Bluetooth problem
Kernel: 6.3.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=647e731d-2d7b-4d32-bb3e-73141eaf0bc1 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: HP product: HP Notebook v: Type1ProductConfigId
Mobo: HP model: 81F0 v: 63.21 serial: <superuser required> UEFI: Insyde
v: F.44 date: 08/07/2018
ID-1: BAT1 charge: 21.5 Wh (66.0%) condition: 32.6/32.6 Wh (100.0%)
volts: 16.0 min: 14.8 model: COMPAL PABAS0241231 type: Li-ion
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1893 high: 1900 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 1900 2: 1900 3: 1900
4: 1874 bogomips: 15963
Device-1: Intel HD Graphics 5500 vendor: Hewlett-Packard driver: i915
v: kernel arch: Gen-8 process: Intel 14nm built: 2014-15 ports:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 M430 Radeon
520 Mobile] vendor: Hewlett-Packard driver: radeon v: kernel
alternate: amdgpu arch: GCN-1 code: Southern Islands process: TSMC 28nm
built: 2011-20 pcie: gen: 2 speed: 5 GT/s lanes: 4 link-max: gen: 3
speed: 8 GT/s lanes: 8 bus-ID: 0d:00.0 chip-ID: 1002:6660 class-ID: 0380
temp: 41.0 C
Device-3: Chicony HP TrueVision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-5:3 chip-ID: 04f2:b56c
compositor: kwin_x11 driver: X: loaded: modesetting,radeon
alternate: fbdev,intel,vesa dri: iris,radeonsi gpu: i915 display-ID: :0
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: AU Optronics 0x70ec built: 2015 res: 1366x768
hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.1 renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c
chip-ID: 8086:9ca0 class-ID: 0403
API: ALSA v: k6.3.4-zen1-1-zen status: kernel-api with: aoss
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 5000
bus-ID: 07:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 13:00.0 chip-ID: 14e4:4365 class-ID: 0280
IF: wlp19s0 state: up mac: <filter>
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:2 chip-ID: 0a5c:216d
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address: N/A
Local Storage: total: 1.14 TiB used: 16.63 GiB (1.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010A9E680
tech: HDD rpm: 5400 serial: <filter> fw-rev: A7G0 scheme: MBR
used: 16.63 GiB (7.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.0 C pch: 45.0 C mobo: N/A gpu: radeon
temp: 41.0 C
Processes: 191 Uptime: 19m wakeups: 1 Memory: available: 7.67 GiB
used: 2.54 GiB (33.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1805
libs: 520 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date:     2023-05-16
Last full system update: 2023-05-28
My bluetooth is not showing previously it was working with windows now i click the bluetooth icon it simply shows no adaptors available please help !!!! I changed the kernels also but it doesnt help
Hi there, welcome to the forum!
I think you could try this:
Thank u
Rather than posting"Thank you", “+1” or “Agreed”, use the Like (heart) button. Please.
