Bluetooth issues past 6.17.5
I rolled back and pinned
IgnorePkg = linux-zen linux-zen-headers
Seems like more regressions in the bluetooth stack crept in. Last update, speakers stopped working. I rolled back the kernel packages and I’m good again. Just an FYI. Last time this happened the regressions didn’t get fixed til the next kernel version.
  Kernel: 6.17.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=0e693b7d-0009-41fd-85f6-1281c3eb5b91 rw rootflags=subvol=@ quiet
    rd.luks.uuid=b09f133e-4cee-496f-816a-bf169e7cfdf5 loglevel=3
    video=DP-3:1920x1080@60 nvidia-drm.modeset=1 modprobe.blacklist=amdgpu
  Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
  Type: Desktop Mobo: System76 model: Thelio Spark v: thelio-spark-r2
    serial: <filter> part-nu: SKU uuid: 290929a2-571e-23d5-5910-60cf847584d7
    UEFI: American Megatrends v: 3057 date: 10/29/2024
  Message: No system battery data found. Is one present?
Memory:
  System RAM: total: 64 GiB available: 62.43 GiB used: 8.33 GiB (13.3%)
  Array-1: capacity: 128 GiB slots: 4 modules: 2 EC: None
    max-module-size: 32 GiB note: est.
  Device-1: Channel-A DIMM 0 type: no module installed
  Device-2: Channel-A DIMM 1 type: DDR5 detail: synchronous unbuffered
    (unregistered) size: 32 GiB speed: 4800 MT/s volts: curr: 1.1 min: 1.1
    max: 1.1 width (bits): data: 64 total: 64 manufacturer: Crucial Technology
    part-no: CT32G48C40U5.C16A1 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Device-4: Channel-B DIMM 1 type: DDR5 detail: synchronous unbuffered
  Info: model: AMD Ryzen 7 8700G w/ Radeon 780M Graphics socket: AM5 bits: 64
    process: TSMC n5 (5nm) family: 0x19 (25) model-id: 0x75 (117) stepping: 2
    microcode: 0xA705208
  Speed (MHz): avg: 2404 min/max: 423/5177 boost: enabled
    base/boost: 4200/5150 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.2 V ext-clock: 100 MHz cores: 1: 2404 2: 2404 3: 2404 4: 2404
    5: 2404 6: 2404 7: 2404 8: 2404 9: 2404 10: 2404 11: 2404 12: 2404 13: 2404
    14: 2404 15: 2404 16: 2404 bogomips: 134388
  Flags: 3dnowprefetch abm adx aes amd_lbr_v2 aperfmperf apic arat avic avx
    avx2 avx512_bf16 avx512_bitalg avx512_vbmi2 avx512_vnni avx512_vpopcntdq
    avx512bw avx512cd avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1
    bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
    constant_tsc cpb cppc cpuid cpuid_fault cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe msr mtrr
    mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw overflow_recov pae pat
    pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
    perfmon_v2 pfthreshold pge pku pni popcnt pse pse36 rapl rdpid rdpru
    rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
    sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
    topoext tsc tsc_scale umip user_shstk v_spec_ctrl vaes vgif vmcb_clean vme
    vmmcall vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec
    xsaveerptr xsaveopt xsaves xtopology
  Type: gather_data_sampling status: Not affected
  Type: ghostwrite status: Not affected
  Type: indirect_target_selection status: Not affected
  Type: old_microcode status: Not affected
  Type: reg_file_data_sampling status: Not affected
  Type: spec_rstack_overflow mitigation: Safe RET
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not affected
  Type: tsa mitigation: Clear CPU buffers
  Type: vmscape mitigation: IBPB before exit to userspace
  Device-1: NVIDIA AD106 [GeForce RTX 4060 Ti] vendor: ZOTAC driver: nvidia
    v: 580.95.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: current (as of 2025-08) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
    ports: active: DP-3 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0
    chip-ID: 10de:2803 class-ID: 0300
  Device-2: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8.1:6
    chip-ID: 046d:0843 class-ID: 0102 serial: <filter>
  Display: unspecified server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
    s-diag: 583mm (22.95")
  Monitor-1: DP-3 model: ASUS PA279 serial: <filter> built: 2021 res:
    mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
    max: 3840x2160 min: 640x480
    inactive: wayland,device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060 Ti/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.4.328 layers: 12 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4060 Ti driver: nvidia v: 580.95.05 device-ID: 10de:2803
    surfaces: N/A device: 1 type: cpu name: llvmpipe (LLVM 21.1.4 256 bits)
    driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM 21.1.4) device-ID: 10005:0000
    surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl, nvidia-settings, nvidia-smi
  Device-1: NVIDIA AD106M High Definition Audio vendor: ZOTAC
    bus-ID: 01:00.1 chip-ID: 10de:22bd class-ID: 0403
    lanes: 16 bus-ID: 0b:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-3: Logitech Webcam C930e driver: snd-usb-audio,uvcvideo type: USB
  API: ALSA v: k6.17.5-zen1-1-zen status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.9 status: n/a (root, process) with:
    vendor: ASUSTeK RTL8111H driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e000 bus-ID: 07:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IP v4: <filter> type: dynamic noprefixroute scope: global
    broadcast: <filter>
  IP v6: <filter> type: noprefixroute scope: link
  Device-2: Realtek RTL8851BE PCIe 802.11ax Wireless Network vendor: Foxconn
    driver: rtw89_8851be v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 08:00.0 chip-ID: 10ec:b851 class-ID: 0280
  IF-ID-1: br-3edafb3ff64e state: down mac: <filter>
  IP v4: <filter> scope: global broadcast: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Info: services: NetworkManager, sshd, systemd-timesyncd, wpa_supplicant
  WAN IP: <filter>
  Device-1: TP-Link Bluetooth USB Adapter driver: btusb v: 0.8 type: USB
    rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1:2 chip-ID: 2357:0604
    lmp-v: 10 status: discoverable: no pairing: yes class-ID: 6c0104
Logical:
  Message: No logical block device data found.
  Device-1: luks-b09f133e-4cee-496f-816a-bf169e7cfdf5 maj-min: 253:0
    type: LUKS dm: dm-0 size: 1.86 TiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:2 size: 1.86 TiB
  Message: No RAID data found.
  Local Storage: total: 2.32 TiB used: 1.59 TiB (68.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK51.2 temp: 54.9 C
  SMART: yes health: PASSED on: 264d 3h cycles: 76
    read-units: 45,828,405 [23.4 TB] written-units: 24,747,049 [12.6 TB]
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 500GB
    family: based SSDs size: 465.76 GiB block-size: physical: 512 B
    logical: 512 B sata: 3.1 speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 2B6Q temp: 28 C scheme: GPT
  SMART: yes state: enabled health: PASSED on: 5y 14d 12h cycles: 1918
    written: 57.9 TiB
  Message: No optical or floppy data found.
  ID-1: / raw-size: 1.86 TiB size: 1.86 TiB (100.00%) used: 1.32 TiB (70.7%)
    fs: btrfs block-size: 4096 B dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-b09f133e-4cee-496f-816a-bf169e7cfdf5 label: N/A
    uuid: 0e693b7d-0009-41fd-85f6-1281c3eb5b91
    used: 984 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:1 label: N/A uuid: E4D4-6243
  ID-3: /home raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
    used: 1.32 TiB (70.7%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
    maj-min: 253:0 mapped: luks-b09f133e-4cee-496f-816a-bf169e7cfdf5 label: N/A
  ID-4: /media raw-size: 465.76 GiB size: 465.76 GiB (100.00%)
    used: 280.31 GiB (60.2%) fs: btrfs block-size: 4096 B dev: /dev/sda1
    maj-min: 8:1 label: N/A uuid: e57da652-ae17-4ce1-87eb-bc5d6666f6f9
  ID-5: /root raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
  ID-6: /srv raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
  ID-7: /var/cache raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
  ID-8: /var/log raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
  ID-9: /var/tmp raw-size: 1.86 TiB size: 1.86 TiB (100.00%)
  ID-1: swap-1 type: zram size: 62.43 GiB used: 0 KiB (0.0%) priority: 100
Unmounted:
  Message: No unmounted partitions found.
USB:
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 1d6b:0002
    class-ID: 0900
  Device-1: 1-1:2 info: TP-Link Bluetooth USB Adapter type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 2357:0604 class-ID: e001 serial: <filter>
  Device-2: 1-7:3 info: ASUSTek AURA LED Controller type: HID
    driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:19af class-ID: 0300
  Hub-2: 1-8:4 info: Genesys Logic Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 100mA
    chip-ID: 05e3:0608 class-ID: 0900
  Device-1: 1-8.1:6 info: Logitech Webcam C930e type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
  Device-2: 1-8.3:7 info: Keychron Q1 Max type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3434:0810 class-ID: 0300
  Device-3: 1-10:5 info: System76 Thelio Io 2 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3384:000b class-ID: 0300
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-4: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
    class-ID: 0900
  Device-1: 3-2:2 info: Microsoft Xbox360 Controller type: <vendor specific>
    driver: xpad interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 045e:028e class-ID: ff00 serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
    class-ID: 0900
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
    class-ID: 0900
  Device-1: 5-1:2 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
  Hub-7: 6-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 1d6b:0003
    class-ID: 0900
  Hub-8: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
    class-ID: 0900
  Hub-9: 8-0:1 info: super-speed hub ports: 1 rev: 3.1
    class-ID: 0900
  Hub-10: 9-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
    class-ID: 0900
  Hub-11: 10-0:1 info: super-speed hub ports: 1 rev: 3.1
    class-ID: 0900
  System Temperatures: cpu: 39.2 C mobo: 33.2 C
  Processes: 460 Power: uptime: 9h 26m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 24.91 GiB services: org_kde_powerdevil,
  Packages: pm: pacman pkgs: 2343 libs: 546 tools: octopi,paru,yay
    pm: flatpak pkgs: 0 Compilers: clang: 21.1.4 gcc: 15.2.1 Shell: Sudo (sudo)
    v: 1.9.17p2 default: Bash v: 5.3.3 running-in: konsole inxi: 3.3.39
Please, post complete garuda-inxi.
A better solution would be to test alternate kernels such as the LTS or mainline to see if they work with your Bluetooth adapter. Freezing a kernel version for any length of time is not really a good fix.
