I have my Bluetooth earphones and they do not connect to the laptop after a reboot. Every time I delete the instance (PTron BT) and reconfigure the device through the KDE settings app, it works. I can watch YouTube videos, and sound comes fine. My headphones’ volume control buttons also control volume without a problem. But every time I reboot the computer, bluetooth breaks. Then I get the following error in the settings menu :
“br-connection-unknown”
Then forgetting the headphones and repairing works. So is there a way to fix this?
My garuda-inxi is follows:
Kernel: 5.19.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=0504164e-7c45-4bb6-8b98-0b9c553029c2 rw rootflags=subvol=@
resume=UUID=24bf752a-dccf-4e7c-ad66-fbc296ec6364 loglevel=3
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Laptop System: Dell product: Dell G15 5510 v: N/A serial:
Chassis: type: 10 serial:
Mobo: Dell model: 0WCM79 v: A01 serial: UEFI: Dell v: 1.15.0
date: 08/05/2022
ID-1: BAT0 charge: 53.8 Wh (98.0%) condition: 54.9/54.9 Wh (100.0%)
volts: 12.8 min: 11.4 model: BYD DELL DVG8M1A type: Li-poly
serial: status: not charging
Info: model: Intel Core i5-10500H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 3104 high: 4400 min/max: 800/4500 base/boost: 2772/2500
ext-clock: 100 MHz cores: 1: 2500 2: 2500 3: 4300 4: 2500 5: 2500 6: 2500
7: 4400 8: 4389 9: 4160 10: 2500 11: 2500 12: 2500 bogomips: 59998
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Dell driver: i915
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 515.76 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-08) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f9d class-ID: 0300
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0c45:6a09 class-ID: 0e02
unloaded: nouveau alternate: fbdev,intel,nv,vesa gpu: i915 display-ID: :0
Monitor-1: eDP-1 model: Najing CEC Panda 0x005f built: 2021
res: 1920x1080 hz: 120 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Dell
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
Sound Server-1: ALSA v: k5.19.12-zen1-1-zen running: yes
IF: wlp0s20f3 state: up mac:
vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac:
bus-ID: 1-14:3 chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 1 state: up address:
Local Storage: total: 1.38 TiB used: 41.85 GiB (3.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM991a NVMe
512GB size: 476.94 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: rev: 26304039
temp: 32.9 C scheme: GPT
SMART: yes health: PASSED on: 7d 22h cycles: 182 read-units: 5,743,303
[2.94 TB] written-units: 5,660,115 [2.89 TB]
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Western Digital model: WD
Elements 25A2 drive model: WD10JMVW-11AJGS4 family: Elements / My
Passport (USB, AF) size: 931.48 GiB block-size: physical: 4096 B
logical: 512 B sata: 3.0 speed: 3.0 Gb/s type: HDD rpm: 5400
serial: drive serial: rev: 1014 drive rev: 01.01A01
temp: 36 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 47d 17h cycles: 358
ID-1: / raw-size: 70 GiB size: 70 GiB (100.00%) used: 21.02 GiB (30.0%)
fs: btrfs block-size: 4096 B dev: /dev/sda3 maj-min: 8:3
ID-2: /boot/efi raw-size: 401 MiB size: 400.2 MiB (99.80%) used: 608 KiB
(0.1%) fs: vfat block-size: 512 B dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 200 GiB size: 200 GiB (100.00%) used: 20.84 GiB
(10.4%) fs: btrfs block-size: 4096 B dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 70 GiB size: 70 GiB (100.00%) used: 21.02 GiB
(30.0%) fs: btrfs block-size: 4096 B dev: /dev/sda3 maj-min: 8:3
ID-5: /var/tmp raw-size: 70 GiB size: 70 GiB (100.00%) used: 21.02 GiB
ID-1: swap-1 type: zram size: 15.41 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 67.0 C pch: 61.0 C mobo: N/A
Processes: 351 Uptime: 26m wakeups: 2055 Memory: 15.41 GiB used: 3.78 GiB
(24.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1651 libs: 496
tools: octopi,paru,yay Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.21
Garuda (2.6.8-1):
System install date: 2022-09-12
Last full system update: 2022-10-03
Windows dual boot: Yes
Any help will be hugely appreciated. Thanks
Here’s a link to the screenshot of the KDE settings app - https://imgur.com/a/YhMzXt3
