Hello !
I installed garuda for the first time two month ago to try it.
but i want to remove it and back to windows, but the problem is i can't access the boot menu i pressed keys from F1 to F12 & del,Esc, End , nothing happend couldn't boot from the usb.
I tried to change garuda boot options but it didn't save the changes .
I'm not new to linux and still learning about it, it may be silly question but thanks in advance!
Kernel: 6.4.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=9f0aeda6-d708-4bfa-9d37-db4adab4ee08 rw rootflags=subvol=@
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Desktop Mobo: Gigabyte model: PA65-UD3-B3 serial: <superuser required>
BIOS: Award v: F6 date: 04/28/2011
Info: model: Intel Core i7-2600 bits: 64 type: MT MCP arch: Sandy Bridge
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 3524 high: 3800 min/max: 1600/3800 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3800 2: 3800 3: 1597
4: 3800 5: 3800 6: 3800 7: 3800 8: 3800 bogomips: 54281
Device-1: AMD Cedar [Radeon HD 5000/6000/7350/8350 Series] vendor: Hightech
Information System driver: radeon v: kernel alternate: amdgpu
arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm built: 2009-15
pcie: gen: 2 speed: 5 GT/s lanes: 16 ports: active: VGA-1
empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 1002:68f9 class-ID: 0300
temp: 58.5 C
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: gpu: radeon display-ID: 0
Monitor-1: VGA-1 model: Dell E1914H serial: <filter> built: 2014
res: 1366x768 dpi: 85 gamma: 1.2 size: 410x230mm (16.14x9.06")
diag: 470mm (18.5") ratio: 16:9 modes: max: 1366x768 min: 720x400
API: OpenGL v: 4.5 Mesa 23.1.3 renderer: AMD CEDAR (DRM 2.50.0 /
6.4.3-zen1-1-zen LLVM 15.0.7) direct-render: Yes
vendor: Gigabyte 6 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: AMD Cedar HDMI Audio [Radeon HD 5400/6300/7300 Series]
vendor: Hightech Information System driver: snd_hda_intel v: kernel pcie:
gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 1002:aa68
API: ALSA v: k6.4.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
Device-1: Ralink RT2561/RT61 802.11g PCI driver: rt61pci v: 2.3.0
bus-ID: 06:03.0 chip-ID: 1814:0301 class-ID: 0280
IF: wlp6s3 state: up mac: <filter>
lanes: 1 port: de00 bus-ID: 08:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-1: wlp7s0u1 state: up mac: <filter>
Local Storage: total: 988.82 GiB used: 84.89 GiB (8.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: USB 3.2Gen1
size: 57.3 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.1
spd: 480 Mb/s lanes: 1 mode: 2.0 speed: 3.0 Gb/s tech: N/A
serial: <filter> fw-rev: 1.00
model: WD10EARS-00MVWB0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
scheme: MBR
used: 80.41 GiB (8.6%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-1: swap-1 type: zram size: 7.74 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C mobo: N/A gpu: radeon temp: 58.5 C
Processes: 283 Uptime: 46m wakeups: 0 Memory: total: 8 GiB
available: 7.74 GiB used: 2.99 GiB (38.7%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages:
pm: pacman pkgs: 1365 libs: 463 tools: pamac,paru Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.28
System install date: 2023-06-17
Last full system update: 2023-07-14
Is partially upgraded: Yes
restarted to try garuda boot menu i pressed C to access grub nothings happened, giving me the login screen.
Thanks again.
