My JBL headset connects just fine in playback mode. When I try to switch it to headset mode in order to make calls, it does not work at all. It does work in Windows and last week's plain Arch.
This is what I see in journalctl when I try to switch to headset mode:
Nov 25 10:47:56 m446 kernel: Bluetooth: hci0: urb 00000000ee97747a submission failed (90)
Nov 25 10:47:56 m446 kernel: Bluetooth: hci0: sending frame failed (-90)
Nov 25 10:47:56 m446 kernel: Bluetooth: hci0: SCO packet for unknown connection handle 0
And this is the relevant output from pacmd list-cards
index: 2
driver: <module-bluez5-device.c>
owner module: 27
properties:
device.description = "JBL TUNE600BTNC"
device.string = "30:C0:1B:E5:C1:62"
device.api = "bluez"
device.class = "sound"
device.bus = "bluetooth"
device.form_factor = "headset"
bluez.path = "/org/bluez/hci0/dev_30_C0_1B_E5_C1_62"
bluez.class = "0x240404"
bluez.alias = "JBL TUNE600BTNC"
device.icon_name = "audio-headset-bluetooth"
device.intended_roles = "phone"
profiles:
headset_head_unit: Headset Head Unit (HSP/HFP) (priority 30, available: unknown)
a2dp_sink_sbc: High Fidelity Playback (A2DP Sink: SBC) (priority 40, available: unknown)
a2dp_sink_aac: High Fidelity Playback (A2DP Sink: AAC) (priority 40, available: no)
a2dp_sink_aptx: High Fidelity Playback (A2DP Sink: aptX) (priority 40, available: no)
a2dp_sink_aptx_hd: High Fidelity Playback (A2DP Sink: aptX HD) (priority 40, available: no)
a2dp_sink_ldac: High Fidelity Playback (A2DP Sink: LDAC) (priority 40, available: no)
off: Off (priority 0, available: yes)
active profile: <headset_head_unit>
sinks:
bluez_sink.30_C0_1B_E5_C1_62.headset_head_unit/#6: JBL TUNE600BTNC
sources:
bluez_sink.30_C0_1B_E5_C1_62.headset_head_unit.monitor/#9: Monitor of JBL TUNE600BTNC
bluez_source.30_C0_1B_E5_C1_62.headset_head_unit/#10: JBL TUNE600BTNC
ports:
headset-output: Headset (priority 0, latency offset 0 usec, available: unknown)
properties:
headset-input: Headset (priority 0, latency offset 0 usec, available: unknown)
properties:
Any tips on how to get the headset working (again)?
