Bluetooth work on Garuda Xfce
Hello,
I activate on my notebook (Lenovo Thinkpad), the small Bluetooth icon appears in the bar.
In the Garuda settings, I click on the Bluetooth adapter.
and activate Bluetooth.
After about 5 seconds, the Bluetooth icon disappears.
The Garuda Bluetooth Manager cannot even be started.
So there is no chance of pairing with the Bluetooth mouse..
  Kernel: 5.15.79-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=8044bb41-5c2f-4a12-adca-63404e547740 rw rootflags=subvol=@
  Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: LENOVO product: 20KD001MMD v: ThinkPad A275
  Mobo: LENOVO model: 20KD001MMD serial: <superuser required> UEFI: LENOVO
    v: R0NET46W (1.24 ) date: 04/13/2021
  ID-1: BAT0 charge: 18.3 Wh (98.9%) condition: 18.5/23.2 Wh (79.7%)
    volts: 12.2 min: 11.1 model: SANYO 45N1773 type: Li-ion serial: <filter>
    status: not charging cycles: 23
  ID-2: BAT1 charge: 19.9 Wh (100.0%) condition: 19.9/23.5 Wh (84.6%)
    volts: 12.7 min: 11.4 model: LGC 45N1127 type: Li-ion serial: <filter>
    status: charging cycles: 48
  Info: model: AMD PRO A12-8830B R7 10 COMPUTE CORES 4C+6G bits: 64
    type: MT MCP arch: Excavator level: v3 note: check built: 2015
    process: GF 28nm family: 0x15 (21) model-id: 0x65 (101) stepping: 1
    microcode: 0x600611A
  Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 320 KiB
    desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
  Speed (MHz): avg: 2214 high: 2755 min/max: 1300/2500 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2166 2: 1416
    3: 2521 4: 2755 bogomips: 19962
    prctl and seccomp
  Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: Lenovo driver: amdgpu
    v: kernel arch: GCN-3 code: Volcanic Islands process: TSMC 28nm
    built: 2014-19 ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:01.0
    chip-ID: 1002:9874 class-ID: 0300
  Device-2: Chicony Integrated Camera type: USB driver: N/A bus-ID: 1-1.3:3
    chip-ID: 04f2:b5ab class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.4 compositor: xfwm v: 4.16.1 driver: X:
    loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x226d built: 2015
    res: 1920x1080 hz: 60 dpi: 177 gamma: 1.2 size: 276x155mm (10.87x6.1")
    diag: 317mm (12.5") ratio: 16:9 modes: max: 1920x1080 min: 640x480
    missing.
  Device-1: AMD Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
  Device-2: AMD Family 15h Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
  Sound API: ALSA v: k5.15.79-1-lts running: yes
  Sound Server-2: PipeWire v: 0.3.60 running: yes
    port: 1400 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp1s0f0 state: down mac: <filter>
    gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:24fd
    bus-ID: 1-1.4.2:6 chip-ID: 8087:0a2b class-ID: e001
  Local Storage: total: 476.94 GiB used: 104.73 GiB (22.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
    model: HFS512GD9TNG-L5B0B size: 476.94 GiB block-size: physical: 512 B
    rev: 80750C10 temp: 36.9 C scheme: GPT
  ID-1: / raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
    used: 52.27 GiB (21.9%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
    used: 26.5 MiB (27.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  ID-3: /home raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
  ID-4: /var/log raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
  ID-5: /var/tmp raw-size: 238.16 GiB size: 238.16 GiB (100.00%)
  ID-1: swap-1 type: zram size: 7.19 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 59.0 C mobo: 57.6 C gpu: amdgpu temp: 57.0 C
  Fan Speeds (RPM): fan-1: 4300
  Processes: 240 Uptime: 1h 44m wakeups: 3 Memory: 7.19 GiB
  used: 1.71 GiB (23.8%) Init: systemd v: 252 default: graphical
  tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1451
  libs: 393 tools: octopi,paru Shell: Bash v: 5.1.16
  running-in: xfce4-terminal inxi: 3.3.23
Garuda (2.6.9-1):
  System install date:     2022-11-17
  Last full system update: 2022-11-22
does bluetoothctl give you an output?
 bluetoothctl
Agent registered
[CHG] Controller 38:BA:F8:58:E6:B5 Class: 0x00000000
[CHG] Controller 38:BA:F8:58:E6:B5 Powered: no
[CHG] Controller 38:BA:F8:58:E6:B5 Discovering: no
[DEL] Media /org/bluez/hci0
	SupportedUUIDs: 0000110a-0000-1000-8000-00805f9b34fb
	SupportedUUIDs: 0000110b-0000-1000-8000-00805f9b34fb
[DEL] Controller 38:BA:F8:58:E6:B5 ralf-20kd001mmd [default]
If you dual boot with Windows make sure fast boot is disabled and bluetooth powersave is disabled in Windows.
If not working, try also disabling WiFi powersave in the Garuda Network Assistant and restart bluetooth
Sorry,
what do you mean with "Powersave" ?
Problem fixed!
I opened the Garuda Network Assistant.
There I could activate Bluetooth..
I tried to open the Garuda Bluetooth Manager
and it worked.
Now pairing is possible with my Bluetooth mouse.
Tjhank you for help.
Regards
Rallebiker
