Hello.
im having an interesting bug with bluetooth widget on plasmashell. steps to reproduce:
1)enable bluetooth and connect to anything (headphones in my case)
2)suspend to ram (via kde plasma menu, systemctl suspend or even echo mem > /sys/power/state, all works the same)
3)resume
bluetooth is enabled on resume, it even connects to my headphones automatically, but bluetooth tray widget doesnt show that. instead it says that "no devices found" (even tho it may enable and disable it) untill you restart plasmashell (i do pkill plasmashell; kstart5 plasmashell) then it works fine again. and in systemsettings app bluetooth works fine always.
so i either just use settings now or restart plasmashell every time. both ways are annoying so i just wonder if someone face this problem as well or there is a solution
i already tried lts kernel and disabled bluetooth-autoconnect.service. standalone widget (outside the tray, like on desktop) works the same way. any ideas to try?
*other locale settings warnings i dont care anyway*
Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a162ca6f-d8e8-47fb-89af-c723071373f9 rw rootflags=subvol=@
selinux=0 apparmor=0 nospectre_v2 l1tf=off no_stf_barrier
nospec_store_bypass_disable noibrs noibpb spectre_v2_user=off
transparent_hugepage=never elevator=cfq pcie_aspm=powersave
mitigations=off nopti=1 pti=off quiet rd.udev.log_priority=3
vt.global_cursor_default=0 loglevel=0 mitigations=off
sysrq_always_enabled=1
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: startx
Type: Laptop System: LENOVO product: 81LG v: Lenovo IdeaPad L340-15IWL
serial: <superuser required> Chassis: type: 10 v: Lenovo IdeaPad L340-15IWL
Mobo: LENOVO model: LNVNB161216 v: NO DPK serial: <superuser required>
UEFI: LENOVO v: ATCN45WW date: 05/17/2021
ID-1: BAT0 charge: 37.0 Wh (99.5%) condition: 37.2/36.0 Wh (103.5%)
volts: 12.7 min: 11.3 model: LGC L18L3PF1 type: Li-poly serial: <filter>
status: Full cycles: 648
Info: model: Intel Core i5-8265U bits: 64 type: MT MCP
arch: Comet/Whiskey Lake note: check family: 6 model-id: 0x8E (142)
stepping: 0xC (12) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1638 high: 3200 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 797 2: 800 3: 800 4: 800
5: 1434 6: 2211 7: 3067 8: 3200 bogomips: 28800
Type: itlb_multihit status: KVM: Vulnerable
Device-1: Intel WhiskeyLake-U GT2 [UHD Graphics 620] vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3ea0 class-ID: 0300
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-7:3 chip-ID: 13d3:5a08 class-ID: 0e02 serial: <filter>
Display: server: X.Org 1.21.1.3 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143
size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (WHL GT2)
v: 4.6 Mesa 21.3.5 direct render: Yes
Device-1: Intel Cannon Point-LP High Definition Audio vendor: Lenovo
chip-ID: 8086:9dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Device-1: Intel Cannon Point-LP CNVi [Wireless-AC] driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:9df0 class-ID: 0280
vendor: Lenovo driver: r8169 v: kernel port: 3000 bus-ID: 01:00.0
driver: btusb v: 0.8 bus-ID: 1-10:5 chip-ID: 8087:0aaa class-ID: e001
address: <filter>
Local Storage: total: 1.14 TiB used: 866.71 GiB (74.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix
model: HFM256GDHTNG-8310A size: 238.47 GiB block-size: physical: 512 B
rev: 80060C00 temp: 35.9 C scheme: MBR
model: WDS500G2B0A-00SM50 size: 465.76 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 30WD
scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 4C scheme: GPT
ID-1: / raw-size: 39.8 GiB size: 39.8 GiB (100.00%) used: 19.04 GiB (47.9%)
fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 6.9 MiB (1.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 39.8 GiB size: 39.8 GiB (100.00%)
used: 19.04 GiB (47.9%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-4: /var/log raw-size: 39.8 GiB size: 39.8 GiB (100.00%)
ID-5: /var/tmp raw-size: 39.8 GiB size: 39.8 GiB (100.00%)
ID-1: swap-1 type: zram size: 19.42 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 38.0 C pch: 37.0 C mobo: N/A
Processes: 282 Uptime: 26m wakeups: 7892 Memory: 19.42 GiB
used: 8.32 GiB (42.8%) Init: systemd v: 250 target: multi-user.target
tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1432
lib: 367 Shell: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-11
Last full system update: 2022-02-12
btw why i dont like to restart plasmashell is 'cause it causes dolphin to crash, especially if there is a copying process. another issue i would like to solve.
