Hi everyone.
this is the output of inxi -Fxxxza of my two pc's with garuda linux:
╭─eliuzhc@nuc10i5fnk in ~ took 3s
╰─λ garuda-inxi
Kernel: 6.4.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=96afba2a-048d-4726-b3cb-1838add5f6f8 rw rootflags=subvol=@
quiet rd.udev.log_priority=3 vt.global_cursor_default=0
resume=UUID=b8d8d854-ce3f-4d0d-b914-20e2633523ac loglevel=3 ibt=off
Desktop: GNOME v: 44.3 tk: GTK v: 3.24.38 wm: gnome-shell dm: GDM v: 44.1
Type: Mini-pc System: Intel Client Systems product: NUC10i5FNK v: K61339-306
serial: <superuser required> Chassis: Intel Corporation type: 35 v: 2.0
Mobo: Intel model: NUC10i5FNB v: K61361-305 serial: <superuser required>
UEFI: Intel v: FNCML357.0046.2020.0928.1457 date: 09/28/2020
Info: model: Intel Core i5-10210U bits: 64 type: MT MCP
stepping: 0xC (12) microcode: 0xF6
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3127 high: 4200 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 4200 2: 2100 3: 2100
4: 4121 5: 4141 6: 4158 7: 2100 8: 2100 bogomips: 33599
Device-1: Intel CometLake-U GT2 [UHD Graphics] driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: DP-2
empty: DP-1,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:9b41 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.8 with: Xwayland v: 23.1.2
compositor: gnome-shell driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa dri: i965 gpu: i915 display-ID: 0
Monitor-1: DP-2 model: AOC 2770 serial: <filter> built: 2018
res: 1920x1080 dpi: 82 gamma: 1.2 size: 598x336mm (23.54x13.23")
diag: 686mm (27") ratio: 16:9 modes: max: 1920x1080 min: 720x400
Message: No known Wayland EGL/GBM data sources. API: EGL/GBM
Device-1: Intel Comet Lake PCH-LP cAVS driver: snd_hda_intel v: kernel
chip-ID: 8086:02c8 class-ID: 0403
API: ALSA v: k6.4.4-zen1-1-zen status: kernel-api tools: N/A
Server-1: JACK v: 1.9.22 status: off tools: N/A
Server-2: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH-LP CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:02f0 class-ID: 0280
IF: wlp0s20f3 state: down mac: <filter>
Device-2: Intel Ethernet I219-V driver: e1000e v: kernel port: N/A
bus-ID: 00:1f.6 chip-ID: 8086:0d4f class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
Local Storage: total: 465.76 GiB used: 143.66 GiB (30.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT500P2SSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P2CR012 temp: 36.9 C
ID-1: / raw-size: 448.63 GiB size: 448.63 GiB (100.00%)
used: 143.66 GiB (32.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 448.63 GiB size: 448.63 GiB (100.00%)
ID-4: /var/log raw-size: 448.63 GiB size: 448.63 GiB (100.00%)
ID-5: /var/tmp raw-size: 448.63 GiB size: 448.63 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.34 GiB used: 1024 KiB (0.0%)
ID-2: swap-2 type: partition size: 16.88 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 46.0 C pch: 38.0 C mobo: N/A
Processes: 299 Uptime: 52m wakeups: 2 Memory: total: 16 GiB note: est.
available: 15.34 GiB used: 5.1 GiB (33.3%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7
Packages: pm: pacman pkgs: 2047 libs: 463 tools: pamac,paru,yaourt
Shell: fish v: 3.6.1 running-in: guake inxi: 3.3.28
System install date: 2021-05-28
Last full system update: 2023-07-24
Relevant software: timeshift NetworkManager mkinitcpio
and
╭─eliuzhc@summite15 in ~ took 2s
╰─λ garuda-inxi
root=UUID=52b01107-189b-46eb-96c3-9ef5db58f1b2 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=1 loglevel=3 resume=/dev/nvme0n1p3
Type: Laptop System: Micro-Star product: Summit E15 A11SCS v: REV:1.0
Mobo: Micro-Star model: MS-16S6 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: E16S6IMS.315 date: 08/03/2021
ID-1: BAT1 charge: 39.7 Wh (73.8%) condition: 53.8/80.3 Wh (67.0%)
volts: 15.5 min: 15.2 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
microcode: 0xAA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1860 high: 3771 min/max: 400/4800 scaling:
driver: intel_pstate governor: powersave cores: 1: 1430 2: 3000 3: 474
4: 849 5: 3771 6: 1959 7: 401 8: 3000 bogomips: 47923
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:9a49 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile]
vendor: Micro-Star MSI driver: nvidia v: 535.86.05
alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-07) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 5a:00.0
chip-ID: 10de:1f95 class-ID: 0302
Device-3: Bison HD Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:4 chip-ID: 5986:2127
compositor: gnome-shell driver: X: loaded: intel,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: i965 gpu: i915
display-ID: 0
Monitor-1: eDP-1 model: BOE Display 0x08f3 built: 2019 res: 3840x2160
dpi: 279 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 398mm (15.7")
ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel Xe Graphics (TGL GT2)
direct-render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Micro-Star MSI
chip-ID: 8086:a0c8 class-ID: 0401
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0026
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 3.0
lmp-v: 5.2 sub-v: 2090 hci-v: 5.2 rev: 2090
Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, object
transfer, audio, telephony
Local Storage: total: 1.84 TiB used: 532.6 GiB (28.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Phison
model: 1TB SM2801T24GKBB4S-E162 size: 953.87 GiB block-size: physical: 512 B
fw-rev: EGFM11.3 temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 31.9 C scheme: MBR
ID-1: / raw-size: 919.41 GiB size: 919.41 GiB (100.00%)
used: 532.6 GiB (57.9%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 919.41 GiB size: 919.41 GiB (100.00%)
ID-4: /var/log raw-size: 919.41 GiB size: 919.41 GiB (100.00%)
ID-5: /var/tmp raw-size: 919.41 GiB size: 919.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.16 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 60.0 C mobo: N/A
Processes: 329 Uptime: 41m wakeups: 8410 Memory: total: 32 GiB note: est.
available: 31.05 GiB used: 8.99 GiB (28.9%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 alt: 12
clang: 15.0.7 Packages: 1874 pm: pacman pkgs: 1865 libs: 496
tools: pamac,paru pm: rpm pkgs: 4 pm: flatpak pkgs: 5 Shell: fish v: 3.6.1
default: Bash v: 5.1.16 running-in: guake inxi: 3.3.28
System install date: 2021-07-27
Last full system update: 2023-07-23
Relevant software: timeshift NetworkManager mkinitcpio nvidia-dkms
Failed units: shadow.service systemd-remount-fs.service
It's about one month since after an upgrade bluetooth le stopped working on my Intel nuc10i5 and on my msi summit e15. I noticed that because after an upgrade my Logitec mx anywhere 3 stopped working.
Theese two pc's have the intel ax201 as wireless card as shown in the inxi output, in can be related to some new driver issues or with some problem with bluez? Does anyone have the same problem? Please help me, there is nothing on the internet about this apart from a few posts where they talk about problems with bluez 5.63 and 5.64 and logitec mx anywhere 3 and all the bluetooth 4.0 LE devices like this. Thanks in advance for the reply.
