Hello!
If i choose pt keyboard or portuguese language the login always fails, but that doesn’t happen in english keyboard and us-english language. Im only able to enter the liveos envrioment that way. When i go to install the calamares installer doesn-t open.
Here is my garuda-inxi:
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us
tz=Europe/Lisbon misobasedir=garuda
root=miso:LABEL=GARUDA_HYPRLAND_RAPTOR quiet systemd.show_status=1
ibt=off driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Type: Laptop System: HP product: OMEN by HP Laptop 16-c0xxx v: N/A
Mobo: HP model: 8902 v: 89.62 serial: <superuser required> UEFI: AMI
v: F.22 date: 10/12/2023
ID-1: BAT0 charge: 61.3 Wh (100.0%) condition: 61.3/61.3 Wh (100.0%)
volts: 17.0 min: 15.4 model: HP Primary type: Li-ion serial: <filter>
status: full cycles: 72
microcode: 0xA50000F
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 545 high: 2729 min/max: 400/4463 scaling:
4: 400 5: 400 6: 400 7: 2729 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 102212
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] vendor: Hewlett-Packard
empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:73ff class-ID: 0380
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-2
bus-ID: 09:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 47.0 C
Device-3: Chicony [] driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 04f2:b735 class-ID: fe01
compositor: Hyprland driver: X: loaded: amdgpu unloaded: modesetting,radeon
alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 1
Monitor-1: eDP-1 model: BOE Display 0x0aae built: 2021 res: 1920x1080
hz: 144 dpi: 137 gamma: 1.2 scale: 1 size: 355x200mm (13.98x7.87")
diag: 407mm (16") ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: AMD Radeon RX 6600M (RADV NAVI23)
driver: mesa radv v: 23.2.1-arch1.2 device-ID: 1002:73ff
16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: AMD Navi 21/23 HDMI/DP Audio vendor: Hewlett-Packard
bus-ID: 03:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: AMD Renoir Radeon High Definition Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.1 chip-ID: 1002:1637
Device-3: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Hewlett-Packard
driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x,
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.5
Device-4: AMD Family 17h/19h HD Audio vendor: Hewlett-Packard
link-max: gen: 4 speed: 16 GT/s bus-ID: 09:00.6 chip-ID: 1022:15e3
Server-2: PipeWire v: 0.3.83 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw89_8852ae v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 05:00.0 chip-ID: 10ec:8852
Device-1: Realtek [] driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0bda:2852 class-ID: e001
Local Storage: total: 2.82 TiB used: 0 KiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Seagate
model: XPG GAMMIX S70 BLADE size: 1.86 TiB block-size: physical: 512 B
fw-rev: 3.2.F.83 temp: 36.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Micron
model: MTFDHBA1T0TDV-1AZ1AABHA size: 953.87 GiB block-size: physical: 512 B
fw-rev: HPS0032 temp: 31.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: SMI (STMicroelectronics) model: USB
size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.0
spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1100 scheme: MBR
ID-1: swap-1 type: zram size: 30.7 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 63.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0 fan-2: 0
GPU: device: amdgpu temp: 50.0 C mem: 50.0 C fan: 0 watts: 5.00
device: amdgpu temp: 47.0 C
Processes: 365 Uptime: 23m wakeups: 2 Memory: total: 32 GiB note: est.
available: 30.7 GiB used: 4.4 GiB (14.4%) Init: systemd v: 254
pm: pacman pkgs: 1239 libs: 356 tools: paru,trizen Shell: fish v: 3.6.1
running-in: alacritty inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-12-07
Last full system update: 2023-12-07 ↻
Is partially upgraded: Yes
The calamares error:
Process 15873 (calamares) of user 0 dumped core.
Stack trace of thread 15873:
#0 0x00007f2ffab7e83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f2ffab2e668 raise (libc.so.6 + 0x3e668)
#2 0x00007f2ffab164b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f2ffb0140c2 _ZNK14QMessageLogger5fatalEPKcz (libQt5Core.so.5 + 0xa00c2)
#4 0x00007f2ffb5eb402 _ZN22QGuiApplicationPrivate25createPlatformIntegrationEv (libQt5Gui.so.5 + 0x13f402)
#5 0x00007f2ffb5eba79 _ZN22QGuiApplicationPrivate21createEventDispatcherEv (libQt5Gui.so.5 + 0x13fa79)
#6 0x00007f2ffb20fc05 _ZN23QCoreApplicationPrivate4initEv (libQt5Core.so.5 + 0x29bc05)
#7 0x00007f2ffb5ebb26 _ZN22QGuiApplicationPrivate4initEv (libQt5Gui.so.5 + 0x13fb26)
#8 0x00007f2ffc81ab9e _ZN19QApplicationPrivate4initEv (libQt5Widgets.so.5 + 0x175b9e)
#9 0x0000555eb3386eed _ZN20CalamaresApplicationC2ERiPPc (calamares + 0x17eed)
#10 0x0000555eb3384f95 main (calamares + 0x15f95)
#11 0x00007f2ffab17cd0 n/a (libc.so.6 + 0x27cd0)
#12 0x00007f2ffab17d8a __libc_start_main (libc.so.6 + 0x27d8a)
#13 0x0000555eb3385c55 _start (calamares + 0x16c55)
Stack trace of thread 15884:
#0 0x00007f2ffabf2f6f __poll (libc.so.6 + 0x102f6f)
#1 0x00007f2ff8f33276 n/a (libglib-2.0.so.0 + 0xb8276)
#2 0x00007f2ff8ed3162 g_main_context_iteration (libglib-2.0.so.0 + 0x58162)
#3 0x00007f2ffb25ef7c _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2eaf7c)
#4 0x00007f2ffb20ee74 _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x29ae74)
#5 0x00007f2ffb06b4f6 _ZN7QThread4execEv (libQt5Core.so.5 + 0xf74f6)
#6 0x00007f2ffa13aa9a n/a (libQt5DBus.so.5 + 0x18a9a)
#7 0x00007f2ffb06771a n/a (libQt5Core.so.5 + 0xf371a)
#8 0x00007f2ffab7c9eb n/a (libc.so.6 + 0x8c9eb)
#9 0x00007f2ffac007cc n/a (libc.so.6 + 0x1107cc)
ELF object binary architecture: AMD x86-64
I tried both rufus and etcher to install the bootable iso, same result.
