System: Kernel: 5.12.12-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=a9a06d42-ed34-491f-a48b-05555f4a2ebb rw
Desktop: KDE Plasma 5.22.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: HP product: HP Laptop 15-da0xxx v: Type1ProductConfigId serial: <filter> Chassis: type: 10
Mobo: HP model: 84A6 v: 80.24 serial: <filter> UEFI: Insyde v: F.02 date: 05/24/2018
Battery: ID-1: BAT1 charge: 10.5 Wh (27.4%) condition: 38.3/41.0 Wh (93.3%) volts: 10.5 min: 11.4
model: Hewlett-Packard PABAS0241231 type: Li-ion serial: <filter> status: Discharging
Device-1: hidpp_battery_1 model: Logitech Wireless Mouse serial: <filter> charge: 55% (should be ignored)
rechargeable: yes status: Discharging
CPU: Info: Dual Core model: Intel Core i3-7100U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check family: 6
model-id: 8E (142) stepping: 9 microcode: EA cache: L2: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 19200
Speed: 2400 MHz min/max: 400/2400 MHz Core speeds (MHz): 1: 2400 2: 2401 3: 2400 4: 2400
Graphics: Device-1: Intel HD Graphics 620 vendor: Hewlett-Packard driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo bus-ID: 1-5:3 chip-ID: 0408:5362 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.1.2 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.12.12-zen1-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.30 running: no
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
port: 4000 bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard driver: rtw_8723de v: N/A
modules: rtw88_8723de port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:d723 class-ID: 0280
Bluetooth: Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-6:4 chip-ID: 0bda:b009
Report: bt-adapter ID: hci0 rfk-id: 7 state: down bt-service: enabled,running rfk-block: hardware: no software: no
address: <filter>
RAID: Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci v: 3.0 port: 5060 bus-ID: 00:17.0
chip-ID: 8086.282a rev: 21 class-ID: 0104
Drives: Local Storage: total: 931.51 GiB used: 67.07 GiB (7.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 5400 rpm serial: <filter> rev: RSM7 scheme: GPT
Partition: ID-1: / raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 67.06 GiB (7.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 67.06 GiB (7.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-4: /var/log raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 67.06 GiB (7.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-5: /var/tmp raw-size: 931.26 GiB size: 931.26 GiB (100.00%) used: 67.06 GiB (7.2%) fs: btrfs dev: /dev/sda2
maj-min: 8:2
ID-1: swap-1 type: zram size: 960.4 MiB used: 126.3 MiB (13.1%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 960.4 MiB used: 134.8 MiB (14.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 960.4 MiB used: 124.9 MiB (13.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 960.4 MiB used: 136.2 MiB (14.2%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 31.0 C mobo: 29.8 C
Info: Processes: 275 Uptime: 22h 05m wakeups: 93 Memory: 3.75 GiB used: 2.27 GiB (60.5%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.0 Packages: pacman: 1648 lib: 498 Shell: fish v: 3.2.2
default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.04
so sorry for that!!
Most likely this is not the cause of your issue, but your system is incredibly outdated.
You have not been updating in these last 4 months, have you? ![]()
I hope the update command (from terminal) was already available at that time.
You may want to try…
If not working, try upd to refresh your mirrors and then sudo pacman -Syu.
Crossing fingers… It will be a lot of stuff and maybe problems, but you have to make this step and get into the process of updating regularly…
Have you had a chance to run update or upd?
Please follow this tutorial to solve that:
Furthermore, please do not post pictures when you can (i.e. you can copy the text from terminal), since text is more readable and can be used to copy/paste/search, etc.
Format text blocks in the posts adding ~~~ before and after the test block.
Yes.
How many times do we have to write this here, it’s in every template.
Thats easy, not like in TTY you must use some .bin stuff.
Now i have updated but the problem is still the same
That was kind of expected (as I anticipated yesterday) but, believe me, it’s not wasted time.
I’m no expert on bluetooth and relevant issues, and the only hint I can give you is the link to the following thread that you may want to check.
It was for a different adapter but it has good troubleshooting hints, and it solved issues for some other users (also with different adapters) in the past.
Poster, if you are dual-booting with Windows, that may be the cause. Are you?
(Sometimes Windows "acquires" the hardware module and does not want to release it.)
Sometimes resetting your bios to the factory default helps in cases like this.
Testing alternate kernels is also very good idea.
