I have fresh install garuda Linux and wifi is working but bluetooth is not working . I am having rtl8821ce wifi/bluetooth Driver on my laptop. List of device were showing up but when in connect I don't work it just shows protocol not found. I have install rtl8821ce-dkms-git from AUR but it also not work.
Install/reinstall pulseaudio-bluetooth
(sudo pacman -Syu pulseaudio-bluetooth
), reboot, try again, let us know the result.
I have already tired it but it won't work
Are you using Pulseaudio or Pipewire?
So there are things that God does not know.
Ok, no religion, maybe it is not a good nick?
Pulseaudio
Yes I am a starter
OK, then there should be no issue and it should work.
Make sure you are fully up-to-date, remove and re-add the pairing, and then try and find some logs to tell us more (e.g. dmesg output from the time you are trying to connect). Read this for more information:
Ok Thanks, I would Update
Having just recently moved Garuda Dr460nized onto metal, I was looking at the forum and stumbled across this thread and thought to myself...oh, that's something I need to do!.. as it turns out jonathons' advise works.
Did you try
It is is similar problem I guess
