I keep getting an error when I try my bluetooth headphones which are an ATH-M50x I have tried using switching from pipwire audio to pulseaudio. I then have tried to uninstall and reinstall bluez which was recommended somewhere on this forum . Tried looking at the bluetoothctl command to with no clue whats wrong. Below i have shared both the garuda-inxi and the bluetoothctl to try and see if someone can help. This device is not even paired to my windows 11 install.
[bluetooth]# list
Controller 50:84:92:FF:73:27 InmateGaruda [default]
[bluetooth]# show
Controller 50:84:92:FF:73:27 (public)
Manufacturer: 0x0002 (2)
Version: 0x0c (12)
Alias: InmateGaruda
Class: 0x006c010c (7078156)
Powered: yes
PowerState: on
Discoverable: no
DiscoverableTimeout: 0x000000b4 (180)
Pairable: yes
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Handsfree Audio Gateway (0000111f-0000-1000-8000-00805f9b34fb)
UUID: PnP Information (00001200-0000-1000-8000-00805f9b34fb)
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: Audio Source (0000110a-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Device Information (0000180a-0000-1000-8000-00805f9b34fb)
UUID: Vendor specific (03b80e5a-ede8-4b33-a751-6ce34ec4c700)
UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb)
Modalias: usb:v1D6Bp0246d054C
Discovering: no
Roles: central
Roles: peripheral
Advertising Features:
ActiveInstances: 0x00 (0)
SupportedInstances: 0x0c (12)
SupportedIncludes: tx-power
SupportedIncludes: appearance
SupportedIncludes: local-name
SupportedSecondaryChannels: 1M
SupportedSecondaryChannels: 2M
SupportedSecondaryChannels: Coded
erl: warning: Setting locale failed.
LANGUAGE = "en_US",
LC_ALL = (unset),
LC_ADDRESS = "fi_FI.UTF-8",
LC_NAME = "fi_FI.UTF-8",
LC_MONETARY = "en_FI.UTF-8",
LC_PAPER = "en_FI.UTF-8",
LC_IDENTIFICATION = "fi_FI.UTF-8",
LC_TELEPHONE = "fi_FI.UTF-8",
LC_MEASUREMENT = "en_FI.UTF-8",
LC_TIME = "en_FI.UTF-8",
LC_NUMERIC = "en_FI.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to a fallback locale ("en_US.UTF-8").
Kernel: 6.9.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=f944f352-5a3e-4b23-8326-5457943b7e1a rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.3.0
Type: Laptop System: Razer product: Blade 17 (2022) - RZ09-0423 v: 8.04
Mobo: Razer model: DI780 v: 4 serial: <superuser required>
part-nu: RZ09-0423PEF3 uuid: <superuser required> UEFI: Razer v: 1.09
date: 01/10/2023
ID-1: BAT0 charge: 64.2 Wh (77.3%) condition: 83.0/82.1 Wh (101.2%)
volts: 15.4 min: 15.4 model: Razer Blade type: Unknown serial: <filter>
status: not charging
Info: model: 12th Gen Intel Core i9-12900H bits: 64 type: MST AMCP
microcode: 0x433
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1224 high: 4081 min/max: 400/4900:5000:3800 scaling:
driver: intel_pstate governor: performance cores: 1: 492 2: 400 3: 400
4: 400 5: 400 6: 400 7: 4081 8: 400 9: 400 10: 400 11: 400 12: 400
13: 3800 14: 3768 15: 2370 16: 3095 17: 400 18: 400 19: 1690 20: 400
bogomips: 116736
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Razer USA
driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
built: 2021-22+ ports: active: none off: eDP-1 empty: none bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA103M [GeForce RTX 3080 Ti Mobile] vendor: Razer USA
driver: nvidia v: 550.90.07 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 8 link-max: lanes: 16 ports: active: none off: HDMI-A-1
empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 01:00.0 chip-ID: 10de:2420
Device-3: IMC Networks Integrated RGB Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:4 chip-ID: 13d3:5279
Monitor-1: HDMI-A-1 res: 5120x1440 size: N/A modes: N/A
inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.1-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 15.15 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 10 device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 24.1.1-arch1.1
device-ID: 8086:46a6 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: NVIDIA GeForce RTX 3080 Ti Laptop GPU
driver: nvidia v: 550.90.07 device-ID: 10de:2420
17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.1-arch1.1 (LLVM 17.0.6)
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Razer USA
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
Device-2: NVIDIA vendor: Razer USA driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:2288 class-ID: 0403
API: ALSA v: k6.9.3-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.7 status: active with: 1: wireplumber
status: active 2: pipewire-alsa type: plugin 3: pw-jack type: plugin
tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0 status: off with: pulseaudio-jack
type: module tools: pacat,pactl
Device-1: Intel Alder Lake-P PCH CNVi WiFi vendor: Rivet Networks
Simultaneous Dual Band Wi-Fi 6E AX1690i 160MHz 2x2 driver: iwlwifi
v: kernel bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
Device-2: Realtek RTL8125 2.5GbE vendor: Razer USA driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0033
Local Storage: total: 4.57 TiB used: 53.53 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Western Digital
model: WDS400T3X0C-00SJG0 size: 3.64 TiB block-size: physical: 512 B
fw-rev: 114000WD temp: 45.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
fw-rev: GXA7601Q temp: 37.9 C scheme: GPT
ID-1: / raw-size: 107.42 GiB size: 107.42 GiB (100.00%)
used: 53.49 GiB (49.8%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:9
used: 46.2 MiB (48.2%) fs: vfat dev: /dev/nvme1n1p2 maj-min: 259:2
ID-3: /home raw-size: 107.42 GiB size: 107.42 GiB (100.00%)
ID-4: /var/log raw-size: 107.42 GiB size: 107.42 GiB (100.00%)
ID-5: /var/tmp raw-size: 107.42 GiB size: 107.42 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.03 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 20 dev: /dev/zram0
System Temperatures: cpu: 54.0 C mobo: N/A
Memory: total: 32 GiB note: est. available: 31.03 GiB used: 5.58 GiB (18.0%)
Processes: 457 Power: uptime: 36m states: freeze,mem,disk suspend: s2idle
suspend, test_resume image: 12.37 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 2089 libs: 601 tools: gnome-software, octopi,
pamac, paru Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.34
System install date: 2024-04-11
Last full system update: 2024-06-18
