Bluetooth don´t work
Hello, I have the following problem
i cannot connect bluetooth devices
Can someone help me
i installed garuda a month ago but have never connected a bluetooth device. now i want to connect a device for the first time and it doesn’t work i have tried with several devices but the following devices:
Bose bluetooth headphones,
Xbox one controller
Microsoft wireless mouse 3000
better said no device
Please help I can also enter commands
Translated with DeepL.com (free version)
Hi there welcome to the forum.
Please provide the output of your garuda-inxi, as required by the template.
here it is sorry was just gone
[🔍] × garuda-inxi
Kernel: 6.6.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: hpet available: acpi_pm
root=UUID=f891302e-d8e6-461e-acc7-96c08d9efaa5 rw rootflags=subvol=@
Type: Laptop System: Hewlett-Packard product: HP Pavilion Notebook v: N/A
Mobo: Hewlett-Packard model: 80B6 v: 81.15 serial: <superuser required>
UEFI: American Megatrends v: F.07 date: 05/22/2015
ID-1: BAT0 charge: 26.5 Wh (86.0%) condition: 30.8/30.8 Wh (100.0%)
power: 30.3 W volts: 15.4 min: 14.8 model: Hewlett-Packard Primary
type: Li-ion serial: N/A status: discharging cycles: 277
Info: model: AMD A10-8700P Radeon R6 10 Compute Cores 4C+6G bits: 64
type: MT MCP arch: Excavator level: v3 note: check built: 2015
process: GF 28nm family: 0x15 (21) model-id: 0x60 (96) stepping: 1
microcode: 0x600610B
Topology: cpus: 1x cores: 4 smt: enabled cache: L1: 320 KiB
desc: d-4x32 KiB; i-2x96 KiB L2: 2 MiB desc: 2x1024 KiB
Speed (MHz): avg: 2121 high: 2737 min/max: 1300/1800 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2178 2: 2271
3: 1298 4: 2737 bogomips: 14372
Device-1: AMD Wani [Radeon R5/R6/R7 Graphics] vendor: Hewlett-Packard
driver: amdgpu v: kernel arch: GCN-3 code: Volcanic Islands
process: TSMC 28nm built: 2014-19 ports: active: eDP-1 empty: HDMI-A-1
bus-ID: 00:01.0 chip-ID: 1002:9874 class-ID: 0300
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 M440/M445 530/535
620/625 Mobile] vendor: Hewlett-Packard driver: amdgpu v: kernel
arch: GCN-3 code: Volcanic Islands process: TSMC 28nm built: 2014-19 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s
bus-ID: 04:00.0 chip-ID: 1002:6900 class-ID: 0380 temp: 40.0 C
Device-3: Chicony HP Truevision HD driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1:2 chip-ID: 04f2:b50d
Monitor-1: eDP-1 mapped: eDP model: Samsung 0x3854 built: 2014
res: 1920x1080 hz: 60 dpi: 128 gamma: 1.2 size: 382x215mm (15.04x8.46")
diag: 438mm (17.3") ratio: 16:9 modes: max: 1920x1080 min: 640x480
device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon R6 Graphics (carrizo
LLVM 16.0.6 DRM 3.54 6.6.3-zen1-1-zen) device-ID: 1002:9874
memory: 500 MiB unified: no
API: Vulkan v: 1.3.269 layers: 7 device: 0 type: integrated-gpu name: AMD
Radeon R6 Graphics (RADV CARRIZO) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:9874 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: AMD Radeon R7 M360 (RADV ICELAND) driver: mesa radv
v: 23.2.1-arch1.2 device-ID: 1002:6900 surfaces: xcb,xlib device: 2
type: cpu name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe
v: 23.2.1-arch1.2 (LLVM 16.0.6) device-ID: 10005:0000 surfaces: xcb,xlib
Device-1: AMD Kabini HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:01.1 chip-ID: 1002:9840
Device-2: AMD Family 15h Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 00:09.2 chip-ID: 1022:157a
API: ALSA v: k6.6.3-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000
bus-ID: 02:00.0 chip-ID: 10ec:8136 class-ID: 0200
Device-2: Broadcom BCM43142 802.11b/g/n vendor: Hewlett-Packard driver: wl
v: kernel modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 03:00.0 chip-ID: 14e4:4365 class-ID: 0280
Device-1: Broadcom BCM43142A0 Bluetooth 4.0 driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-2:3 chip-ID: 0a5c:216d
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 119.24 GiB used: 81.3 GiB (68.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 128GB
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 81.3 GiB (68.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.21 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.0 C mobo: N/A
GPU: device: amdgpu temp: 40.0 C device: amdgpu temp: 39.0 C
Processes: 264 Uptime: 1h 0m wakeups: 1 Memory: total: 8 GiB note: est.
available: 7.21 GiB used: 3.46 GiB (48.0%) Init: systemd v: 254
pm: pacman pkgs: 1334 libs: 371 tools: octopi,paru Shell: fish v: 3.6.1
default: Bash v: 5.2.21 running-in: konsole inxi: 3.3.31
Garuda (2.6.19-2):
System install date:     2023-10-15
Last full system update: 2023-12-01
Hello please help me
After 35 min. :exploding_head:
This is called an empty bump. Provide further information if you wish to elevate your post. Add more posts to your thread when you have some useful information to provide others.
Until then, your empty posts are of little usefulness and are unwanted in forums.
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
lsusb
btmgmt
Use "help" for a list of available commands in a menu.
Use "menu <submenu>" if you want to enter any submenu.
Use "back" if you want to return to menu main.
Try installing broadcom-bt-firmware-git and reboot.
Check also this, if it can be switched in the bluetooth settings.
I tryed
Thank you very much it works great without you I would have given up looking for a solution
