Blur not work
I am using garuda KDE Dragonized Gaming Edition, i am unable to enable blur effect while opening the window/apps, I am getting blur effect on live iso but after installation i don't get any blur background when i open any apps
Please follow the template.
Missing garuda-inxi
Did you check the settings, did you search upstream?
Kernel: 6.2.10-arch1-1 arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=d429b51a-57da-4784-a081-04260251835d rw [email protected]
loglevel=3 ibt=off
Type: Laptop System: LENOVO product: 80E5 v: Lenovo G50-80
serial: <superuser required> Chassis: type: 10 v: Lenovo G50-80
Mobo: LENOVO model: Lenovo G50-80 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: B0CN93WW date: 07/23/2015
ID-1: BAT0 charge: 17.6 Wh (96.7%) condition: 18.2/28.5 Wh (63.9%)
volts: 15.1 min: 14.4 model: Lenovo IdeaPad type: Unknown serial: <filter>
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1897 high: 1900 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1896 2: 1900 3: 1896
4: 1896 bogomips: 15969
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Bison Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 1-6:4
chip-ID: 5986:014f class-ID: 0e02
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: :0 screens: 1
s-diag: 414mm (16.31")
Monitor-1: eDP-1 mapped: eDP1 model: BOE Display 0x061d built: 2014
res: 1366x768 hz: 60 dpi: 102 gamma: 1.2 size: 340x190mm (13.39x7.48")
diag: 389mm (15.3") ratio: 16:9, 15:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.0.2 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
API: ALSA v: k6.2.10-arch1-1 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.68 status: active with: 1: pipewire-pulse
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b4 class-ID: 0280
IF: wlan0 state: down mac: <filter>
Device-3: Realtek RTL8188CUS 802.11n WLAN Adapter type: USB
driver: rtl8192cu bus-ID: 1-1:2 chip-ID: 0bda:8176 class-ID: 0000
IF: wlan1 state: up mac: <filter>
bus-ID: 1-7:5 chip-ID: 8087:07dc class-ID: e001
Local Storage: total: 223.57 GiB used: 79.1 GiB (35.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
type: SSD serial: <filter> rev: 0103 scheme: GPT
ID-1: / raw-size: 98.44 GiB size: 98.44 GiB (100.00%)
used: 78.91 GiB (80.2%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
used: 194.8 MiB (19.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 98.44 GiB size: 98.44 GiB (100.00%)
ID-4: /var/log raw-size: 98.44 GiB size: 98.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 98.44 GiB size: 98.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.75 GiB used: 195.2 MiB (5.1%)
ID-2: swap-2 type: partition size: 7.73 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda6 maj-min: 8:6
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 261 Uptime: 1m wakeups: 1 Memory: 3.75 GiB used: 2.52 GiB (67.4%)
Init: systemd v: 253 default: graphical tool: systemctl Compilers:
gcc: 12.2.1 clang: 15.0.7 Packages: pm: pacman pkgs: 2017 libs: 570
tools: octopi,paru,yay Shell: fish v: 3.6.1 default: Bash v: 5.1.16
System install date:     2023-02-17
Last full system update: 2023-04-13
Relevant software:       snapper(custom) NetworkManager mkinitcpio
"While" opening... you mean "after" the windows are opened the blur effect does not work?
