Hello.
so i recently came across this post in community where someone appreciated the sudden increase in the sound quality maybe due to drivers. i asked him if he did something specific with the driver (maybe update it) or maybe he just ran "sudo update" and Naman told me to open a topic.
so here's the issue. I usually am in the same room as my laptop when wearing my wireless headphones. my headphones are boult flex q12. not much known but maybe if it helps.
so while i dont notice it much, but when i do leave the room, the audio starts to stutter, and i disconnect after a step or two.
i switched my room so i initially thought maybe its the walls. i recently was on windows (playing games) and went to the next room and realised that the audio doesnt depreciate until about 10-15 steps or more. i have not installed any special drivers in windows for my headphones.
Any help is appreciated.
╰─λ inxi -Faz
System: Kernel: 5.14.14-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=873c951f-daf4-4fad-aecc-0961323840e3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Micro-Star product: GF63 Thin 10SC v: REV:1.0 serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16R5 v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E16R5IMS.104 date: 08/30/2021
Battery: ID-1: BAT1 charge: 34.1 Wh (69.2%) condition: 49.3/51.3 Wh (96.0%) volts: 12.5 min: 11.4
model: MSI BIF0_9 type: Li-ion serial: N/A status: Charging
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 3727 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 3727 2: 4265 3: 3742 4: 4472
5: 4339 6: 4484 7: 4469 8: 3333 9: 4312 10: 4486 11: 3384 12: 4500
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Micro-Star MSI driver: nvidia
v: 470.74 alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:1f9d class-ID: 0302
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.14-zen1-1-zen running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
chip-ID: 8087:0026 class-ID: e001
Drives: Local Storage: total: 1.14 TiB used: 279.13 GiB (23.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3256B-AI1 size: 238.47 GiB
rev: EDFK0S03 temp: 44.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
serial: <filter> rev: 0001 scheme: GPT
Partition: ID-1: / raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 34.19 GiB (34.2%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%) used: 27.9 MiB (9.4%) fs: vfat
ID-3: /home raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 34.19 GiB (34.2%) fs: btrfs
ID-4: /var/log raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 34.19 GiB (34.2%)
ID-5: /var/tmp raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 34.19 GiB (34.2%)
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 62.0 C mobo: N/A
Info: Processes: 378 Uptime: 1h 44m wakeups: 1 Memory: 7.59 GiB used: 5.94 GiB (78.3%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1572 lib: 488
