Bluetooth doesn’t work on my Garuda Hyprland, I tried various things and found out that my adapter is not being detected so it’s not working .
The following are the things i tried:
- Tried to see if the adapter is recognized or not through bluetoothctl
bluetoothctl
[bluetooth]# Agent registered
[bluetooth]# list
[bluetooth]# devices
No default controller available
[bluetooth]#
- Checked if bluetooth is blocked or not using rfkill list
rfkill list
0: acer-wireless: Wireless LAN
Soft blocked: no
Hard blocked: no
1: acer-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
3: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
- Already installed bluez, blueman and bluez-utils and setup.
- Enabled and started bluetooth service using
sudo systemctl enable bluetooth
sudo systemctl start bluetooth
- Running
sudo systemctl status bluetooth
gives
[sudo] password for incog:
● bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; preset: disabled)
Active: active (running) since Sun 2025-02-23 19:01:36 +0545; 14h ago
Invocation: 559ff77d1b65450bb62b1c746a3f224c
Docs: man:bluetoothd(8)
Main PID: 870 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 18696)
Memory: 2.1M (peak: 2.6M)
CPU: 34ms
CGroup: /system.slice/bluetooth.service
└─870 /usr/lib/bluetooth/bluetoothd
Feb 23 19:01:36 Incog bluetoothd[870]: src/plugin.c:init_plugin() System does not support bap plugin
Feb 23 19:01:36 Incog bluetoothd[870]: src/plugin.c:init_plugin() System does not support bass plugin
Feb 23 19:01:36 Incog bluetoothd[870]: src/plugin.c:init_plugin() System does not support mcp plugin
Feb 23 19:01:36 Incog bluetoothd[870]: src/plugin.c:init_plugin() System does not support vcp plugin
Feb 23 19:01:36 Incog bluetoothd[870]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Feb 23 19:01:36 Incog bluetoothd[870]: src/plugin.c:init_plugin() System does not support micp plugin
Feb 23 19:01:36 Incog bluetoothd[870]: src/plugin.c:init_plugin() System does not support ccp plugin
Feb 23 19:01:36 Incog bluetoothd[870]: src/plugin.c:init_plugin() System does not support csip plugin
Feb 23 19:01:36 Incog bluetoothd[870]: src/plugin.c:init_plugin() System does not support asha plugin
Feb 23 19:01:36 Incog bluetoothd[870]: Bluetooth management interface 1.23 initialized
- Running
gives
Kernel: 6.13.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=c5f2a093-3549-46be-913c-cbe25862b213 rw rootflags=subvol=@
Desktop: Hyprland v: 0.47.2 with: waybar tools: hypridle avail: hyprlock
vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Laptop System: Acer product: Aspire A315-59 v: V1.16
Mobo: ADL model: Callisto_ADU v: V1.16 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.16
date: 08/16/2022
ID-1: BAT1 charge: 22.6 Wh (60.6%) condition: 37.3/41.6 Wh (89.7%)
volts: 11.4 min: 11.2 model: LGC AP19B8K type: Li-ion serial: <filter>
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x436
Topology: cpus: 1x dies: 1 clusters: 4 cores: 10 threads: 12 mt: 2 tpc: 2
st: 8 smt: enabled cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32
KiB, 8x64 KiB L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 654 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 654 2: 654 3: 654 4: 654 5: 654 6: 654 7: 654
8: 654 9: 654 10: 654 11: 654 12: 654 bogomips: 59904
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics]
vendor: Acer Incorporated ALI driver: i915 v: kernel alternate: xe arch: Xe
process: Intel 10nm built: 2021-22+ ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0000:00:02.0 chip-ID: 8086:46a8
Device-2: Chicony ACER HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:2 chip-ID: 04f2:b773
compositor: Hyprland v: 0.47.2 driver: X: loaded: modesetting unloaded: vesa
alternate: fbdev,intel dri: iris gpu: i915 display-ID: 1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2016 res:
size: 340x190mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.3.4-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (ADL
GT2) device-ID: 8086:46a8 memory: 7.48 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 5 device: 0 type: integrated-gpu name: Intel
Iris Xe Graphics (ADL GT2) driver: N/A device-ID: 8086:46a8
de: kscreen-console,kscreen-doctor wl: kanshi, nwg-displays, way-displays,
wayland-info, wdisplays, wlr-randr x11: xdriinfo, xdpyinfo, xprop, xrandr
vendor: Acer Incorporated ALI driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel, snd_soc_avs, snd_sof_pci_intel_tgl
bus-ID: 0000:00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.13.3-zen1-1-zen status: kernel-api
Device-1: MEDIATEK MT7663 802.11ac PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7615e v: kernel bus-ID: 0000:2a:00.0
chip-ID: 14c3:7663 class-ID: 0280
IF: wlp42s0 state: up mac: <filter>
Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-10:3 chip-ID: 04ca:3801
Report: hciconfig ID: hci0 rfk-id: 3 state: down
address: <filter>
Info: acl-mtu: 0:0 sco-mtu: 0:0 link-mode: peripheral accept
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 476.94 GiB used: 147.67 GiB (31.0%)
fw-rev: FXM7301Q temp: 17.9 C scheme: GPT
ID-1: / raw-size: 127 GiB size: 127 GiB (100.00%) used: 79.29 GiB (62.4%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:5
used: 27.6 MiB (28.7%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 127 GiB size: 127 GiB (100.00%)
used: 79.29 GiB (62.4%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:5
ID-4: /var/log raw-size: 127 GiB size: 127 GiB (100.00%)
ID-5: /var/tmp raw-size: 127 GiB size: 127 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.33 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 30.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.33 GiB used: 4.75 GiB (31.0%)
Processes: 381 Power: uptime: 14h 39m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 3 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.12 GiB services: upowerd
Packages: 1919 pm: pacman pkgs: 1910 libs: 505
tools: octopi,pacseek,paru,yay pm: flatpak pkgs: 9 Compilers: gcc: 14.2.1
Shell: garuda-inxi default: Zsh v: 5.9 running-in: kitty inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2025-01-26
Last full system update: 2025-02-24 ↻
Relevant software: snapper(custom) NetworkManager dracut
- Tried using other kernels like Linux-LTS , Linux , Linux-mainline but doesn’t work on either of them.
- Bluetooth works perfectly in Windows .
- Also tried cold booting the system multiple times
- On live booted Arconet Linux, bluetooth works perfectly fine but bluetooth doesn’t work on live booted Garuda Hyprland.
