Boots to TTY after upgrade
  Kernel: 6.2.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=b5d503f4-6af8-4fad-afdb-a829dc8d8588 rw [email protected]
    loglevel=3 ibt=off
  Desktop: MATE v: 1.26.1 info: mate-panel wm: marco v: 1.26.1 vt: 1
    dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Acer product: Nitro AN515-42 v: V1.13
  Mobo: RR model: Freed_RRS v: V1.13 serial: <superuser required>
    UEFI: Insyde v: 1.13 date: 02/11/2019
  ID-1: BAT1 charge: 36.0 Wh (100.0%) condition: 36.0/48.9 Wh (73.5%)
    volts: 16.3 min: 15.2 model: LG 0x41,0x43,0x31,0x34,0x42,0x38,0 type: Li-ion
    serial: <filter> status: full
  Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
    family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1620 high: 2000 min/max: 1600/2000 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 2000
    3: 1600 4: 1510 5: 1600 6: 1450 7: 1600 8: 1600 bogomips: 31938
  Device-1: AMD Baffin [Radeon RX 460/560D / Pro
    450/455/460/555/555X/560/560X] vendor: Acer Incorporated ALI
    built: 2016-20 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
    speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 1002:67ef class-ID: 0380
    temp: 36.0 C
  Device-2: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5
    lanes: 16 ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0
    chip-ID: 1002:15dd class-ID: 0300 temp: 37.0 C
  Device-3: Quanta HD Webcam type: USB driver: uvcvideo bus-ID: 3-1:2
    chip-ID: 0408:a060 class-ID: 0e02 serial: <filter>
  Display: server: X.Org v: 21.1.8 compositor: marco v: 1.26.1 driver: X:
    loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
    dri: radeonsi gpu: amdgpu display-ID: :0 screens: 1
  Monitor-1: eDP-1 mapped: eDP model: LG Display 0x05d8 built: 2018
    res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
    missing.
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio
    vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 04:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
  API: ALSA v: k6.2.10-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
    speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.1 chip-ID: 10ec:8168
  IF: enp2s0f1 state: down mac: <filter>
    vendor: Lite-On driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 03:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 35.0 C
  Device-1: Lite-On type: USB driver: btusb v: 0.8 bus-ID: 1-4:3
    chip-ID: 04ca:3016 class-ID: e001
  Local Storage: total: 5.57 TiB used: 5.04 TiB (90.6%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    type: SSD serial: <filter> rev: 023 scheme: MBR
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400M8120G
    type: SSD serial: <filter> rev: 61E1 scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate model: BUP Portable
    size: 4.55 TiB block-size: physical: 4096 B logical: 512 B type: N/A
    serial: <filter> rev: 1708 scheme: GPT
  ID-1: / raw-size: 96 GiB size: 96 GiB (100.00%) used: 16.19 GiB (16.9%)
    fs: btrfs dev: /dev/sdb1 maj-min: 8:17
  ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.45%)
    used: 891 KiB (0.9%) fs: vfat dev: /dev/sdb2 maj-min: 8:18
  ID-3: /home raw-size: 931.51 GiB size: 915.82 GiB (98.32%)
    used: 787.79 GiB (86.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
  ID-4: /var/log raw-size: 96 GiB size: 96 GiB (100.00%)
    used: 16.19 GiB (16.9%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
  ID-5: /var/tmp raw-size: 96 GiB size: 96 GiB (100.00%)
  ID-1: swap-1 type: zram size: 30.26 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 37.8 C mobo: N/A
  GPU: device: amdgpu temp: 36.0 C watts: 9.11 device: amdgpu temp: 37.0 C
  Processes: 325 Uptime: 2m wakeups: 1 Memory: 30.26 GiB
  used: 4.94 GiB (16.3%) Init: systemd v: 253 default: graphical
  pkgs: 1529 libs: 503 tools: octopi,pamac,paru,yay Shell: Bash v: 5.1.16
  running-in: mate-terminal inxi: 3.3.26
  System install date:     2023-03-29
  Last full system update: 2023-04-07
After today's updates, with a new kernel, the PC boots into TTY. I am able to log in and issue a startx command, but what happened to the display manager?
There are many post about this with the solutions, please use the forum search before reporting again.
