hello all
System: Kernel: 5.12.17-1-ck-zen2 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-ck-zen2 root=UUID=ce5da691-f89b-4cd8-b44f-90011d7f627a rw
systemd.unified_cgroup_hierarchy=1 resume=UUID=1c553e07-4c85-4cb4-845d-6e5ec3419d20 loglevel=3
sysrq_always_enabled=1 mitigations=off
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: MEDION product: E14304 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: MEDION model: NS1xAR serial: <filter> UEFI: American Megatrends v: A6R618_V0.17.2_M00P1T0G0 date: 12/24/2020
Battery: ID-1: BAT0 charge: 44.5 Wh (98.9%) condition: 45.0/45.0 Wh (100.0%) volts: 11.6 min: N/A
model: MEDION Li-ion Real Battery type: Li-ion serial: <filter> status: Charging
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter> charge: 75% rechargeable: yes status: Discharging
CPU: Info: Quad Core model: AMD Ryzen 3 4300U with Radeon Graphics bits: 64 type: MCP arch: Zen 2 family: 17 (23)
model-id: 60 (96) stepping: 1 microcode: 8600106 cache: L2: 2 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 21560
Speed: 2491 MHz min/max: 1400/2700 MHz boost: enabled Core speeds (MHz): 1: 2491 2: 3182 3: 2506 4: 3361
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and usercopy barriers only; no swapgs barriers
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Renoir driver: amdgpu v: kernel bus-ID: 03:00.0 chip-ID: 1002:1636
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: amdgpu,ati unloaded: modesetting
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 158 size: 309x174mm (12.2x6.9") diag: 355mm (14")
OpenGL: renderer: AMD RENOIR (DRM 3.40.0 5.12.17-1-ck-zen2 LLVM 12.0.1) v: 4.6 Mesa 21.2.2 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] driver: snd_hda_intel v: kernel bus-ID: 03:00.1 chip-ID: 1002:1637
Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio driver: snd_hda_intel v: kernel bus-ID: 03:00.6
Sound Server-1: ALSA v: k5.12.17-1-ck-zen2 running: yes
Sound Server-4: PipeWire v: 0.3.37 running: yes
Network: Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel bus-ID: 01:00.0 chip-ID: 8086:3165 class-ID: 0280
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-3:2 chip-ID: 8087:0a2a
Drives: Local Storage: total: 1.83 TiB used: 396.42 GiB (21.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q4 size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 type: SSD serial: <filter> rev: RKT40Q.2 temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Generic model: SD MMC MS PRO size: 7.61 GiB block-size:
physical: 512 B logical: 512 B type: SSD serial: <filter> rev: 1.00 scheme: MBR
Partition: ID-1: / raw-size: 115.23 GiB size: 115.23 GiB (100.00%) used: 30.91 GiB (26.8%) fs: btrfs dev: /dev/nvme0n1p1
maj-min: 259:1
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p3
maj-min: 259:3
ID-3: /home raw-size: 1.59 TiB size: 1.59 TiB (100.00%) used: 353.64 GiB (21.7%) fs: btrfs dev: /dev/nvme0n1p4
maj-min: 259:4
ID-4: /var/log raw-size: 115.23 GiB size: 115.23 GiB (100.00%) used: 30.91 GiB (26.8%) fs: btrfs
ID-5: /var/tmp raw-size: 115.23 GiB size: 115.23 GiB (100.00%) used: 30.91 GiB (26.8%) fs: btrfs
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5
ID-2: swap-2 type: zram size: 7.26 GiB used: 2.2 MiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 54.5 C mobo: N/A gpu: amdgpu temp: 52.0 C
Info: Processes: 306 Uptime: 2h 0m wakeups: 20 Memory: 7.26 GiB used: 4.1 GiB (56.4%) Init: systemd v: 249
tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1479 lib: 358 Shell: fish v: 3.3.1
running-in: konsole inxi: 3.3.06
SoundPeats earbuds are not showing any battery info in KDE. not in notification area, nor in the system info - energy.
They do show in Android.
For instance Logitech mouse is shown,
all updated.
any ideas how to force the info to show up?
