Hello Garuda users.
When I login after reboot the Bluetooth speaker connects automatically. However after about 2 minutes idle the speaker disconnects. I connect the speaker again, and it disconnects after 20 minutes idle thereafter. I figure this is designed behavior, and I'm hoping the design includes other options.
I can see this interaction between devices using btmon
. For example, here is a disconnection finishing:
Status: Success (0x00)
Handle: 256 Address: 54:15:89:07:49:A4 (MCS Logic Inc.)
Reason: Remote User Terminated Connection (0x13)
@ MGMT Event: Device Disconnected (0x000c) plen 8 {0x0001} [hci0] 1706.248898
BR/EDR Address: 54:15:89:07:49:A4 (MCS Logic Inc.)
Reason: Connection terminated by remote host (0x03)
< HCI Command: Write Scan Enable (0x03|0x001a) plen 1 #160 [hci0] 1706.272656
Scan enable: Page Scan (0x02)
> HCI Event: Command Complete (0x0e) plen 4 #161 [hci0] 1706.274528
It looks like a "request to disconnect" from the speaker. I should be able to respond in the negative, is that correct?
I think previously I had used an HDMI connection to the speaker to avoid this issue, although my recollection is hazy.
I've spent a few hours searching around but haven't found the info I need to even create a sufficient search.
-- mickleby
Complete disconnection dialog:
L2CAP: Disconnection Response (0x07) ident 13 len 4
Destination CID: 2546
Source CID: 67
^[> ACL Data RX: Handle 256 flags 0x02 dlen 12 #144 [hci0] 1706.065802
L2CAP: Disconnection Request (0x06) ident 169 len 4
Destination CID: 68
Source CID: 2547
> ACL Data RX: Handle 256 flags 0x02 dlen 7 #145 [hci0] 1706.065810
Channel: 64 len 3 [PSM 25 mode Basic (0x00)] {chan 1}
AVDTP: Close (0x08) Command (0x00) type 0x00 label 0 nosp 0
ACP SEID: 7
< ACL Data TX: Handle 256 flags 0x00 dlen 12 #146 [hci0] 1706.066010
L2CAP: Disconnection Response (0x07) ident 169 len 4
Destination CID: 68
Source CID: 2547
< ACL Data TX: Handle 256 flags 0x00 dlen 6 #147 [hci0] 1706.066380
Channel: 2544 len 2 [PSM 25 mode Basic (0x00)] {chan 1}
AVDTP: Close (0x08) Response Accept (0x02) type 0x00 label 0 nosp 0
> HCI Event: Number of Completed Packets (0x13) plen 5 #148 [hci0] 1706.069535
Num handles: 1
Count: 1
> HCI Event: Number of Completed Packets (0x13) plen 5 #149 [hci0] 1706.071491
Num handles: 1
Count: 1
> ACL Data RX: Handle 256 flags 0x02 dlen 12 #150 [hci0] 1706.074598
L2CAP: Disconnection Request (0x06) ident 170 len 4
Destination CID: 66
Source CID: 2545
> ACL Data RX: Handle 256 flags 0x02 dlen 12 #151 [hci0] 1706.074600
L2CAP: Disconnection Request (0x06) ident 171 len 4
Destination CID: 64
Source CID: 2544
< ACL Data TX: Handle 256 flags 0x00 dlen 12 #152 [hci0] 1706.074674
L2CAP: Disconnection Response (0x07) ident 170 len 4
Destination CID: 66
Source CID: 2545
< ACL Data TX: Handle 256 flags 0x00 dlen 12 #153 [hci0] 1706.074690
L2CAP: Disconnection Response (0x07) ident 171 len 4
Destination CID: 64
Source CID: 2544
> HCI Event: Number of Completed Packets (0x13) plen 5 #154 [hci0] 1706.078487
Num handles: 1
Count: 1
> HCI Event: Number of Completed Packets (0x13) plen 5 #155 [hci0] 1706.080466
Num handles: 1
Count: 1
> ACL Data RX: Handle 256 flags 0x02 dlen 12 #156 [hci0] 1706.084618
L2CAP: Disconnection Request (0x06) ident 172 len 4
Destination CID: 65
Source CID: 2543
< ACL Data TX: Handle 256 flags 0x00 dlen 12 #157 [hci0] 1706.084659
L2CAP: Disconnection Response (0x07) ident 172 len 4
Destination CID: 65
Source CID: 2543
> HCI Event: Number of Completed Packets (0x13) plen 5 #158 [hci0] 1706.088463
Num handles: 1
Count: 1
> HCI Event: Disconnect Complete (0x05) plen 4 #159 [hci0] 1706.248681
Inxi:
╰─λ sudo garuda-inxi
[sudo] password for mickleby:
Kernel: 6.2.11-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=7ce7773f-cf24-4ed4-92fd-61d4b91d7a28 rw [email protected]
Desktop: Qtile v: 0.22.1 wm: LG3D dm: SDDM Distro: Garuda Linux
Type: Desktop System: AZW product: SEi v: N/A serial: N/A
Mobo: AZW model: SEi serial: N/A UEFI: American Megatrends LLC.
v: ALDER109 date: 12/01/2022
Device-1: hidpp_battery_0 model: Logitech Illuminated Living-Room Keyboard
K830 serial: <filter> charge: 100% (should be ignored) rechargeable: yes
Info: model: 12th Gen Intel Core i5-1235U socket: U3E1 bits: 64
type: MST AMCP arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x429
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 2353 high: 2500 min/max: 400/4400:3300
base/boost: 1188/4400 scaling: driver: intel_pstate governor: powersave
volts: 0.7 V ext-clock: 100 MHz cores: 1: 2500 2: 2500 3: 740 4: 2500
5: 2500 6: 2500 7: 2500 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500
bogomips: 59904
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics] driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: HDMI-A-1
empty: HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46a8 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-c4107
driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris
Screen-1: 0 s-res: 1360x768 s-dpi: 96 s-size: 358x202mm (14.09x7.95")
s-diag: 411mm (16.18")
Monitor-1: HDMI-A-1 mapped: HDMI-1 model: LG (GoldStar) TV
serial: <filter> built: 2012 res: 1360x768 hz: 60 dpi: 216 gamma: 1.2
size: 160x90mm (6.3x3.54") diag: 1836mm (72.3") ratio: 16:9 modes:
missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio driver: snd_hda_intel
chip-ID: 8086:51c8 class-ID: 0403
API: ALSA v: k6.2.11-zen1-1-zen status: kernel-api tools: alsamixer,amixer
Server-1: PipeWire v: 0.3.69 status: n/a (root, process) with:
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 3-10:3 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 535.41 GiB used: 11.1 GiB (2.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2400 MTFDKBA512QFM
lanes: 4 type: SSD serial: <filter> rev: V3MA002 temp: 31.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: PNY model: USB 3.0 FD
size: 58.47 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> scheme: MBR
ID-1: / raw-size: 38.67 GiB size: 38.67 GiB (100.00%)
used: 11.07 GiB (28.6%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p5
maj-min: 259:5
used: 34.7 MiB (36.2%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 38.67 GiB size: 38.67 GiB (100.00%)
maj-min: 259:5
ID-4: /var/log raw-size: 38.67 GiB size: 38.67 GiB (100.00%)
maj-min: 259:5
ID-5: /var/tmp raw-size: 38.67 GiB size: 38.67 GiB (100.00%)
maj-min: 259:5
ID-1: swap-1 type: zram size: 15.39 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 30.0 C mobo: N/A
Processes: 303 Uptime: 14m wakeups: 8 Memory: 15.39 GiB
used: 2.99 GiB (19.4%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1187
libs: 326 tools: pamac,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.26
System install date: 2023-04-11
Last full system update: 2023-04-16
Windows dual boot: Yes
╭─[email protected] in ~ via v3.10.10 as 🧙 took 8s
╰─λ
