Booting/installation failure 20250308 images
Hi!
I’m trying to get garuda up and running but I do run from ‘error to error’.
At first there was just a black screen - used the fix with ventoy to boot the image.
But the image is showing an error - tested mokka and hyperland. As I’m a new user I cannot upload images…
It is showing something like:
dracut-init2queue{7331}: Warning: dracut-initqueue: starting timeput scripts
Warning: /dev/disk/by-label/GARUDA_HYPERLAND_BROADWING does not exist
Entering emergency mode…
That’s it - nothing more.
Any hints?
Kind regards,
Did you remove the USB-Stick?
Did you install on USB-Stick?
Use live ISO to check lsblk -f and /ets/fstab
Search for /boot/ and the initramfs- images
Blockquote
No I didn’t
Blockquote
No I didn’t
Blockquote
I do not reach the system. The last output is ‘Reached Target Basic System’ and after that the error-messages are shown…
This is standard for new members to prevent spam and other nonsense. You can use an external pic hoster and post the link here.
In Grub2 mode?
Checksum correct after download? Checksum of the iso on the ventoy-stick correct after copying?
BIOS settings correct? Secure Boot off, Fastboot off, AHCI on?
Manufacturer and model of the Mobo/PC/Laptop?
Blockquote
In Grub2 mode?
yes
Blockquote
yes
Blockquote
yes
MSI MEG x570 unify
This is the error:
hi tom_246
i have both isos mokka and hyperland. i have a usb drive with those versions and more from garuda and it worked fine Ventoy and grub 2 at all. Did you have a older Ventoy USB Drive please update them or reinstall Ventoy again to your USB Drive.
Do you use the official isos from the Website or the devs isos?
Hi Duke187!
The ventoy I creaded three days ago - should be up to date.
I tested this stick with endeavour and manjaro and both do boot up to reach the desktop. Right now it’s something with the garuda-image, which is the original one - no dev-iso.
okay that is wired because i had those issues sometimes with the dev isos but actually installed via Ventoy Hyperland and its working on my pc. (garuda-hyprland-linux-zen-250308.iso downloaded and created on 17 march 25 and 2.6GiB)
Used an old garuda-iso (garuda-dr460nized-linux-zen-240428.iso) and this iso is just booting fine… Just did the upload to ventoy-stick…
I don’t know what changed between 240428 and 250308… but my PC doesn’t like it… :sweat_smile:
I tested some other USB-Sticks and an ssd connected by usb… always the same result…
Without ventoy garuda-iso will not boot, using ventoy I’m stuck at ‘reached targed basic system’…
So no chance for me to use Garuda? Will I have to wait for the next iso-release in 2026 to test it again? :wink: :innocent:
On which system you are creating the usb stick?
Do you want install to a ssd external or from it?
Did you try disconnect other ssd or other usb port?
Do you have a nvidia gpu card?
No problems on my PCs, with and without Nvidia GPU. The notebooks, AMD and Intel CPU, internal GPU, only work with the detour Grub2.
You are now the first one where nothing works.
Maybe it would be helpful for our developers if you would post garuda-inxi from an old Gauruda ISO.
Or from other OS, inxi -Faz.
BTW
How old is you Hardware?
I’m creating the usb stick on the PC I will use to install/run Garuda (dual boot with Win).
For installation I will use free space on the internal nvme-drive.
I used several usb-ports - even installed a new pcie-card with usb-ports.
No, no nvidia gpu.
Will do so - but it will be on the weekend - work…
I’m using an MSI x570 Motherboard with ryzen 9 5950x cpu.
Maybe it’s the other way around and “Broadwing” doesn’t like your PC. :grin:
I only know the error message from installed systems (and a simple dracut rebuild is usually enough), but I have never seen it on a live.iso.
Try disconnecting all internal drives and check whether the live.iso can then be booted without issues.
If none of this works, then simply install your working “Bird of Prey” garuda-dr460nized-linux-zen-240428.iso. After the system update it will be up to date, what you still need for “Broadwing” is kwin-effect-rounded-corners-git and (IIRC) the panel colorizer. You can install that afterwards if you want:
If you want Garuda Mokka, then also install the “Bird of Prey” dr460nized.iso and then migrate to Mokka:
If you want to install Garuda Hyprland, then take the “Bird of Prey” hyprland.iso:
This is the output of garuda-inxi.
sudo garuda-inxi
Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=1234 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Desktop System: Micro-Star product: MS-7C35 v: 2.0 serial: N/A
Mobo: Micro-Star model: MEG X570 UNIFY (MS-7C35) v: 2.0 serial: <filter>
uuid: 1234 UEFI: American Megatrends LLC.
v: A.L1 date: 09/03/2024
Info: model: AMD Ryzen 9 5950X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 2312 high: 3400 min/max: 2200/5083 boost: enabled
base/boost: 3400/5050 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.1 V ext-clock: 100 MHz cores: 1: 2200 2: 3400 3: 2200 4: 2200
5: 2200 6: 2200 7: 2200 8: 2200 9: 3400 10: 2200 11: 2200 12: 2200
13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200 20: 2200
21: 2200 22: 2200 23: 2200 24: 2200 25: 2200 26: 2200 27: 2200 28: 2200
29: 2200 30: 2200 31: 2200 32: 3400 bogomips: 217601
driver: amdgpu v: kernel arch: RDNA-1 code: Navi-1x process: TSMC n7 (7nm)
built: 2019-20 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1
empty: DP-2,DP-3,HDMI-A-1 bus-ID: 2f:00.0 chip-ID: 1002:731f
Display: server: X.Org v: 23.2.6 with: Xwayland v: 23.2.6
gpu: amdgpu display-ID: :1 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-1 model: Mi Monitor serial: <filter> built: 2020
res: 3440x1440 hz: 50 dpi: 109 gamma: 1.2 size: 800x330mm (31.5x12.99")
diag: 864mm (34") modes: max: 3440x1440 min: 720x400
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 5700 (radeonsi navi10
LLVM 17.0.6 DRM 3.57 6.8.7-zen1-2-zen) device-ID: 1002:731f
memory: 7.81 GiB unified: no
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 5700 (RADV NAVI10) driver: mesa radv v: 24.0.5-arch1.1
device-ID: 1002:731f surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 2f:00.1 chip-ID: 1002:ab38
bus-ID: 31:00.4 chip-ID: 1022:1487 class-ID: 0403
API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.5 status: n/a (root, process) with:
Device-1: Mellanox MT27710 Family [ConnectX-4 Lx] driver: mlx5_core
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 4 link-max: lanes: 8 port: N/A
bus-ID: 24:00.0 chip-ID: 15b3:1015 class-ID: 0200
IF: enp36s0f0np0 state: up speed: 10000 Mbps duplex: full mac: <filter>
Device-2: Mellanox MT27710 Family [ConnectX-4 Lx] driver: mlx5_core
bus-ID: 24:00.1 chip-ID: 15b3:1015 class-ID: 0200
IF: enp36s0f1np1 state: up speed: 25000 Mbps duplex: full mac: <filter>
Device-3: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 27:00.0
IF: enp39s0 state: down mac: <filter>
Device-4: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 28:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 8087:0032
Local Storage: total: 1.85 TiB used: 4.29 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Crucial model: CT1000T500SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P8CR004 temp: 34.9 C
SMART: yes health: PASSED on: 53 hrs cycles: 60
read-units: 455,843 [233 GB] written-units: 1,008,977 [516 GB]
model: WDS100T1X0E-00AFY0 size: 931.51 GiB block-size: physical: 512 B
fw-rev: 613200WD temp: 46.9 C scheme: GPT
SMART: yes health: PASSED on: 268d 4h cycles: 2,837
read-units: 41,917,600 [21.4 TB] written-units: 52,797,561 [27.0 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Intenso model: Alu Line
size: 29.53 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: 8.07 scheme: MBR
ID-1: / raw-size: 525.84 GiB size: 525.84 GiB (100.00%)
used: 4.25 GiB (0.8%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p6
maj-min: 259:8
ID-2: /boot/efi raw-size: 750 MiB size: 748.5 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:7
ID-3: /home raw-size: 525.84 GiB size: 525.84 GiB (100.00%)
maj-min: 259:8
ID-4: /var/log raw-size: 525.84 GiB size: 525.84 GiB (100.00%)
maj-min: 259:8
ID-5: /var/tmp raw-size: 525.84 GiB size: 525.84 GiB (100.00%)
maj-min: 259:8
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 32 dev: /dev/zram0
System Temperatures: cpu: 43.2 C mobo: N/A gpu: amdgpu temp: 32.0 C
mem: 36.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 65535
Memory: total: 32 GiB available: 31.26 GiB used: 3.28 GiB (10.5%)
Processes: 569 Power: uptime: 10m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1247 libs: 370 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
System install date:     2025-03-29
Last full system update: 2025-03-29
Windows dual boot:       Yes
What happened during installation is that the Windows Explorer is showing a btrfs-filesystem with some snapshots (‘@’, cache, home, log, root, srv, tmp) now. Disk management isn’t showing anything with this ‘drive letter’!?
What is this? Where is it coming from?
I think calamares choose only the volume and settings the user selects. @dalto :slight_smile: ?
It isn’t a network-share.
I mounted the network-share with another drive-letter and it is fine.
After reboot this new drive isn’t listed with the ip anymore - now it is a ‘local disk’.
Disk part is showing the two nvme-drives only but the disk management isn’t showing any drive with this letter… According to Windows Explorer it is some 11GB - there is no partition with this size…
I just included a fat32-partition with mount-point /boot/efi and the free space as /… Nothing more…
As I do know now how to get Garuda installed I deleted the two partitions I created for the Garuda installation and this ghost-partition is gone…
Funny thing…
