome-software,octopi,paru pm: flatpak pkgs: 0 Compilers:
clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: garuda-inxi (sudo) default: Bash
v: 5.2.37 running-in: konsole inxi: 3.3.36
System install date: 2024-11-02
Last full system update: 2024-11-09 ↻
Windows dual boot: Yes
