My bluetooth headphone audio is much lower then when I was using Ubuntu (so it shouldn't be a harware problem)
I tried the following solution: Bluetooth Headset volume too low (only in arch) / Multimedia and Games / Arch Linux Forums but it didn't help
I also tried Arch WIki, but it assumes PulseAudio, but when I try to install it garuda says I would have to remove gnome-bluetooth and shell.
Maybe?
Did you search in forum?
When I exit alsa the master volume goes back to 0
Start at the beginning read
please
and post
inxi -Fxxxza
as text!
Are you on KDE?
Maybe reboot after update.
I'm on Gnome
here's the output of the command:
System: Kernel: 5.10.15-120-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=2ecc406b-c39b-4e9b-953d-77dd6ef617da rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
Desktop: GNOME 3.38.3 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1 Distro: Garuda Linux
Machine: Type: Laptop System: Micro-Star product: GL62M 7RD v: REV:1.0 serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16J9 v: REV:1.0 serial: <filter> UEFI: American Megatrends v: E16J9IMS.31C
date: 10/24/2017
Battery: ID-1: BAT1 charge: 35.1 Wh condition: 35.1/42.4 Wh (83%) volts: 12.2/10.8 model: MSI BIF0_9 type: Li-ion
serial: N/A status: Full
CPU: Info: Quad Core model: Intel Core i5-7300HQ bits: 64 type: MCP arch: Kaby Lake family: 6 model-id: 9E (158)
stepping: 9 microcode: DE L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20017
Speed: 3024 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 3024 2: 3189 3: 3158 4: 3020
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Graphics: Device-1: Intel HD Graphics 630 vendor: Micro-Star MSI driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:591b
class ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Micro-Star MSI driver: N/A alternate: nouveau
bus ID: 01:00.0 chip ID: 10de:1c8d class ID: 0302
Display: x11 server: X.Org 1.20.10 compositor: gnome-shell driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :1 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1016x286mm (40.0x11.3") s-diag: 1055mm (41.6")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
Monitor-2: HDMI2 res: 1920x1080 hz: 60 dpi: 102 size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: Mesa Intel HD Graphics 630 (KBL GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Audio: Device-1: Intel CM238 HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 00:1f.3
chip ID: 8086:a171 class ID: 0403
Sound Server: ALSA v: k5.10.15-120-tkg-bmq
Network: Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0
chip ID: 8086:24fb class ID: 0280
Device-2: Qualcomm Atheros QCA8171 Gigabit Ethernet vendor: Micro-Star MSI driver: alx v: kernel port: d000
bus ID: 03:00.0 chip ID: 1969:10a1 class ID: 0200
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-10:4 chip ID: 8087:0aa7
class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 238.47 GiB used: 84.26 GiB (35.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: THNSNJ256G8NY size: 238.47 GiB block size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0101 scheme: GPT
Partition: ID-1: / raw size: 238.17 GiB size: 238.17 GiB (100.00%) used: 84.26 GiB (35.4%) fs: btrfs block size: 4096 B
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%) fs: vfat block size: 512 B
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 238.17 GiB size: 238.17 GiB (100.00%) used: 84.26 GiB (35.4%) fs: btrfs block size: 4096 B
ID-4: /var/log raw size: 238.17 GiB size: 238.17 GiB (100.00%) used: 84.26 GiB (35.4%) fs: btrfs block size: 4096 B
ID-5: /var/tmp raw size: 238.17 GiB size: 238.17 GiB (100.00%) used: 84.26 GiB (35.4%) fs: btrfs block size: 4096 B
ID-1: swap-1 type: zram size: 3.89 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 3.89 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 3.89 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
Sensors: System Temperatures: cpu: 56.0 C mobo: 27.8 C
Info: Processes: 290 Uptime: 1h 03m wakeups: 1 Memory: 15.55 GiB used: 6.04 GiB (38.9%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1686 lib: 460 Shell: Zsh v: 5.8 running in: kitty inxi: 3.3.01
Folks at telegram helped me and pavucontrol worked
Folks are Garuda Team Developer
