Bluetooth volume on Gravastar Venus pair of speakers no longer changes in KDE after update. I used to be able to adjust volume via JamesDSP but that stopped working. I removed JamesDSP. Volume is either mute or 100%. It was also this way prior to the most recent updates.
I've tried to find references to absolute volume with no success in Pipewire config files.
I have not tried different bluetooth devices, I don't have any.
Regular wireless headphones, G933 volume needs to be near max to hear anything.
Yes I dual boot, sound works fine in Winders 10.
Kernel: 5.19.13-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=e1a6aef3-e2b1-422c-a112-f41b436462a8 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.25.5 tk: Qt v: 5.15.6 wm: kwin_x11 vt: 1
Type: Desktop System: Micro-Star product: MS-7C90 v: 1.0
Mobo: Micro-Star model: MPG B550 GAMING CARBON WIFI (MS-7C90) v: 1.0
serial: <superuser required> UEFI: American Megatrends LLC. v: 1.70
date: 06/25/2021
Device-1: ps-controller-battery-d0:bc:c1:cf:0a:0a model: N/A serial: N/A
charge: N/A status: full
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm)
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3684 high: 4097 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3592 2: 3644
3: 3621 4: 3665 5: 4097 6: 3684 7: 3699 8: 3700 9: 3598 10: 3663 11: 3653
12: 3595 bogomips: 88799
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Gigabyte driver: nvidia
v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 2b:00.0 chip-ID: 10de:2484 class-ID: 0300
Screen-1: 0 s-res: 3440x1440 s-dpi: 106 s-size: 824x352mm (32.44x13.86")
s-diag: 896mm (35.28")
Monitor-1: DP-2 res: 3440x1440 hz: 100 dpi: 107
size: 819x346mm (32.24x13.62") diag: 889mm (35") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA
515.76 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 1-4:3 v: kernel pcie: chip-ID: 046d:0a5b
gen: 4 class-ID: 0300 speed: 16 GT/s lanes: 16 bus-ID: 2b:00.1
bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech G933 Wireless Headset Dongle type: USB
Device-4: Sony DualSense wireless controller (PS5) type: USB
driver: playstation,snd-usb-audio,usbhid bus-ID: 3-2.4.1:5
chip-ID: 054c:0ce6 class-ID: 0300
Sound API: ALSA v: k5.19.13-zen1-1-zen running: yes
speed: 5 GT/s lanes: 1 bus-ID: 29:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169
v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 2a:00.0
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: Sony DualSense wireless controller (PS5) type: USB
bus-ID: 1-9:7 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 3.17 TiB used: 327.17 GiB (10.1%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Western Digital model: WD BLACK
SN770 1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: 731030WD
temp: 39.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Patriot model: Viper M.2 VPR100
size: 238.47 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: ECFM22.6
temp: 30.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Toshiba model: TR150 size: 447.13 GiB
serial: <filter> rev: 12.3 scheme: MBR
ID-4: /dev/sdb maj-min: 8:16 vendor: Silicon Power model: SPCC Solid
State Disk size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 8A0 scheme: MBR
ID-5: /dev/sdc maj-min: 8:32 vendor: AMD Radeon model: Radeon R7
type: SSD serial: <filter> rev: 1.01 scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 vendor: TeamGroup model: T-FORCE 500GB
type: SSD serial: <filter> rev: S6OA scheme: MBR
ID-7: /dev/sde maj-min: 8:64 type: USB vendor: ASUS model: ROG ESD-S1CL
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> scheme: GPT
ID-1: / raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 327.17 GiB
(35.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
(0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 327.17
GiB (35.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
ID-4: /var/log raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 327.17
ID-5: /var/tmp raw-size: 931.22 GiB size: 931.22 GiB (100.00%) used: 327.17
System Temperatures: cpu: 36.5 C mobo: N/A gpu: nvidia temp: 31 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 60%
Processes: 349 Uptime: 1m wakeups: 1 Memory: 15.55 GiB used: 3.6 GiB
(23.1%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1913
libs: 522 tools: octopi,pamac,paru,yay Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.22
Garuda (2.6.8-1):
System install date: 2022-07-04
Last full system update: 2022-10-09
Failed units:~~~
