Bluetooth stopped working
Hello,
After disconnecting my minipc and then reconnecting the bluetooth stopped working. It does not recognise any devices I have previously paired nor does the scan pick up anything.
I tested the LTS kernel - no difference.
I upgraded the wifi card from AX200 to AX210. No difference.
systemctl status bluetooth
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Fri 2024-12-27 23:23:38 AEDT; 9min ago
Invocation: 1decf428cd5e4b03bd65dd72ac86f7f8
Docs: man:bluetoothd(8)
Main PID: 806 (bluetoothd)
Status: β€œRunning”
Tasks: 1 (limit: 33239)
Memory: 3.3M (peak: 4M)
CPU: 34ms
CGroup: /system.slice/bluetooth.service
└─806 /usr/lib/bluetooth/bluetoothd
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/faststream
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/faststream_duplex
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSink/opus_05
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/opus_05
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSink/opus_05_duplex
Dec 27 23:23:47 Vampa bluetoothd[806]: Endpoint registered: sender=:1.41 path=/MediaEndpoint/A2DPSource/opus_05_duplex
bluetoothctl
[bluetooth]# Agent registered
[bluetooth]# list
Controller BC:38:98:A8:AC:54 Vampa [default]
[bluetooth]# devices
[bluetooth]#
lsmod | grep btusb
btusb 81920 0
btrtl 32768 1 btusb
btintel 69632 1 btusb
btbcm 24576 1 btusb
btmtk 36864 1 btusb
bluetooth 1150976 46 btrtl,btmtk,btintel,btbcm,bnep,btusb,rfcomm
lsusb
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 413c:2113 Dell Computer Corp. KB216 Wired Keyboard
Bus 001 Device 003: ID 413c:301a Dell Computer Corp. Dell MS116 Optical Mouse
Bus 001 Device 004: ID 8087:0032 Intel Corp. AX210 Bluetooth
  Kernel: 6.12.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=1de1715e-056d-4625-af40-7d9d204c0313 rw rootflags=subvol=@
    quiet resume=UUID=85270526-26c6-4f0e-a046-7af1687bcffc loglevel=3 ibt=off
  Type: Mini-pc Mobo: AZW model: SER8 v: V10 serial: <superuser required>
    part-nu: 75 uuid: <superuser required> UEFI: American Megatrends LLC.
    v: SER8_P5C8V27 date: 06/13/2024
  Info: model: AMD Ryzen 7 8845HS w/ Radeon 780M Graphics bits: 64
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
    microcode: 0xA705206
  Speed (MHz): avg: 1329 min/max: 400/5137 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1329 2: 1329 3: 1329
    4: 1329 5: 1329 6: 1329 7: 1329 8: 1329 9: 1329 10: 1329 11: 1329 12: 1329
    13: 1329 14: 1329 15: 1329 16: 1329 bogomips: 121368
  Device-1: Advanced Micro Devices [AMD/ATI] Phoenix3 driver: amdgpu v: kernel
    arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm) built: 2023+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1 empty: DP-2, DP-3, DP-4,
    DP-5, DP-6, HDMI-A-1, Writeback-1 bus-ID: c5:00.0 chip-ID: 1002:1900
    class-ID: 0300 temp: 39.0 C
  Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.4
    s-diag: 1165mm (45.88") monitors: <missing: xrandr>
  Monitor-1: DP-1 model: LG (GoldStar) HDR 4K serial: <filter> built: 2024
    res: 3840x2160 dpi: 163 gamma: 1.2 size: 600x340mm (23.62x13.39")
    diag: 690mm (27.2") ratio: 16:9 modes: max: 3840x2160 min: 640x480
    device: 1 drv: swrast gbm: drv: kms_swrast surfaceless: drv: radeonsi x11:
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.3.2-arch1.1
    gfx1103_r1 LLVM 18.1.8 DRM 3.59 6.12.6-zen1-1-zen) device-ID: 1002:1900
    memory: 3.91 GiB unified: no
  API: Vulkan v: 1.4.303 layers: 4 device: 0 type: integrated-gpu name: AMD
    Radeon Graphics (RADV GFX1103_R1) driver: N/A device-ID: 1002:1900
    surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256
  Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
    Audio driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: c5:00.1 chip-ID: 1002:1640 class-ID: 0403
    bus-ID: c5:00.5 chip-ID: 1022:15e2 class-ID: 0480
    bus-ID: c5:00.6 chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.12.6-zen1-1-zen status: kernel-api tools: N/A
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 03:00.0
  IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-5:4 chip-ID: 8087:0032
    lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c0104
  Local Storage: total: 3.64 TiB used: 1.35 TiB (37.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:1 vendor: Crucial model: CT2000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40D temp: 40.9 C
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Crucial model: CT2000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40D temp: 41.9 C
  ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 670.41 GiB (36.6%)
    fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
    used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:2
    used: 670.41 GiB (36.6%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:3
  ID-1: swap-1 type: partition size: 29.9 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:4
  ID-2: swap-2 type: zram size: 27.18 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 48.0 C mobo: 39.5 C gpu: amdgpu temp: 38.0 C
  Memory: total: 28 GiB available: 27.18 GiB used: 5.52 GiB (20.3%)
  Processes: 473 Power: uptime: 4m states: freeze,mem,disk suspend: s2idle
    image: 10.86 GiB services: org_kde_powerdevil,upowerd Init: systemd v: 257
  Packages: pm: pacman pkgs: 1577 libs: 440 tools: octopi,paru Compilers:
    clang: 18.1.8 gcc: 14.2.1 alt: 9 Shell: garuda-inxi default: Bash v: 5.2.37
  System install date:     2024-12-03
  Last full system update: 2024-12-27 ↻
hmmm, now typing from my bluetooth keyboard!
I am not sure what fixed it!!
The mouse was stupid slow in becoming discovered!
Another related question though:
How to have the bluetooth keyboard be recognised straight up on startup?
I cannot get connection to use the grub menu. I have to wait about 15 seconds to be able to type my login also!
Hi there @Anarchotaoist.
You should be able to easily find this information by reading the entry on the Arch wiki regarding Bluetooth. This topic has also been discussed numerous times on the Garuda forum.
Thanks but no success.
https://wiki.archlinux.org/title/Bluetooth
3.3 Discoverable on startup
-did not work
I also tried:
https://forum.xfce.org/viewtopic.php?id=12419
-did not work either!
That said, in /etc/systemd/system/btkbd.service do I need to change ${HCIDEVICE} and ${BTKBDMAC} to the actual address here?
ExecStart=/usr/local/sbin/hciconfig ${HCIDEVICE} up
# ignore errors on connect, spurious problems with bt? so start next command with -
ExecStart=-/usr/local/bin/hcitool cc ${BTKBDMAC}
