Ok so I'm having a really scuffed and very annoying issue that I'm failing to deal with for several hours already...
What happened:
- I accidentally knocked out my flimsy bluetooth dongle out of my usb hub
- Rebooted, because it would not detect it again
- Worked
- Did it again
- didn't work anymore in the hub. It just refuses to register at all. It now only works in my pc's own usb ports, which is where I can't use it.
- Everything is in shambles
So after dealing with error upon error I decided to delete my headset's profile altogether and start from zero, but I'm still having issues. I can now connect to my headset again, but it's not registered in pipewire, even though it clearly sais it did exactly that. A minute later, the device disconnects again.
I have no clue what to do now. Nothing I try works. I don't even know where this issue started.
At this point, I'd like to have my deleted headset profile back, since deleting it really didn't work out. Where is that stored? I can't find the file...
Does anyone have an idea how to fix this? It does not seem to be related to an upgrade. The relevant stuff was the kernel, and downgrading or switching to LTS does not work.
Since I already have this typed, I'll post it, but I'm gonna try upgrading again in the hopes of that changing anything, but I doubt it. (Did not help)
Edit: Now, after another reboot, I'm getting the 6th completely undocumented error message: le-connection-abort-by-local
Why does it abort?
Also, just to confirm, I just removed my own wireplumber and bluetooth/main.conf modifications, still no change.
Kernel: 6.4.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: root=PARTUUID=fec66b8f-995b-8043-94b0-fcc9535362ba rw
add_efi_memmap rootflags=subvol=@ initrd=@\boot\amd-ucode.img
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
iommu=soft initrd=\@\boot\initramfs-linux-zen.img
Desktop: Hyprland info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50a
date: 11/27/2019
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3532 high: 4144 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4144 2: 4129
3: 4141 4: 4141 5: 3841 6: 2071 7: 3600 8: 3600 9: 3600 10: 4132 11: 2922
12: 2071 bogomips: 86226
vendor: Sapphire driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-3,HDMI-A-1 empty: DP-1,DP-2 bus-ID: 0a:00.0
chip-ID: 1002:73df class-ID: 0300
Display: wayland server: Xwayland v: 23.2.0 compositor: Hyprland driver:
X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: 1
Monitor-1: DP-3 model: Apple Cinema HD Display serial: <filter>
built: 2003 res: 1920x1200 dpi: 99 gamma: 1.2 size: 495x310mm (19.49x12.2")
diag: 584mm (23") ratio: 16:10 modes: max: 1920x1200 min: 640x480
Monitor-2: HDMI-A-1 model: Samsung SyncMaster serial: <filter> built: 2007
res: 1680x1050 dpi: 90 gamma: 1.2 size: 474x296mm (18.66x11.65")
diag: 559mm (22") ratio: 16:10 modes: max: 1680x1050 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.52 6.4.7-zen1-2-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0a:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.3
Device-3: C-Media USB Microphone driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.1:6
chip-ID: 0d8c:9700 class-ID: 0300 serial: <filter>
Device-4: Textech USB Midi 4i4o driver: snd-usb-audio type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.2:7 chip-ID: 15ca:1804
class-ID: 0103
Device-5: Comtrue Swissonic Audio ASIO driver: snd-usb-audio type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4.3:8
chip-ID: 2fc6:f04e class-ID: 0102 serial: <filter>
Device-6: M-Audio Keystation 88 MK3 driver: snd-usb-audio type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4.4:9
chip-ID: 0763:0044 class-ID: 0103
API: ALSA v: k6.4.7-zen1-2-zen status: kernel-api
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:2 chip-ID: 0a5c:21e8
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 sub-v: 220e hci-v: 6 rev: 1000 class-ID: 7c0104
Info: acl-mtu: 1021:8 sco-mtu: 64:1 link-policy: rswitch sniff
link-mode: peripheral accept service-classes: rendering, capturing, object
transfer, audio, telephony
Local Storage: total: 2.96 TiB used: 810.77 GiB (26.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A82 scheme: GPT
ID-1: / raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
used: 104.04 GiB (53.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 19.1 MiB (6.3%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%)
used: 358.54 GiB (48.7%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 50.9 C mobo: 29.0 C gpu: amdgpu temp: 52.0 C
mem: 50.0 C
Fan Speeds (rpm): cpu: 0 fan-1: 0 fan-3: 0 gpu: amdgpu fan: 0
Power: 12v: N/A 5v: N/A 3.3v: 3.33 vbat: 2.83 gpu: amdgpu watts: 12.00
Processes: 367 Uptime: 12m wakeups: 0 Memory: total: 32 GiB
available: 31.29 GiB used: 5.38 GiB (17.2%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: nix-default pkgs: 0 pm: nix-sys pkgs: 0 pm: nix-usr pkgs: 0
pm: pacman pkgs: 1905 libs: 502 tools: yay Shell: Zsh v: 5.9
running-in: alacritty inxi: 3.3.29
System install date: 2023-01-08
Last full system update: 2023-08-19
Is partially upgraded: Yes
