Hey team Garuda,
Recently I did a fresh Install of Garuda OS.
After Getting everything done post installation everytime when I rebooted my system it said
[Failed] Failed to start Setup Virtual Console
Garuda inxi -
clocksource: hpet available: acpi_pm
root=UUID=f824512c-ed25-441b-9895-43b8d09686a7 rw rootflags=subvol=@
quiet resume=UUID=7eecd08e-d0a9-496f-8a87-1712b6f17e8d loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 81UT v: Lenovo IdeaPad S145-15API
serial: Chassis: type: 10 v: Lenovo IdeaPad S145-15API
serial:
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55724WIN
serial: UEFI: LENOVO v: BUCN31WW date: 02/11/2022
ID-1: BAT0 charge: 15.4 Wh (52.0%) condition: 29.6/35.0 Wh (84.5%)
power: 6.7 W volts: 7.5 min: 7.5 model: SMP L16M2PB2 type: Li-poly
serial: status: discharging cycles: 457
Info: model: AMD Ryzen 3 3200U with Radeon Vega Mobile Gfx bits: 64
stepping: 1 microcode: 0x8108102
L1: 192 KiB desc: d-2x32 KiB; i-2x64 KiB L2: 1024 KiB desc: 2x512 KiB
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1430 high: 1507 min/max: 1400/2600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1331 2: 1400
3: 1507 4: 1482 bogomips: 20761
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 41.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 174f:1176
class-ID: 0e02
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
drv: radeonsi inactive: gbm
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 3 Graphics (raven2
LLVM 16.0.6 DRM 3.54 6.5.9-zen2-1-zen) device-ID: 1002:15d8
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Vega 3 Graphics (RADV RAVEN2) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:15d8 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
IF: wlp2s0 state: up mac:
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 0cf3:e500
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: bt-v: 4.2
Local Storage: total: 1.36 TiB used: 10.54 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Silicon Power
model: SPCC M.2 PCIe SSD size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: ELFMB0.6 temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPZX-24Z10
tech: HDD rpm: 5400 serial: fw-rev: 1A05 scheme: GPT
ID-1: / raw-size: 454.91 GiB size: 454.91 GiB (100.00%)
used: 10.54 GiB (2.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 454.91 GiB size: 454.91 GiB (100.00%)
ID-4: /var/log raw-size: 454.91 GiB size: 454.91 GiB (100.00%)
ID-5: /var/tmp raw-size: 454.91 GiB size: 454.91 GiB (100.00%)
ID-1: swap-1 type: zram size: 9.59 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 10.55 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 43.5 C mobo: N/A gpu: amdgpu temp: 43.0 C
Processes: 236 Uptime: 36m wakeups: 0 Memory: total: 12 GiB note: est.
available: 9.59 GiB used: 3.57 GiB (37.3%) Init: systemd v: 254
pm: pacman pkgs: 1411 libs: 411 tools: octopi,paru Shell: fish v: 3.6.1
error: blackarch: key “F9A6E68A711354D84A9B91637533BAFE69A25079” is unknown
error: keyring is not writable
Garuda (2.6.17-1):
System install date: 2023-11-05
Last full system update: 2023-11-05
Failed units: packagekit.service systemd-vconsole-setup.service
