Could someone help me how to enable the bluetooth back?
I have played music with bluetooth after dual booting the Garuda Linux with Windows OS and before doing pacman -Syu.
The pacman -Syu possibly had made changes to the bluetooth.
╰─λ garuda-inxi
Kernel: 5.18.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=1c1995a9-4167-46de-b0a9-fa58d32cb7ac rw [email protected]
Desktop: KDE Plasma v: 5.25.1 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: ASUSTeK product: X555LA v: 1.0
Mobo: ASUSTeK model: X555LA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X555LA.308 date: 08/14/2014
ID-1: BAT0 charge: N/A condition: N/A volts: N/A model: N/A type: Unknown
serial: N/A status: N/A
Info: model: Intel Core i3-4030U bits: 64 type: MT MCP arch: Haswell
gen: core 4 built: 2013-15 process: Intel 22nm family: 6
model-id: 0x45 (69) stepping: 1 microcode: 0x26
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1365 high: 1797 min/max: 800/1800 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 891 2: 1403 3: 1372
4: 1797 bogomips: 15164
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: ASUSTeK
driver: i915 v: kernel arch: Gen7.5 process: Intel 22nm built: 2013 ports:
active: DP-1,eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:0a16
Device-2: Realtek USB Camera type: USB driver: uvcvideo bus-ID: 2-5:4
chip-ID: 0bda:57b5 class-ID: 0e02 serial: <filter>
Screen-1: 0 s-res: 2732x768 s-dpi: 96 s-size: 722x203mm (28.43x7.99")
s-diag: 750mm (29.53")
Monitor-1: DP-1 pos: primary,left model: AOC 2070L serial: <filter>
built: 2018 res: 1366x768 hz: 60 dpi: 80 gamma: 1.2
size: 434x236mm (17.09x9.29") diag: 494mm (19.4") ratio: 16:9 modes:
max: 1366x768 min: 720x400
Monitor-2: eDP-1 pos: right model: ChiMei InnoLux 0x15ab built: 2013
res: 1366x768 hz: 60 dpi: 101 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1366x768
OpenGL: renderer: Mesa Intel HD Graphics 4400 (HSW GT2)
v: 4.6 Mesa 22.1.2 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Sound Server-1: ALSA v: k5.18.7-zen1-1-zen running: yes
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Lite-On driver: wl
chip-ID: 14e4:4365 class-ID: 0280
IF: wlp3s0 state: dormant mac: <filter>
Device-1: Lite-On Broadcom BCM43142A0 Bluetooth Device type: USB
driver: btusb v: 0.8 bus-ID: 2-6:5 chip-ID: 04ca:2006 class-ID: fe01
Report: bt-adapter ID: hci0 rfk-id: 0 state: up address: N/A
Local Storage: total: 465.76 GiB used: 11.05 GiB (2.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MQ01ABF050
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 1J scheme: GPT
ID-1: / raw-size: 114.62 GiB size: 114.62 GiB (100.00%)
used: 11.02 GiB (9.6%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
used: 29.8 MiB (31.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 114.62 GiB size: 114.62 GiB (100.00%)
ID-4: /var/log raw-size: 114.62 GiB size: 114.62 GiB (100.00%)
ID-5: /var/tmp raw-size: 114.62 GiB size: 114.62 GiB (100.00%)
ID-1: swap-1 type: zram size: 5.68 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C pch: 48.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3100
Processes: 192 Uptime: 17m wakeups: 1 Memory: 5.68 GiB
used: 2.3 GiB (40.4%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 Packages: pacman: 1153 lib: 298
Shell: fish v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-06-13
Last full system update: 2022-06-28 ↻
