Greetings everyone,
I have been using Garuda for some time now and a while ago I started to have issues with the Bluetooth in Garuda, I posted the issue on the forum and despite great efforts from the community my problem remained unsolved. I thought it was because of my dual boot with Windows so I recently formatted my SSD and reinstalled Garuda only. However, the problem persists. The Bluetooth is initially usable using the solution by using this solution to my post but the fix isn’t permanent and the Bluetooth suddenly stops working and starts saying “Adapter not found”. Below I have also attached this happening when using bluetoothctl.
Output of garuda-inxi:
Kernel: 6.7.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b3f7625d-2e45-4e53-ad78-5d24ccaa13a5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.10 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-ec0xxx v: N/A
Mobo: HP model: 86D5 v: 96.45 serial: <filter> part-nu: 169P5PA#ACJ
uuid: 30444335-3433-4e47-445a-842afd0e3d89 UEFI: AMI v: F.17
date: 03/16/2023
ID-1: BAT0 charge: 14.0 Wh (35.4%) condition: 39.5/39.5 Wh (100.0%)
power: 36.4 W volts: 12.6 min: 11.6 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: charging cycles: 355
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx socket: FP5
bits: 64 type: MT MCP arch: Zen/Zen+ note: check gen: 1 level: v3
note: check built: 2019 process: GF 12nm family: 0x17 (23)
model-id: 0x18 (24) stepping: 1 microcode: 0x8108109
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1487 high: 2100 min/max: 1400/2100 boost: enabled
base/boost: 2100/3700 scaling: driver: acpi-cpufreq governor: schedutil
volts: 1.2 V ext-clock: 100 MHz cores: 1: 1400 2: 1400 3: 1400 4: 2100
5: 1400 6: 1400 7: 1400 8: 1400 bogomips: 33536
Device-1: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 545.29.06
2024-02; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none empty: HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel arch: GCN-5 code: Vega
ports: active: eDP-1 empty: HDMI-A-2 bus-ID: 05:00.0 chip-ID: 1002:15d8
class-ID: 0300 temp: 60.0 C
Device-3: Quanta HP TrueVision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 0408:5365
class-ID: 0e02
Display: server: X.Org v: 23.2.4 with: Xwayland v: 23.2.4
gpu: amdgpu display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1515 built: 2019 res: 1920x1080
hz: 60 dpi: 143 gamma: 1.2 size: 340x190mm (13.39x7.48") diag: 394mm (15.5")
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 23.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon Vega 8 Graphics
(radeonsi raven LLVM 16.0.6 DRM 3.57 6.7.4-zen1-1-zen)
device-ID: 1002:15d8 memory: 1.95 GiB unified: no
API: Vulkan v: 1.3.276 layers: 4 device: 0 type: integrated-gpu name: AMD
Radeon Vega 8 Graphics (RADV RAVEN) driver: mesa radv v: 23.3.5-arch1.1
device-ID: 1002:15d8 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 545.29.06
device-ID: 10de:1f91 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.3.5-arch1.1 (LLVM
Device-1: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 05:00.5
API: ALSA v: k6.7.4-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.3 status: n/a (root, process) with:
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
vendor: Hewlett-Packard RTL8111/8168/8411 driver: r8169 v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 04:00.0
Local Storage: total: 1.14 TiB used: 350.92 GiB (30.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Gigabyte
model: GP-GSM2NE3256GNTD size: 238.47 GiB block-size: physical: 512 B
fw-rev: EDFM20.0 temp: 24.9 C scheme: GPT
SMART: yes health: PASSED on: 335d 14h cycles: 6,765
read-units: 38,659,654 [19.7 TB] written-units: 43,901,660 [22.4 TB]
model: WD10SPZX-60Z10T0 family: Blue Mobile (SMR) size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B sata: 3.1 speed: 6.0 Gb/s
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1A04 temp: 26 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 338d 3h cycles: 6761 Old-Age:
g-sense error rate: 5437
ID-1: / raw-size: 70 GiB size: 70 GiB (100.00%) used: 11.82 GiB (16.9%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 167.97 GiB size: 167.97 GiB (100.00%)
used: 18.84 GiB (11.2%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p3
maj-min: 259:3
ID-4: /var/log raw-size: 70 GiB size: 70 GiB (100.00%)
used: 11.82 GiB (16.9%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p2
maj-min: 259:2
ID-5: /var/tmp raw-size: 70 GiB size: 70 GiB (100.00%)
maj-min: 259:2
ID-1: swap-1 type: zram size: 5.66 GiB used: 4.45 GiB (78.6%)
System Temperatures: cpu: 58.5 C mobo: N/A gpu: amdgpu temp: 58.0 C
Fan Speeds (rpm): fan-1: 0 fan-2: 0
Memory: total: 6 GiB available: 5.66 GiB used: 4.53 GiB (80.0%)
Processes: 364 Power: uptime: 4h 20m states: freeze,mem,disk suspend: deep
avail: s2idle wakeups: 1 fails: 1 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 2.22 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1338 libs: 378 tools: octopi,pamac,paru
Compilers: gcc: 13.2.1 Shell: garuda-inxi (sudo) default: Bash v: 5.2.26
Garuda (2.6.23-1):
System install date: 2024-02-13
Last full system update: 2024-02-15
bluetoothctl
Waiting to connect to bluetoothd...[bluetooth]# Agent registered
[bluetooth]# scan on
[bluetooth]# SetDiscoveryFilter success
[bluetooth]# list
Controller 28:CD:C4:C7:35:3A garuda-linux [default]
[bluetooth]# Failed to start discovery: org.bluez.Error.InProgress
[bluetooth]# devices
Device 30:63:71:7F:80:34 itel N33
[bluet30:63:71:7F:80:343:71:7F:80:34
[bluetooth]# Changing 30:63:71:7F:80:34 trust succeeded
[blue30:63:71:7F:80:343:71:7F:80:34
Attempting to pair with 30:63:71:7F:80:34
[bluetooth]# Failed to pair: org.bluez.Error.AlreadyExists
[bluetoo30:63:71:7F:80:343:71:7F:80:34
Attempting to connect to 30:63:71:7F:80:34
[bluetooth]# connect 30:63:71:7F:80:34
[bluetooth]# Failed to connect: org.bluez.Error.InProgress br-connection-busy
[bluetooth]# hci0 class of device changed: 0x000000
[bluetooth]# hci0 new_settings: bondable ssp br/edr le secure-conn
[bluetooth]# [CHG] Controller 28:CD:C4:C7:35:3A Class: 0x00000000 (0)
[bluetooth]# Failed to connect: org.bluez.Error.Failed br-connection-aborted-by-local
[bluetooth]# [CHG] Controller 28:CD:C4:C7:35:3A Powered: no
[bluetooth]# [CHG] Controller 28:CD:C4:C7:35:3A Discovering: no
[bluetooth]# hci0 removed
[bluetooth]# [DEL] Device 30:63:71:7F:80:34 itel N33
[bluetooth]# [DEL] Media /org/bluez/hci0
[bluetooth]# SupportedUUIDs: 0000110a-0000-1000-8000-00805f9b34fb
[bluetooth]# SupportedUUIDs: 0000110b-0000-1000-8000-00805f9b34fb
[bluetooth]# [DEL] Controller 28:CD:C4:C7:35:3A garuda-linux [default]
connectoth]# connect 30:63:71:7F:80:34
No default controller available
[bluetooth]#
Any help would be appreciated. Thanks in advance to all![]()
