Yes indeed, but after I ran the Bash script (posted above) thinks are a bit better. Here’s the current situ:
inxi -Fraz
System: Kernel: 5.12.11-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-06-21_15-30-15/@/boot/vmlinuz-linux-zen
root=UUID=e8afabb7-2035-4f3d-9517-d4c56593050a rw rootflags=subvol=timeshift-btrfs/snapshots/2021-06-21_15-30-15/@
quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: KDE Plasma 5.22.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: BESSTAR TECH LIMITED product: X400 v: N/A serial: <filter>
Mobo: BESSTAR TECH model: N/A serial: <filter> UEFI: American Megatrends v: ATB15011 date: 01/12/2021
CPU: Info: 6-Core model: AMD Ryzen 5 PRO 4650G with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600106 cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 88636
Speed: 2994 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz): 1: 2994 2: 2953 3: 2994 4: 2997 5: 2994
6: 2990 7: 3376 8: 2993 9: 2994 10: 2986 11: 2955 12: 2984
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel bus-ID: 05:00.0 chip-ID: 1002:1636
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5") s-diag: 1165mm (45.9")
Monitor-1: HDMI-A-0 res: 3840x2160 hz: 60 dpi: 140 size: 698x393mm (27.5x15.5") diag: 801mm (31.5")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.11-zen1-1-zen LLVM 12.0.0) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 05:00.1 chip-ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Realtek driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.12.11-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: f000 bus-ID: 02:00.0
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: e000 bus-ID: 03:00.0
Device-3: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel port: e000 bus-ID: 04:00.0 chip-ID: 8086:2723
Device-4: Realtek RTL88x2bu [AC1200 Techkey] type: USB driver: rtl88x2bu bus-ID: 1-2:2 chip-ID: 0bda:b812
IF: wlp5s0f3u2 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 3-1:2 chip-ID: 8087:0029 class-ID: e001
Drives: Local Storage: total: 480.67 GiB used: 169.18 GiB (35.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-A01 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: EDFK0S03 scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: General USB Flash Disk size: 3.73 GiB block-size: physical: 512 B
logical: 512 B rotation: SSD serial: <filter> rev: 1.0 scheme: MBR
Partition: ID-1: / raw-size: 223.84 GiB size: 223.84 GiB (100.00%) used: 169.15 GiB (75.6%) fs: btrfs dev: /dev/nvme0n1p6
maj-min: 259:6
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 30.5 MiB (31.8%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 223.84 GiB size: 223.84 GiB (100.00%) used: 169.15 GiB (75.6%) fs: btrfs dev: /dev/nvme0n1p6
maj-min: 259:6
ID-4: /var/log raw-size: 223.84 GiB size: 223.84 GiB (100.00%) used: 169.15 GiB (75.6%) fs: btrfs
dev: /dev/nvme0n1p6 maj-min: 259:6
ID-5: /var/tmp raw-size: 223.84 GiB size: 223.84 GiB (100.00%) used: 169.15 GiB (75.6%) fs: btrfs
ID-1: swap-1 type: zram size: 1.26 GiB used: 196 MiB (15.2%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.26 GiB used: 190.6 MiB (14.8%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.26 GiB used: 200.7 MiB (15.6%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.26 GiB used: 192.4 MiB (14.9%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 1.26 GiB used: 200 MiB (15.5%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 1.26 GiB used: 190.1 MiB (14.7%) priority: 32767 dev: /dev/zram5
Sensors: System Temperatures: cpu: 35.2 C mobo: 0 C gpu: amdgpu temp: 32.0 C
Repos: Packages: pacman: 1748 lib: 549
Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
1: https://random-mirror.chaotic.cx/$repo/$arch
2: https://cdn-mirror.chaotic.cx/$repo/$arch
3: https://us-wa-mirror.chaotic.cx/$repo/$arch
4: https://us-ut-mirror.chaotic.cx/$repo/$arch
5: https://us-ca-mirror.chaotic.cx/$repo/$arch
6: https://nl-mirror.chaotic.cx/$repo/$arch
7: https://es-mirror.chaotic.cx/$repo/$arch
8: https://de-1-mirror.chaotic.cx/$repo/$arch
9: http://de-2-mirror.chaotic.cx/$repo/$arch
10: https://de-3-mirror.chaotic.cx/$repo/$arch
11: https://de-4-mirror.chaotic.cx/$repo/$arch
12: https://be-bru-mirror.chaotic.cx/$repo/$arch
13: https://kr-mirror.chaotic.cx/$repo/$arch
14: https://bg-mirror.chaotic.cx/$repo/$arch
15: https://ca-mirror.chaotic.cx/$repo/$arch
Active pacman repo servers in: /etc/pacman.d/mirrorlist
1: https://arch.nimukaito.net/$repo/os/$arch
2: https://arch.yourlabs.org/$repo/os/$arch
3: https://archlinux.mailtunnel.eu/$repo/os/$arch
4: https://mirror.wormhole.eu/archlinux/$repo/os/$arch
5: https://mirrors.celianvdb.fr/archlinux/$repo/os/$arch
6: https://mirror.thekinrar.fr/archlinux/$repo/os/$arch
7: https://mirror.oldsql.cc/archlinux/$repo/os/$arch
8: https://mirror.cyberbits.eu/archlinux/$repo/os/$arch
9: https://arch-mirror.cloud.louifox.house/$repo/os/$arch
10: https://mirror.sysa.tech/archlinux/$repo/os/$arch
Info: Processes: 317 Uptime: 1d 19h 30m wakeups: 0 Memory: 15.11 GiB used: 6.11 GiB (40.5%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Shell: fish v: 3.2.2 running-in: konsole inxi: 3.3.04
