Boot issue after initial updates applied
Won't boot after initial update:
  1. Reinstall from thumb-drive, install completes no issues.
  2. Reboot and login
  3. All is everything is functioning fine no errors
  4. Apply the requested system updates, no install errors and reboot
  5. Stuck at black screen stating it starting the ramdisk.
  6. Reboot try recovery mode, all three options render the same screen 2 line black screen, I have waited over an hour for it move on and never does.
  7. Rinse and repeat ;-), I can't get past the update. So I am currently not updating. The LTS Kernel when I install it is a little better but to quirky. I have repeated this process 5 or 6 times, Once the updates apply I can get back into my system to grab any logs etc.. But life has been good till now.
I have been using Garuda on this machine for about 6 months. No issue until now. Applying updates etc.
I have removed the quite quiet splash, no difference and goes on showing the boot process with exception of the first after reboot of initial install.
Grub Line:rd.udev.log_priority=3 vt.global_cursor_default=0 loglevel=3 ibt=off
It's been a lot of up to the latest updates ;-).
root=UUID=b1681b29-99de-42f9-8c9a-7aa216c7392e rw rootflags=subvol=@
Mobo: ASUSTeK model: TUF GAMING Z590-PLUS WIFI v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 1801
date: 12/26/2022
Device-1: hid-0003:256F:C62E.0001-battery model: 3Dconnexion SpaceMouse
Wireless serial: N/A charge: N/A status: discharging
Info: model: 11th Gen Intel Core i9-11900KF bits: 64 type: MT MCP
arch: Rocket Lake gen: core 11 level: v4 note: check built: 2021+
process: Intel 14nm family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x57
L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3895 high: 5197 min/max: 800/5100:5300 scaling:
driver: intel_pstate governor: powersave cores: 1: 5063 2: 5063 3: 3500
4: 3500 5: 5000 6: 5197 7: 3500 8: 3500 9: 3500 10: 3500 11: 3500 12: 3500
13: 3500 14: 3500 15: 3500 16: 3500 bogomips: 112128
Device-1: NVIDIA TU104 [GeForce RTX 2080 Rev. A] vendor: ZOTAC
status: current (as of 2023-03) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 bus-ID: 0000:01:00.0
chip-ID: 10de:1e87 class-ID: 0300
Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Micro-Star MSI
status: current (as of 2023-03) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 bus-ID: 0000:04:00.0 chip-ID: 10de:1c82
Device-3: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 5-3.4.2:5 chip-ID: 046d:082d
alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia display-ID: :0
Screen-1: 0 s-res: 8320x1440 s-dpi: 92 s-size: 2297x393mm (90.43x15.47")
s-diag: 2330mm (91.75")
Monitor-1: DP-1 pos: 2-4 res: 1920x1080 hz: 60 dpi: 82
Monitor-2: DP-3 pos: 2-2 res: 1920x1080 hz: 60 dpi: 82
Monitor-3: DP-4 pos: primary,1-3 res: 2560x1440 dpi: 65024
size: 1x1mm (0.04x0.04") diag: 1mm (0.06") modes: N/A
Monitor-4: USB-C-0 pos: 2-1 res: 1920x1080 dpi: 163
size: 300x260mm (11.81x10.24") diag: 397mm (15.63") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
2080/PCIe/SSE2 direct-render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: ASUSTeK driver: snd_hda_intel
bus-ID: 1-12.2:13 v: kernel alternate: snd_sof_pci_intel_tgl
chip-ID: 0414:a00c class-ID: 0300 bus-ID: 0000:00:1f.3 chip-ID: 8086:43c8
Device-2: NVIDIA TU104 HD Audio vendor: ZOTAC driver: snd_hda_intel
v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:10f8 class-ID: 0403
Device-3: NVIDIA GP107GL High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 0000:04:00.1 chip-ID: 10de:0fb9
Device-4: Giga-Byte ESS SABRE HiFi USB Audio Device type: USB
Device-5: Giga-Byte USB Audio type: USB driver: snd-usb-audio
bus-ID: 1-12.3:15 chip-ID: 0414:a008 class-ID: 0102 serial: <filter>
Device-6: Logitech HD Pro Webcam C920 type: USB
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api tools: N/A
bus-ID: 0000:00:14.3 chip-ID: 8086:43f0 class-ID: 0280
port: N/A bus-ID: 0000:07:00.0 chip-ID: 8086:15f3 class-ID: 0200
bus-ID: 1-14:14 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Device driver: intel_nvme_remap v: N/A port: 5020
bus-ID: 0000:00:17.0 chip-ID: 8086:43d6 rev: N/A class-ID: 0104
Local Storage: total: 19.35 TiB used: 5.19 GiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 37.9 C scheme: GPT
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: 233010WD temp: 28.9 C
scheme: MBR
ID-3: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 1000GB
size: 931.52 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SSD PLUS 1000GB
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: SanDisk model: SDSSDH3 512G
type: SSD serial: <filter> rev: 1000 scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 vendor: Silicon Power model: SPCC M.2 SSD
type: SSD serial: <filter> rev: 1B0 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: ASMedia
model: T ASM236X NVME size: 119.24 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> scheme: GPT
ID-8: /dev/sdf maj-min: 8:80 type: USB vendor: Seagate model: Expansion SW
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B type: N/A
serial: <filter> rev: 1801 scheme: GPT
ID-9: /dev/sdg maj-min: 8:96 type: USB vendor: Samsung
model: SSD 860 EVO 500GB size: 465.76 GiB block-size: physical: 512 B
logical: 512 B type: SSD serial: <filter> rev: TB08 scheme: GPT
ID-10: /dev/sdh maj-min: 8:112 type: USB vendor: Western Digital
model: WD40EFRX-68N32N0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: HDD rpm: 5400 serial: <filter> rev: 3004 scheme: GPT
ID-11: /dev/sdi maj-min: 8:128 type: USB vendor: Seagate
model: Backup+ Hub BK size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: N/A serial: <filter> rev: D781 scheme: GPT
ID-1: / raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
used: 5.16 GiB (4.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:8
used: 25.9 MiB (27.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:4
ID-3: /home raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
ID-4: /var/log raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
ID-5: /var/tmp raw-size: 117.19 GiB size: 117.19 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.18 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 384 Uptime: 4m wakeups: 3 Memory: 31.18 GiB used: 2.88 GiB (9.2%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 Packages: pm: pacman pkgs: 1184 libs: 320 tools: octopi,paru
inxi: 3.3.26
System install date:     2023-08-14
Last full system update: 2023-08-14
On a clean install now, I have not applied any updates. Below is the list of updates it wants to apply, if I do it will not finish the boot process: (5 attempts made, same list of updates according to diff). For now I will just not apply any updates. Is there another update tool I can use that will let select everything but the kernel updates? Pretty new to Linux / Garuda, I tried pacman, but the gui does not run if there is one.
Checking for updates...
a52dec 0.8.0-1 -> 0.8.0-2
aalib 1.4rc5-15 -> 1.4rc5-17
adwaita-cursors 43-2 -> 44.0-1
adwaita-icon-theme 43-2 -> 44.0-1
alsa-card-profiles 1:0.3.70-1 -> 1:0.3.77-2
alsa-lib 1.2.8-1 -> 1.2.9-1
alsa-ucm-conf 1.2.8-1 -> 1.2.9-1
android-udev 20230303-1 -> 20230614-1
aom 3.6.0-1 -> 3.6.1-1
ark 23.04.0-1 -> 23.04.3-1
at-spi2-core 2.48.0-2 -> 2.48.3-2
attica 5.105.0-1 -> 5.108.0-1
audit 3.1-1 -> 3.1.2-1
autorandr 1.13.3-1 -> 1.14-1
avahi 0.8+22+gfd482a7-3 -> 1:0.8+r22+gfd482a7-1
baloo 5.105.0-1 -> 5.108.0-1
baloo-widgets 23.04.0-1 -> 23.04.3-1
bash 5.1.016-3 -> 5.1.016-4
beautyline 1:20230402-1 -> 1:20230729-1
bind 9.18.14-1 -> 9.18.17-1
binutils 2.40-4 -> 2.41-3
bison 3.8.2-5 -> 3.8.2-6
bluedevil 1:5.27.4-1 -> 1:5.27.7-1
bluez 5.66-1 -> 5.68-1
bluez-hid2hci 5.66-1 -> 5.68-1
bluez-libs 5.66-1 -> 5.68-1
bluez-plugins 5.66-1 -> 5.68-1
bluez-qt 5.105.0-1 -> 5.108.0-1
bluez-utils 5.66-1 -> 5.68-1
boost-libs 1.81.0-3 -> 1.81.0-7
breeze 5.27.4-1 -> 5.27.7-1
breeze-icons 5.105.0-1 -> 5.108.0-1
brotli 1.0.9-10 -> 1.0.9-12
btrfs-assistant 1.8-1 -> 1.8-2
btrfs-progs 6.2.2-1 -> 6.3.3-1
ca-certificates-mozilla 3.89-1 -> 3.92-1
candy-icons-git r982.a017160-1 -> r1033.f78e4e7-1
chaotic-mirrorlist 20230424-1 -> 20230710-2
ckbcomp 1.219-1 -> 1.221-1
cpio 2.13-3 -> 2.14-1
curl 8.0.1-1 -> 8.2.1-1
dav1d 1.1.0-1 -> 1.2.1-1
dbus 1.14.6-2 -> 1.14.8-1
dbus-glib 0.112-2 -> 0.112-3
dbus-python 1.2.18-4 -> 1.3.2-2
device-mapper 2.03.21-1 -> 2.03.22-1
diffutils 3.9-1 -> 3.10-1
djvulibre 3.5.28-4 -> 3.5.28-5
dkms 3.0.10-1 -> 3.0.11-1
dolphin 23.04.0-3 -> 23.04.3-1
dolphin-plugins 23.04.0-1 -> 23.04.3-1
double-conversion 3.2.1-1 -> 3.3.0-1
dracut 056-2 -> 059-3
duktape 2.7.0-5 -> 2.7.0-6
egl-wayland 2:1.1.11-4 -> 2:1.1.12-1
enchant 2.3.4-1 -> 2.5.0-1
ethtool 1:6.2-1 -> 1:6.4-1
exa 0.10.1-7 -> 0.10.1-8
exfatprogs 1.2.0-1 -> 1.2.1-1
exiv2 0.27.6-1 -> 0.28.0-3
f2fs-tools 1.16.0-1 -> 1.16.0-2
fakeroot 1.31-2 -> 1.32.1-1
fastfetch 1.11.0-1 -> 1.12.2-1
ffmpeg 2:6.0-5 -> 2:6.0-8
ffmpegthumbs 23.04.0-1 -> 23.04.3-1
file 5.44-3 -> 5.45-1
firedragon 112.0.1-1 -> 116.0.2-1
firedragon-extension-plasma-integration 1.8.1-3.2 -> 1.8.1-3.4
firewalld 1.3.0-2 -> 2.0.0-1
flac 1.4.2-1 -> 1.4.3-1
fluidsynth 2.3.2-1 -> 2.3.3-1
frameworkintegration 5.105.0-1 -> 5.108.0-1
freetype2 2.13.0-1 -> 2.13.1-1
fribidi 1.0.12-1 -> 1.0.13-2
fuse-common 3.14.1-1 -> 3.16.1-1
fuse3 3.14.1-1 -> 3.16.1-1
fwupd 1.8.14-1 -> 1.9.3-1
fzf 0.39.0-1 -> 0.42.0-1
game-devices-udev 0.21-1 -> 0.22-0.2
garuda-bash-config 1.0.3-1 -> 1.0.4-1
garuda-dr460nized 3.0.2-1 -> 3.0.6-1
garuda-fish-config 1.5.12-1 -> 1.5.15-1
garuda-gamer 1.1.8-1 -> 1.1.9-1
garuda-libs 1.4.1-1 -> 1.4.2-1
garuda-migrations 2.3.1-1 -> 2.4.2-1
garuda-settings-manager 1.0.2-1 -> 1.0.2-3
garuda-settings-manager-kcm 1.0.2-1 -> 1.0.2-3
garuda-setup-assistant 3.1.10-1 -> 3.1.11-1
garuda-update 4.1.0-1 -> 4.2.2-1
garuda-wallpapers r85.f5daed8-1 -> r86.e1486a1-1
gawk 5.2.1-2 -> 5.2.2-1
gc 8.2.2-1 -> 8.2.4-1
gcab 1.5-1 -> 1.6-1
gcc 12.2.1-2 -> 13.2.1-3
gcc-libs 12.2.1-2 -> 13.2.1-3
geoip-database 20230414-1 -> 20230719-1
gettext 0.21.1-5 -> 0.22-1
ghostscript 10.01.1-1 -> 10.01.2-1
git 2.40.1-1 -> 2.41.0-2
glib-networking 1:2.76.0-1 -> 1:2.76.1-1
glib2 2.76.1-1 -> 2.76.4-1
glibc 2.37-2 -> 2.38-2
glslang 12.1.0-1 -> 12.3.1-2
gmp 6.2.1-2 -> 6.3.0-1
gnustep-base 1.29.0-1 -> 1.29.0-2
gobject-introspection 1.76.1-1 -> 1.76.1-3
gobject-introspection-runtime 1.76.1-1 -> 1.76.1-3
gperftools 2.10-1 -> 2.10-3
gpgme 1.20.0-1 -> 1.21.0-1
grep 3.10-1 -> 3.11-1
groff 1.22.4-10 -> 1.23.0-3
grub 2:2.06.r499.ge67a551a4-1 -> 2:2.12rc1-1
grub-btrfs 4.12-2 -> 4.13-1
gspell 1.12.1-1 -> 1.12.2-1
gst-libav 1.22.1-2 -> 1.22.5-1
gst-plugin-pipewire 1:0.3.70-1 -> 1:0.3.77-2
gst-plugins-bad 1.22.1-2 -> 1.22.5-1
gst-plugins-bad-libs 1.22.1-2 -> 1.22.5-1
gst-plugins-base 1.22.1-2 -> 1.22.5-1
gst-plugins-base-libs 1.22.1-2 -> 1.22.5-1
gst-plugins-good 1.22.1-2 -> 1.22.5-1
gst-plugins-ugly 1.22.1-2 -> 1.22.5-1
gstreamer 1.22.1-2 -> 1.22.5-1
gstreamer-vaapi 1.22.1-2 -> 1.22.5-1
gtk-update-icon-cache 1:4.10.3-1 -> 1:4.10.5-1
gtk3 1:3.24.37-1 -> 1:3.24.38-1
gtk4 1:4.10.3-1 -> 1:4.10.5-1
gupnp 1:1.6.3-1 -> 1:1.6.5-1
gwe 0.15.5-3.1 -> 0.15.5-3.5
harfbuzz 7.2.0-1 -> 8.1.1-1
harfbuzz-icu 7.2.0-1 -> 8.1.1-1
hblock 3.4.1-1 -> 3.4.2-1
hidapi 0.13.1-2 -> 0.14.0-1
highway 1.0.4-1 -> 1.0.6-1
hostapd 2.10-2 -> 2.10-3
hwdata 0.369-1 -> 0.372-1
hwinfo 22.2-2 -> 23.2-1
iana-etc 20230405-1 -> 20230629-1
icu 72.1-2 -> 73.2-2
imagemagick 7.1.1.8-1 -> 7.1.1.15-2
imath 3.1.7-1 -> 3.1.9-1
imlib2 1.11.0-1 -> 1.11.1-1
intel-ucode 20230214-1 -> 20230808-1
inxi 3.3.26.1-1 -> 3.3.28.1-1
iproute2 6.3.0-1 -> 6.4.0-1
iputils 20221126-1 -> 20221126-2
jemalloc 1:5.3.0-1 -> 1:5.3.0-2
kaccounts-integration 23.04.0-1 -> 23.04.3-1
kactivities 5.105.0-1 -> 5.108.0-1
kactivities-stats 5.105.0-1 -> 5.108.0-1
kactivitymanagerd 5.27.4-1 -> 5.27.7-1
karchive 5.105.0-1 -> 5.108.0-1
kate 23.04.0-1 -> 23.04.3-1
kauth 5.105.0-1 -> 5.108.0-1
kbd 2.5.1-1 -> 2.6.1-1
kbookmarks 5.105.0-1 -> 5.108.0-1
kcmutils 5.105.0-1 -> 5.108.0-1
kcodecs 5.105.0-1 -> 5.108.0-1
kcompletion 5.105.0-1 -> 5.108.0-1
kconfig 5.105.0-1 -> 5.108.0-1
kconfigwidgets 5.105.0-1 -> 5.108.0-1
kcontacts 1:5.105.0-1 -> 1:5.108.0-1
kcoreaddons 5.105.0-1 -> 5.108.0-1
kcrash 5.105.0-1 -> 5.108.0-1
kdbusaddons 5.105.0-1 -> 5.108.0-1
kde-cli-tools 5.27.4-1 -> 5.27.7-1
kde-gtk-config 5.27.4-1 -> 5.27.7-1
kde-servicemenus-rootactions 2.9.1-2.1 -> 2.9.1-2.3
kdeclarative 5.105.0-1 -> 5.108.0-1
kdeconnect 23.04.0-1 -> 23.04.3-1
kdecoration 5.27.4-1 -> 5.27.7-1
kded 5.105.0-1 -> 5.108.0-1
kdegraphics-mobipocket 23.04.0-1 -> 23.04.3-1
kdegraphics-thumbnailers 23.04.0-1 -> 23.04.3-1
kdelibs4support 5.105.0-1 -> 5.108.0-1
kdeplasma-addons 5.27.4-1 -> 5.27.7-1
kdesu 5.105.0-1 -> 5.108.0-1
kdialog 23.04.0-1 -> 23.04.3-1
kdnssd 5.105.0-1 -> 5.108.0-1
kemoticons 5.105.0-1 -> 5.108.0-1
kfilemetadata 5.105.0-1 -> 5.108.0-1
kglobalaccel 5.105.0-1 -> 5.108.0-1
kguiaddons 5.105.0-1 -> 5.108.0-1
kholidays 1:5.105.0-1 -> 1:5.108.0-1
khotkeys 5.27.4-1 -> 5.27.7-1
ki18n 5.105.0-1 -> 5.108.0-1
kiconthemes 5.105.0-1 -> 5.108.0-1
kidletime 5.105.0-1 -> 5.108.0-1
kimageformats 5.105.0-1 -> 5.108.0-1
kinfocenter 5.27.4-1 -> 5.27.7-1
kinit 5.105.0-1 -> 5.108.0-1
kio 5.105.0-1 -> 5.108.0-1
kio-extras 23.04.0-1 -> 23.04.3-1
kirigami-addons 0.8.0-1 -> 0.10.0-1
kirigami2 5.105.0-1 -> 5.108.0-1
kitemmodels 5.105.0-1 -> 5.108.0-1
kitemviews 5.105.0-1 -> 5.108.0-1
kjobwidgets 5.105.0-1 -> 5.108.0-1
kjs 5.105.0-1 -> 5.108.0-1
kmenuedit 5.27.4-1 -> 5.27.7-1
knewstuff 5.105.0-1 -> 5.108.0-1
knotifications 5.105.0-1 -> 5.108.0-1
knotifyconfig 5.105.0-1 -> 5.108.0-1
konsole 23.04.0-1 -> 23.04.3-1
kpackage 5.105.0-1 -> 5.108.0-1
kparts 5.105.0-1 -> 5.108.0-1
kpeople 5.105.0-1 -> 5.108.0-1
kpipewire 5.27.4-1 -> 5.27.7-1
kpmcore 23.04.0-1 -> 23.04.3-1
kpty 5.105.0-1 -> 5.108.0-1
kquickcharts 5.105.0-1 -> 5.108.0-1
krunner 5.105.0-1 -> 5.108.0-1
kscreen 5.27.4-1 -> 5.27.7-1
kscreenlocker 5.27.4-1 -> 5.27.7-1
kservice 5.105.0-1 -> 5.108.0-1
ksshaskpass 5.27.4-1 -> 5.27.7-1
ksystemstats 5.27.4-1 -> 5.27.7-1
ktexteditor 5.105.0-1 -> 5.108.0-1
ktextwidgets 5.105.0-1 -> 5.108.0-1
kunitconversion 5.105.0-1 -> 5.108.0-1
kwallet 5.105.0-1 -> 5.108.0-2
kwallet-pam 5.27.4-1 -> 5.27.7-1
kwayland 5.105.0-1 -> 5.108.0-1
kwayland-integration 5.27.4-1 -> 5.27.7-1
kwidgetsaddons 5.105.0-1 -> 5.108.0-1
kwin 5.27.4.1-1 -> 5.27.7-1
kwin-scripts-forceblur 0.6.1-1.1 -> 0.6.1-1.3
kwindowsystem 5.105.0-1 -> 5.108.0-1
kxmlgui 5.105.0-1 -> 5.108.0-1
layer-shell-qt 5.27.4-1 -> 5.27.7-1
ldb 2:2.7.2-1 -> 2:2.7.2-2
less 1:608-2 -> 1:633-1
lib32-alsa-lib 1.2.8-1 -> 1.2.9-1
lib32-brotli 1.0.9-5 -> 1.0.9-12
lib32-curl 8.0.1-1 -> 8.2.1-1
lib32-dbus 1.14.6-2 -> 1.14.8-1
lib32-freetype2 2.13.0-1 -> 2.13.1-1
lib32-fribidi 1.0.12-1 -> 1.0.13-2
lib32-gcc-libs 12.2.1-2 -> 13.2.1-3
lib32-glib2 2.76.1-1 -> 2.76.4-1
lib32-glibc 2.37-2 -> 2.38-2
lib32-harfbuzz 7.2.0-1 -> 8.1.1-1
lib32-icu 72.1-2 -> 73.2-1
lib32-libcap 2.68-1 -> 2.69-1
lib32-libldap 2.6.4-1 -> 2.6.6-1
lib32-libpipewire 1:0.3.70-1 -> 1:0.3.77-2
lib32-libpng 1.6.39-1 -> 1.6.40-2
lib32-libssh2 1.10.0-2 -> 1.11.0-1
lib32-libx11 1.8.4-1 -> 1.8.6-1
lib32-libxcrypt 4.4.33-1 -> 4.4.36-1
lib32-libxi 1.8-2 -> 1.8.1-1
lib32-libxml2 2.10.4-2 -> 2.11.5-1
lib32-llvm-libs 15.0.7-1 -> 15.0.7-3
lib32-mesa 23.0.3-1 -> 1:23.1.5-1
lib32-ncurses 6.4-1 -> 6.4_20230520-1
lib32-nvidia-utils 530.41.03-1 -> 535.98-1
lib32-ocl-icd 2.3.1-1 -> 2.3.2-1
lib32-opencl-nvidia 530.41.03-1 -> 535.98-1
lib32-openssl 1:3.0.8-1 -> 1:3.1.2-1
lib32-pam 1.5.2-1 -> 1.5.3-1
lib32-pipewire 1:0.3.70-1 -> 1:0.3.77-2
lib32-pipewire-jack 1:0.3.70-1 -> 1:0.3.77-2
lib32-systemd 253.3-1 -> 254.1-1
lib32-util-linux 2.38.1-1 -> 2.39.1-1
lib32-vulkan-icd-loader 1.3.245-1 -> 1.3.255-1
lib32-xz 5.4.2-1 -> 5.4.4-1
libaccounts-glib 1.26-1 -> 1.26-2
libadwaita 1:1.3.2-1 -> 1:1.3.4-1
libappindicator-gtk3 12.10.0.r298-1 -> 12.10.0.r298-2
libarchive 3.6.2-2 -> 3.7.1-1
libassuan 2.5.5-2 -> 2.5.6-1
libatasmart 0.19-5 -> 0.19-6
libavc1394 0.5.4-5 -> 0.5.4-6
libblockdev 2.28-1 -> 2.28-4
libbpf 1.1.0-1 -> 1.2.2-1
libbytesize 2.7-1 -> 2.8-2
libcaca 0.99.beta20-1 -> 0.99.beta20-2
libcamera 0.0.4-4 -> 0.1.0-1
libcamera-ipa 0.0.4-4 -> 0.1.0-1
libcap-ng 0.8.3-1 -> 0.8.3-2
libcdio-paranoia 10.2+2.0.1-2 -> 10.2+2.0.1-3
libcups 1:2.4.2-6 -> 1:2.4.6-1
libdatrie 0.2.13-2 -> 0.2.13-4
libdbusmenu-glib 16.04.0-5 -> 16.04.0.r498-1
libdbusmenu-gtk3 16.04.0-5 -> 16.04.0.r498-1
libdc1394 2.2.6-2 -> 2.2.7-1
libdca 0.0.7-1 -> 0.0.7-2
libde265 1.0.11-2 -> 1.0.12-1
libdv 1.0.0-10 -> 1.0.0-11
libdvdnav 6.1.1-1 -> 6.1.1-2
libdvdread 6.1.3-1 -> 6.1.3-2
libelf 0.189-1 -> 0.189-3
libepoxy 1.5.10-1 -> 1.5.10-2
libevdev 1.13.0-1 -> 1.13.1-1
libftdi 1.5-4 -> 1.5-5
libgirepository 1.76.1-1 -> 1.76.1-3
libgit2 1:1.6.4-1 -> 1:1.7.0-3
libgme 0.6.3-2 -> 0.6.3-4
libgudev 237-2 -> 238-1
libgusb 0.4.5-1 -> 0.4.6-1
libical 3.0.16-4 -> 3.0.16-5
libimagequant 4.1.1-1 -> 4.2.0-1
libimobiledevice 1.3.0-6 -> 1.3.0-9
libinih 56-1 -> 57-1
libinput_gestures_qt 0.3.2+7+g0868859-1.1 -> 0.3.2+7+g0868859-1.3
libjcat 0.1.13-2 -> 0.1.14-1
libjpeg-turbo 2.1.5.1-1 -> 3.0.0-1
libjxl 0.8.1-1 -> 0.8.2-1
libkdcraw 23.04.0-1 -> 23.04.3-1
libkexiv2 23.04.0-1 -> 23.04.3-1
libksba 1.6.3-1 -> 1.6.4-1
libkscreen 5.27.4-1 -> 5.27.7-1
libksysguard 5.27.4-1 -> 5.27.7-1
liblc3 1.0.2-1 -> 1.0.4-1
libldap 2.6.4-2 -> 2.6.6-1
libmanette 0.2.6-4 -> 0.2.6-5
libmd 1.0.4-1 -> 1.1.0-1
libmfx 23.1.6-1 -> 23.2.2-2
libmm-glib 1.20.6-1 -> 1.20.6-2
libmpcdec 1:0.1+r475-3 -> 1:0.1+r475-4
libmpeg2 0.5.1-7 -> 0.5.1-8
libnewt 0.52.23-1 -> 0.52.23-2
libnftnl 1.2.5-1 -> 1.2.6-1
libnghttp2 1.52.0-2 -> 1.55.1-1
libopenmpt 0.6.10-1 -> 0.7.2-1
libp11-kit 0.24.1-1 -> 0.25.0-1
libpaper 2.1.0-1 -> 2.1.1-1
libpgm 5.3.128-2 -> 5.3.128-3
libplacebo 5.229.2-2 -> 5.264.1-2
libplist 2.2.0-6 -> 2.3.0-2
libproxy 0.4.18-2 -> 0.5.3-2
libqalculate 4.6.1-1 -> 4.7.0-1
libraw 0.21.1-1 -> 0.21.1-2
librsvg 2:2.56.0-1 -> 2:2.56.3-1
libseccomp 2.5.4-1 -> 2.5.4-2
libsmbios 2.4.3-5 -> 2.4.3-6
libssh 0.10.4-3 -> 0.10.5-1
libssh2 1.10.0-3 -> 1.11.0-1
libsysprof-capture 3.48.0-1 -> 3.48.0-4
libteam 1.31-7 -> 1.31-8
libthai 0.1.29-2 -> 0.1.29-3
libtheora 1.1.1-5 -> 1.1.1-6
libtiff 4.5.0-3 -> 4.5.1-1
libtommath 1.2.0-3 -> 1.2.0-4
libtool 2.4.7+4+g1ec8fa28-2 -> 2.4.7+4+g1ec8fa28-6
libtraceevent 1:1.7.2-1 -> 1:1.7.3-1
libtracefs 1.6.4-2 -> 1.7.0-1
libusbmuxd 2.0.2-1 -> 2.0.2-3
libuv 1.44.2-1 -> 1.46.0-1
libva 2.18.0-1 -> 2.19.0-1
libva-utils 2.18.0-1 -> 2.19.0-1
libwacom 2.6.0-2 -> 2.7.0-1
libwbclient 4.18.2-1 -> 4.18.5-2
libwebp 1.3.0-2 -> 1.3.1-1
libxi 1.8-3 -> 1.8.1-1
libxnvctrl 530.41.03-1 -> 535.98-1
libxslt 1.1.37-2 -> 1.1.38-1
libzip 1.9.2-1 -> 1.10.0-1
licenses 20220125-2 -> 20230729-1
lilv 0.24.20-1 -> 0.24.20-2
linux-api-headers 6.1.9-1 -> 6.4-1
linux-firmware 20230404.2e92a49f-1 -> 20230804.7be2766d-2
linux-firmware-whence 20230404.2e92a49f-1 -> 20230804.7be2766d-2
linux-wifi-hotspot 4.4.0-1.1 -> 4.5.0-1
linux-zen 6.2.13.zen1-1 -> 6.4.10.zen2-1
linux-zen-headers 6.2.13.zen1-1 -> 6.4.10.zen2-1
lirc 1:0.10.2-2 -> 1:0.10.2-3
llvm-libs 15.0.7-2 -> 15.0.7-3
lsb-release 2.0.r48.3cf5103-1 -> 2.0.r53.a86f885-1
lua 5.4.4-4 -> 5.4.6-1
luajit 2.1.0.beta3.r471.g505e2c03-1 -> 2.1.0.beta3.r493.g8635cbab-1
lvm2 2.03.21-1 -> 2.03.22-1
mailcap 2.1.53-1 -> 2.1.54-1
memtest86+ 6.10-1 -> 6.20-1
mercurial 6.4.2-1 -> 6.5.1-1
mhwd-garuda-git r20.dc8eff1-2 -> r22.b935c24-1
milou 5.27.4-1 -> 5.27.7-1
minizip 1:1.2.13-2 -> 1:1.2.13-3
mjpegtools 2.2.1-1 -> 2.2.1-2
modemmanager 1.20.6-1 -> 1.20.6-2
modemmanager-qt 5.105.0-1 -> 5.108.0-1
mpfr 4.2.0-3 -> 4.2.0.p12-3
mpv 1:0.35.1-6 -> 1:0.36.0-1
neon 0.32.5-1 -> 0.32.5-2
nettle 3.8.1-1 -> 3.9.1-1
networkmanager-openconnect 1.2.8-2 -> 1.2.10-1
networkmanager-openvpn 1.10.2-1 -> 1.10.2-3
networkmanager-qt 5.105.0-1 -> 5.108.0-1
nftables 1:1.0.7-1 -> 1:1.0.8-2
nmap 7.93-1 -> 7.94-1
noto-fonts 20230501-1 -> 1:23.8.1-1
noto-fonts-cjk 20220126-1 -> 20220126-2
nss 3.89-1 -> 3.92-1
nvidia-dkms 530.41.03-1 -> 535.98-1
nvidia-settings 530.41.03-1 -> 535.98-1
oath-toolkit 2.6.7-1 -> 2.6.9-1
okular 23.04.0-1 -> 23.04.3-1
openconnect 1:9.01-2 -> 1:9.12-1
openexr 3.1.7-1 -> 3.1.10-1
openfortivpn 1.20.1-1 -> 1.20.5-1
openldap 2.6.4-2 -> 2.6.6-1
openmpi 4.1.5-1 -> 4.1.5-3
openpmix 4.2.3-2 -> 4.2.5-1
openresolv 3.13.1-1 -> 3.13.2-1
openssh 9.3p1-1 -> 9.4p1-2
openssl 3.0.8-1 -> 3.1.2-1
openvpn 2.6.3-1 -> 2.6.5-1
orc 0.4.33-1 -> 0.4.34-1
oxygen-sounds 5.27.4-1 -> 5.27.7-1
pace 1.4.2-1.1 -> 1.4.2-1.3
pacman 6.0.2-6 -> 6.0.2-7
pacman-contrib 1.9.0-1 -> 1.9.1-1
pacman-mirrorlist 20230410-1 -> 20230628-1
pahole 1:1.24+r29+g02d67c5-1 -> 1:1.25-4
pam 1.5.2-2 -> 1.5.3-3
partitionmanager 23.04.0-1 -> 23.04.3-1
patch 2.7.6-9 -> 2.7.6-10
pciutils 3.9.0-2 -> 3.10.0-1
pcsclite 1.9.9-3 -> 2.0.0-1
perl 5.36.0-3 -> 5.38.0-1
perl-clone 0.46-1 -> 0.46-2
perl-encode-locale 1.05-10 -> 1.05-11
perl-error 0.17029-4 -> 0.17029-5
perl-file-basedir 0.09-2 -> 0.09-3
perl-file-desktopentry 0.22-10 -> 0.22-11
perl-file-listing 6.15-2 -> 6.16-2
perl-file-mimeinfo 0.33-1 -> 0.33-2
perl-html-parser 3.81-1 -> 3.81-2
perl-html-tagset 3.20-13 -> 3.20-14
perl-http-cookies 6.10-3 -> 6.10-4
perl-http-daemon 6.16-1 -> 6.16-2
perl-http-date 6.05-6 -> 6.06-1
perl-http-message 6.44-1 -> 6.44-2
perl-http-negotiate 6.01-11 -> 6.01-12
perl-io-html 1.004-3 -> 1.004-4
perl-ipc-system-simple 1.30-4 -> 1.30-5
perl-libwww 6.67-1 -> 6.67-2
perl-lwp-mediatypes 6.04-3 -> 6.04-4
perl-mailtools 2.21-6 -> 2.21-7
perl-net-http 6.22-2 -> 6.23-2
perl-timedate 2.33-4 -> 2.33-5
perl-try-tiny 0.31-2 -> 0.31-3
perl-uri 5.17-1 -> 5.19-2
perl-www-robotrules 6.02-11 -> 6.02-12
perl-xml-parser 2.46-4 -> 2.46-5
perl-xml-writer 0.900-1 -> 0.900-2
pipewire-alsa 1:0.3.70-1 -> 1:0.3.77-2
pipewire-audio 1:0.3.70-1 -> 1:0.3.77-2
pipewire-pulse 1:0.3.70-1 -> 1:0.3.77-2
pipewire-v4l2 1:0.3.70-1 -> 1:0.3.77-2
pipewire-x11-bell 1:0.3.70-1 -> 1:0.3.77-2
pipewire-zeroconf 1:0.3.70-1 -> 1:0.3.77-2
plasma-browser-integration 5.27.4-1 -> 5.27.7-1
plasma-desktop 5.27.4-1 -> 5.27.7.1-1
plasma-firewall 5.27.4-1 -> 5.27.7-1
plasma-framework 5.105.0-1 -> 5.108.0-1
plasma-integration 5.27.4-1 -> 5.27.7-1
plasma-nm 5.27.4-1 -> 5.27.7-1
plasma-pa 5.27.4-1 -> 5.27.7-1
plasma-systemmonitor 5.27.4-1 -> 5.27.7-1
plasma-thunderbolt 5.27.4-1 -> 5.27.7-1
plasma-workspace 5.27.4.1-1 -> 5.27.7-2
plasma5-applets-eventcalendar 76-1.1 -> 76-1.3
plasma5-applets-window-appmenu 0.8.0-1.1 -> 0.8.0-1.3
plasma5-applets-window-title 0.7.1-2.1 -> 0.7.1-2.3
plymouth-git 22.02.122.r174.gf09cfea7-1 -> 22.02.122.r180.gb1d5aa9d-1
polkit 122-1 -> 123-1
polkit-kde-agent 5.27.4.1-1 -> 5.27.7-1
poppler 23.03.0-1 -> 23.07.0-1
poppler-qt5 23.03.0-1 -> 23.07.0-1
powerdevil 5.27.4.1-1 -> 5.27.7-1
prison 5.105.0-1 -> 5.108.0-1
procps-ng 3.3.17-1 -> 4.0.3-1
protobuf 21.12-1 -> 23.4-1
protobuf-c 1.4.1-1 -> 1.4.1-2
purpose 5.105.0-1 -> 5.108.0-1
python 3.10.10-1 -> 3.11.3-2
python-cairo 1.23.0-3 -> 1.24.0-1
python-capng 0.8.3-1 -> 0.8.3-2
python-chardet 5.1.0-1 -> 5.2.0-1
python-contourpy 1.0.7-1 -> 1.1.0-1
python-cycler 0.11.0-1 -> 0.11.0-3
python-dateutil 2.8.2-4 -> 2.8.2-5
python-fonttools 4.39.3-1 -> 4.42.0-1
python-gobject 3.44.1-1 -> 3.44.1-4
python-idna 3.4-1 -> 3.4-3
python-injector 0.20.1-2.1 -> 0.20.1-2.3
python-kiwisolver 1.4.4-2 -> 1.4.4-4
python-mako 1.2.4-1 -> 1.2.4-3
python-markdown 3.4.3-1 -> 3.4.4-1
python-markupsafe 2.1.2-1 -> 2.1.3-1
python-matplotlib 3.7.1-3 -> 3.7.2-1
python-numpy 1.24.3-1 -> 1.25.1-1
python-packaging 23.0-1 -> 23.1-1
python-peewee 3.16.2-1 -> 3.16.2-2
python-pillow 9.4.0-2 -> 10.0.0-2
python-py3nvml 0.2.7-1.1 -> 0.2.7-1.3
python-pyparsing 3.0.9-1 -> 3.0.9-3
python-pyqt5 5.15.9-1 -> 5.15.9-2
python-pyqt5-sip 12.12.1-1 -> 12.12.2-1
python-pyxdg 0.28-1 -> 0.28-2
python-requests 2.28.2-1 -> 2.28.2-4
python-rx 3.2.0-3 -> 3.2.0-4
python-six 1.16.0-6 -> 1.16.0-8
python-typing_extensions 4.5.0-1 -> 4.7.1-1
python-urllib3 1.26.13-1 -> 1.26.15-1
python-xlib 0.33-1 -> 0.33-2
qca-qt5 2.3.6-1 -> 2.3.7-1
qqc2-desktop-style 5.105.0-1 -> 5.108.0-1
qt5-base 5.15.9+kde+r151-1 -> 5.15.10+kde+r147-1
qt5-declarative 5.15.9+kde+r24-1 -> 5.15.10+kde+r29-1
qt5-graphicaleffects 5.15.9-1 -> 5.15.10-1
qt5-imageformats 5.15.9+kde+r9-1 -> 5.15.10+kde+r9-1
qt5-location 5.15.9+kde+r4-1 -> 5.15.10+kde+r4-2
qt5-multimedia 5.15.9+kde+r3-1 -> 5.15.10+kde+r3-1
qt5-quickcontrols 5.15.9-1 -> 5.15.10-1
qt5-quickcontrols2 5.15.9+kde+r5-1 -> 5.15.10+kde+r6-1
qt5-sensors 5.15.9-1 -> 5.15.10-1
qt5-speech 5.15.9+kde+r1-1 -> 5.15.10+kde+r1-1
qt5-svg 5.15.9+kde+r7-1 -> 5.15.10+kde+r8-1
qt5-tools 5.15.9+kde+r1-1 -> 5.15.10+kde+r3-1
qt5-translations 5.15.9-1 -> 5.15.10-1
qt5-wayland 5.15.9+kde+r55-1 -> 5.15.10+kde+r52-1
qt5-webchannel 5.15.9+kde+r3-1 -> 5.15.10+kde+r3-1
qt5-webengine 5.15.13-2 -> 5.15.14-4
qt5-x11extras 5.15.9-1 -> 5.15.10-1
qtermwidget 1.3.0-1 -> 1.3.0-2
raptor 2.0.16-2 -> 2.0.16-3
rate-mirrors 0.15.0-1 -> 0.16.4-1
rav1e 0.6.3-1 -> 0.6.6-1
reflector 2021.11-6 -> 2023-1
reflector-simple 2.0-1.1 -> 3.3-1
resvg 0.31.1-1 -> 0.35.0-1
rubberband 3.2.1-1 -> 3.3.0-1
sddm 0.19.0-9 -> 0.20.0-2
sddm-kcm 5.27.4.1-1 -> 5.27.7-1
sdl2 2.26.5-1 -> 2.28.2-1
shaderc 2023.3-1 -> 2023.4-1
signon-kwallet-extension 23.04.0-1 -> 23.04.3-1
smartmontools 7.3-1 -> 7.4-1
smbclient 4.18.2-1 -> 4.18.5-2
snapper 0.10.4-2 -> 0.10.5-1
snapper-support 1.1.2-2 -> 1.1.2-2.2
sof-firmware 2.2.4-1 -> 2.2.6-1
solid 5.105.0-1 -> 5.108.0-1
sonnet 5.105.0-1 -> 5.108.0-1
spandsp 0.0.6-4 -> 0.0.6-5
spectacle 23.04.0-1 -> 23.04.3-1
sqlite 3.41.2-1 -> 3.42.0-1
srt 1.5.1-3 -> 1.5.2-1
starship 1.14.2-1 -> 1.16.0-1
strongswan 5.9.9-1 -> 5.9.11-1
subversion 1.14.2-6 -> 1.14.2-9
sudo 1.9.13.p3-1 -> 1.9.14.p3-1
svt-av1 1.4.1-1 -> 1.6.0-1
sweet-kde-theme-git r25.41a9a69-1 -> r26.5fc01aa-1
sweet-theme-full-git r313.fb69198-1 -> r327.8bb5040-1
syndication 5.105.0-1 -> 5.108.0-1
syntax-highlighting 5.105.0-1 -> 5.108.0-1
systemd 253.3-3 -> 254.1-1
systemd-libs 253.3-3 -> 254.1-1
systemd-oomd-defaults 251.5-1.1 -> 253.5-1
systemd-sysvcompat 253.3-3 -> 254.1-1
systemsettings 5.27.4.1-1 -> 5.27.7-1
taglib 1.13-1 -> 1.13.1-1
talloc 2.4.0-2 -> 2.4.1-1
tar 1.34-2 -> 1.35-1
tdb 1.4.8-1 -> 1.4.9-1
tevent 1:0.14.1-1 -> 1:0.15.0-1
thin-provisioning-tools 1.0.4-1 -> 1.0.6-1
threadweaver 5.105.0-1 -> 5.108.0-1
tpm2-tss 3.2.0-3 -> 4.0.1-1
tracker3 3.5.1-1 -> 3.5.3-2
ttf-dejavu 2.37+18+g9b5d1b2f-3 -> 2.37+18+g9b5d1b2f-4
ttf-fantasque-nerd 3.0.0-1 -> 3.0.2-1
ttf-firacode-nerd 3.0.0-1 -> 3.0.2-1
ttf-hack 3.003-3 -> 3.003-6
tzdata 2023c-1 -> 2023c-2
udisks2 2.9.4-1 -> 2.9.4-4
unarchiver 1.10.7-8 -> 1.10.7-9
unrar 1:6.2.6-1 -> 1:6.2.10-1
update-grub 0.0.1-7.1 -> 0.0.1-8
upower 1.90.0-3 -> 1.90.2-1
usbmuxd 1.1.1-2 -> 1.1.1-3
usbutils 015-2 -> 015-3
util-linux 2.38.1-3 -> 2.39.1-1
util-linux-libs 2.38.1-3 -> 2.39.1-1
v4l-utils 1.24.1-1 -> 1.24.1-2
volume_key 0.3.12-7 -> 0.3.12-8
vulkan-tools 1.3.245-1 -> 1.3.255-1
wayland-protocols 1.31-1 -> 1.32-1
wayland-utils 1.1.0-1 -> 1.2.0-1
webkit2gtk 2.40.1-1 -> 2.40.5-1
webrtc-audio-processing 0.3.1-3 -> 0.3.1-4
wget 1.21.3-1 -> 1.21.4-1
whois 5.5.16-1 -> 5.5.18-1
wildmidi 0.4.5-1 -> 0.4.5-2
wireless-regdb 2023.02.13-1 -> 2023.05.03-1
xcb-proto 1.15.2-2 -> 1.15.2-3
xdg-dbus-proxy 0.1.4-1 -> 0.1.5-1
xdg-desktop-portal 1.16.0-2 -> 1.16.0-3
xdg-desktop-portal-kde 5.27.4.1-1 -> 5.27.7-1
xfsprogs 6.2.0-1 -> 6.4.0-1
xkeyboard-config 2.38-1 -> 2.39-1
xorg-server 21.1.8-1 -> 21.1.8-2
xorg-server-common 21.1.8-1 -> 21.1.8-2
xorg-setxkbmap 1.3.3-2 -> 1.3.4-1
xorg-xrdb 1.2.1-1 -> 1.2.2-1
xorg-xwayland 23.1.1-1 -> 23.1.2-1
xorgproto 2022.2-1 -> 2023.2-1
xsel 1.2.0.20200527-2 -> 1.2.1-1
xxhash 0.8.1-4 -> 0.8.2-1
yad 12.3-1 -> 13.0-1
zbar 0.23.90-1 -> 0.23.90-3
zeromq 4.3.4-2 -> 4.3.4-4
zimg 3.0.4-1 -> 3.0.5-1
zlib 1:1.2.13-2 -> 1:1.2.13-3
zxing-cpp 2.0.0-2 -> 2.1.0-1
Command finished OK!
Hi @bsilverthorn, we have recently had a few folks with a similar issue, which was resolved by booting into the UEFI/BIOS menu and setting the SATA controller to AHCI mode (sometimes it will default to being set to RAID or some other setting).
If you are dual-booting with Windows, it may be necessary to boot Windows once in recovery mode after making this change, so the AHCI driver can be downloaded.
Yes thank you, I checked that. I did update the bios a month back. It has been booting perfectly till now. It is still set at AHCI though darn it ;-).
It looks like we have two topics for this issue now. I will close this one down in favor of continuing the conversation in the other topic: Won't boot after latest updates
