मैंने पहले पोस्ट किए गए सभी समाधानों का प्रयास किया है लेकिन काम नहीं कर रहा है।
I've tried all the soltutions previously posted but not working... @garuda-team
rfk-block: hardware: no software: yes
टर्मिनल आउटपुट inxi -Fza
Here is terminal output of inxi -Fza
मैंने 'pipewire-pulse' को 'pulseaudio' से बदलने की कोशिश की
I tried replacing 'pipewire-pulse' with 'pulseaudio'
:: pulseaudio and pipewire-pulse are in conflict. Remove pipewire-pulse? [y/N] y
:: removing pipewire-pulse breaks dependency 'pipewire-pulse' required by pipewire-support
The package available in AUR is bcm20702a1-firmware only, bcm20702a0-firmware is not available. When I’m cloning bcm20702a0-firmware, it’s automatically acquiring bcm20702a1-firmware package.
To connect, I’m turning on bluetooth from widgets → Add new device… Now after waiting for a while (I tried connecting to bluetooth earphones as well as smartphone), I got to know it’s not visible then (from settings → configure bluetooth) I have to click on the tick in front visible everytime. Even after making it visible, bluetooth is not showing smartphone bluetooth nor detecting earphones (same on smartphone/earphones side).
Actually while running inxi -Fza, I turned off bluetooth from widget mistakenly. After turning it on, there is no software block .
(Though already explained)
प्रिय मित्र, ब्लूटूथ चालू करने के बाद, यह किसी भी ब्लूटूथ डिवाइस (स्मार्टफोन/इयरफ़ोन) का पता नहीं लगा रहा है...
Dear friend, after turning bluetooth on, it's not detecting any bluetooth device(smartphone/earphones)...
Is there an update for your 2019 BIOS?
Did you check your BIOS Bluetooth settings?
Does it work if you boot a Garuda ISO?
Has it worked in any other Linux?
Does (or did) it work in Windows?
Why no update on your attempt to replace pipewire with pulseaaudio? Whatever happened with that?
If that is still TRUE, it needs to be resolved.
You’ve been using the good old scattershot methodology, and it apparently is not working.
First things first.
And don’t move on to something else unless it will resolve an error with the first thing.
Making the local device visible makes it visible for other devices to connect to it, it doesn’t make other devices visible to this one.
If this device can’t see other BT devices (after e.g. clicking Search) then are you sure those other devices are visible and not already paired and active with another device?
BIOS is up to date.
Bluetooth was working in windows. no issues
I tried runnung bluetoothctl.
bluetoothctl
Agent registered
[bluetooth]# power on
Changing power on succeeded
[bluetooth]# scan on
Discovery started
[CHG] Controller D8:5D:E2:AB:AF:EA Discovering: yes
[bluetooth]# pair D0:49:7C:03:76:AA
Device D0:49:7C:03:76:AA not available
[bluetooth]# DiscoverableTimeout = 0
Invalid command in menu main: DiscoverableTimeout
Use "help" for a list of available commands in a menu.
Use "menu <submenu>" if you want to enter any submenu.
Use "back" if you want to return to menu main.
[bluetooth]# list
Controller D8:5D:E2:AB:AF:EA akash-hpnotebook [default]
[bluetooth]# show
Controller D8:5D:E2:AB:AF:EA (public)
Alias: akash-hpnotebook
Class: 0x007c010c
Powered: yes
Discoverable: no
DiscoverableTimeout: 0x000000b4
Pairable: yes
UUID: Message Notification Se.. (00001133-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: OBEX Object Push (00001105-0000-1000-8000-00805f9b34fb)
UUID: Message Access Server (00001132-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: IrMC Sync (00001104-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (00005005-0000-1000-8000-0002ee000001)
UUID: Headset (00001108-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Phonebook Access Server (0000112f-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: Device Information (0000180a-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: Handsfree Audio Gateway (0000111f-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: OBEX File Transfer (00001106-0000-1000-8000-00805f9b34fb)
Modalias: usb:v1D6Bp0246d053C
Discovering: yes
Roles: central
Roles: peripheral
Advertising Features:
ActiveInstances: 0x00 (0)
SupportedInstances: 0x05 (5)
SupportedIncludes: tx-power
SupportedIncludes: appearance
SupportedIncludes: local-name
[bluetooth]# DiscoverableTimeout: 0x00000000
Invalid command in menu main: DiscoverableTimeout:
[bluetooth]# help
Menu main:
Available commands:
advertise Advertise Options Submenu
monitor Advertisement Monitor Options Submenu
scan Scan Options Submenu
gatt Generic Attribute Submenu
list List available controllers
show [ctrl] Controller information
select <ctrl> Select default controller
devices List available devices
paired-devices List paired devices
system-alias <name> Set controller alias
reset-alias Reset controller alias
power <on/off> Set controller power
pairable <on/off> Set controller pairable mode
discoverable <on/off> Set controller discoverable mode
discoverable-timeout [value] Set discoverable timeout
agent <on/off/capability> Enable/disable agent with given capability
default-agent Set agent as the default one
advertise <on/off/type> Enable/disable advertising with given type
set-alias <alias> Set device alias
scan <on/off> Scan for devices
info [dev] Device information
pair [dev] Pair with device
cancel-pairing [dev] Cancel pairing with device
trust [dev] Trust device
untrust [dev] Untrust device
block [dev] Block device
unblock [dev] Unblock device
remove <dev> Remove device
connect <dev> Connect device
disconnect [dev] Disconnect device
menu <name> Select submenu
version Display version
quit Quit program
exit Quit program
help Display help about this program
export Print environment variables
[bluetooth]# discoverable-timeout 0
Changing discoverable-timeout 0 succeeded
[CHG] Controller D8:5D:E2:AB:AF:EA DiscoverableTimeout: 0x00000000
[bluetooth]# list
[bluetooth]# show
Class: 0x007c010c
Powered: yes
Discoverable: no
Pairable: yes
Discovering: yes
Roles: central
Roles: peripheral
[bluetooth]# discoverable on
Changing discoverable on succeeded
[CHG] Controller D8:5D:E2:AB:AF:EA Discoverable: yes
Failed to start discovery: org.bluez.Error.InProgress
[bluetooth]#
Can you help me with discovery error(the only issue)?
AUR से पैकेज bcm43142a0-फर्मवेयर स्थापित करने के बाद, ब्लूटूथ सभी ब्लूटूथ डिवाइस से कनेक्ट हो रहा है... मदद के लिए आप सभी का धन्यवाद!!!
After installing the package bcm43142a0-firmware from the AUR, bluetooth is connecting to devices... Thank you everyone for the help!!!
To others: See, this where trying to help another user gets really, really frustrating. If they won't give a complete answer, don't help them. You are hurting them.
