Bluetooth operated well for several weeks after initially installing Garuda. I was primarily using it with a headset, and I was getting good audio quality (at least as good as one can hope from Bluetooth).
Later, any time I'd try to connect my headset, Garuda would indicate for about 10 seconds that it had connected (though the headset would not indicate this) before disconnecting again, with Bluetooth Device Wizard reporting "The setup of [my device] has failed." On rare occasions, I've managed to get a successful connection, but the audio quality is low, and no higher quality codec is available (previously I was using A2DP, not available anymore).
Note that this problem started months ago, perhaps in August. I am not dual booting.
System: Kernel: 5.15.5-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=2f4858ad-71bd-4356-b1ac-0e372de86443
systemd.unified_cgroup_hierarchy=1 resume=UUID=60288167-31c3-4822-a67d-4bf8e661fc50 loglevel=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop System: HP product: HP Pavilion Desktop TP01-1xxx v: N/A
Mobo: HP model: 87D6 v: SMVB serial: <superuser required> UEFI: AMI v: F.12 date: 12/17/2020
CPU: Info: 6-Core model: AMD Ryzen 5 4600G with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2
family: 17 (23) model-id: 60 (96) stepping: 1 microcode: 8600106 cache: L1: 384 KiB L2: 3 MiB
L3: 8 MiB
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 88631
Speed: 3245 MHz min/max: 1400/3700 MHz boost: enabled Core speeds (MHz): 1: 3245 2: 2926
3: 3075 4: 2905 5: 3944 6: 3991 7: 2864 8: 3179 9: 3440 10: 2907 11: 3587 12: 3079
mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
Graphics: Device-1: AMD Renoir vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 0c:00.0
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver: loaded: amdgpu,ati
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4") s-diag: 485mm (19.1")
Monitor-1: HDMI-A-0 res: 1600x900 dpi: 99 size: 410x280mm (16.1x11.0") diag: 496mm (19.5")
OpenGL: renderer: AMD RENOIR (DRM 3.42.0 5.15.5-zen1-1-zen LLVM 13.0.0) v: 4.6 Mesa 21.2.5
direct render: Yes
Audio: Device-1: AMD vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 0c:00.1
Device-2: AMD Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
bus-ID: 0c:00.6 chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.15.5-zen1-1-zen running: yes
Network: Device-1: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter vendor: Hewlett-Packard
driver: rtw_8821ce v: N/A modules: rtw88_8821ce port: e000 bus-ID: 09:00.0 chip-ID: 10ec:c821
IF: wlp9s0 state: down mac: <filter>
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard
driver: r8169 v: kernel port: d000 bus-ID: 0a:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-12:3
chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Drives: Local Storage: total: 480.71 GiB used: 362.52 GiB (75.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: SK Hynix model: BC511 HFM512GDJTNI-82A0A
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD
serial: <filter> rev: HPS0 temp: 33.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 type: USB model: Rocketfish Rocketfish size: 3.77 GiB block-size:
physical: 512 B logical: 512 B type: N/A serial: <filter> rev: 4096 scheme: MBR
Partition: ID-1: / raw-size: 464.43 GiB size: 464.43 GiB (100.00%) used: 362.52 GiB (78.1%) fs: btrfs
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 562 KiB (0.2%) fs: vfat
ID-3: /home raw-size: 464.43 GiB size: 464.43 GiB (100.00%) used: 362.52 GiB (78.1%) fs: btrfs
ID-4: /var/log raw-size: 464.43 GiB size: 464.43 GiB (100.00%) used: 362.52 GiB (78.1%)
ID-5: /var/tmp raw-size: 464.43 GiB size: 464.43 GiB (100.00%) used: 362.52 GiB (78.1%)
ID-1: swap-1 type: partition size: 12.25 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 11.13 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 30.0 C mobo: N/A gpu: amdgpu temp: 25.0 C
Info: Processes: 357 Uptime: 6m wakeups: 0 Memory: 11.13 GiB used: 2.47 GiB (22.2%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1485 lib: 439
Shell: fish v: 3.3.1 default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
For further info, I ran systemctl status bluetooth and got this readout---note that I tried to connect the headset at 7:46
ā bluetooth.service - Bluetooth service
Loaded: loaded (/usr/lib/systemd/system/bluetooth.service; enabled; vendor preset: disabled)
Active: active (running) since Tue 2021-11-30 07:00:25 CST; 43min ago
Docs: man:bluetoothd(8)
Main PID: 750 (bluetoothd)
Status: "Running"
Tasks: 1 (limit: 13544)
Memory: 3.4M
CPU: 27ms
CGroup: /system.slice/bluetooth.service
āā750 /usr/lib/bluetooth/bluetoothd
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/sbc
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSink/sbc_xq
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/sbc_xq
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/faststream_duplex
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_1
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_0
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_1
Nov 30 07:01:58 pavilion bluetoothd[750]: Endpoint registered: sender=:1.48 path=/MediaEndpoint/A2DPSource/aptx_ll_duplex_0
Nov 30 07:02:05 pavilion bluetoothd[750]: src/profile.c:record_cb() Unable to get Hands-Free Voice gateway SDP record: Host is down
Nov 30 07:46:51 pavilion bluetoothd[750]: src/profile.c:ext_connect() Hands-Free Voice gateway failed connect to E8:AB:FA:3F:FA:40: Connection timed out (110)
Nov 30 07:46:56 pavilion bluetoothd[750]: profiles/audio/avdtp.c:avdtp_connect_cb() connect to E8:AB:FA:3F:FA:40: Host is down (112)
Here's the output of dmesg | grep Bluetooth
[ 5.974342] usb 1-12: Product: Bluetooth Radio
[ 6.724861] Bluetooth: Core ver 2.22
[ 6.724878] Bluetooth: HCI device and connection manager initialized
[ 6.724881] Bluetooth: HCI socket layer initialized
[ 6.724882] Bluetooth: L2CAP socket layer initialized
[ 6.724885] Bluetooth: SCO socket layer initialized
[ 6.780197] Bluetooth: hci0: RTL: examining hci_ver=08 hci_rev=000c lmp_ver=08 lmp_subver=8821
[ 6.783203] Bluetooth: hci0: RTL: rom_version status=0 version=1
[ 6.783208] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_fw.bin
[ 6.783744] Bluetooth: hci0: RTL: loading rtl_bt/rtl8821c_config.bin
[ 6.783777] Bluetooth: hci0: RTL: cfg_sz 10, total sz 31990
[ 6.937226] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 6.937235] Bluetooth: BNEP filters: protocol multicast
[ 6.937244] Bluetooth: BNEP socket layer initialized
[ 7.870436] Bluetooth: hci0: RTL: fw version 0x829a7644
[ 100.218828] Bluetooth: RFCOMM TTY layer initialized
[ 100.218850] Bluetooth: RFCOMM socket layer initialized
[ 100.218855] Bluetooth: RFCOMM ver 1.11
Things I've Tried
Connecting other BT devices---no luck.
Resetting headset's connections as well as deleting the headset from my remembered connections
Connecting with bluethoothctl. See below: on first attempt, it claimed to have connected for about 10 seconds, then disconnected again.
Agent registered
[bluetooth]# info E8:AB:FA:3F:FA:40
Device E8:AB:FA:3F:FA:40 (public)
Name: TaoTronics SoundSurge 90
Alias: TaoTronics SoundSurge 90
Class: 0x00240404
Icon: audio-headset
Paired: yes
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
UUID: Audio Sink (0000110b-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
UUID: A/V Remote Control (0000110e-0000-1000-8000-00805f9b34fb)
UUID: Handsfree (0000111e-0000-1000-8000-00805f9b34fb)
[bluetooth]# connect E8:AB:FA:3F:FA:40
Attempting to connect to E8:AB:FA:3F:FA:40
[CHG] Device E8:AB:FA:3F:FA:40 Connected: yes
Failed to connect: org.bluez.Error.Failed br-connection-canceled
[CHG] Device E8:AB:FA:3F:FA:40 Connected: no
Failed to connect: org.bluez.Error.Failed br-connection-page-timeout
rfkill list to check for hard block
0: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
1: phy0: Wireless LAN
Soft blocked: yes
Hard blocked: no
Booting with linux, linux-lts, linux-mainline, and linux-hardened kernels. No change.
Turning off the Wi-Fi router that's located close to the tower to make sure its signal wasn't causing interference.
Switching to pulseaudio instead of pipewire, and making sure pulseaudio-bluetooth was installed
Downgrading bluez to 5.61-1
I know a fresh install of Garuda may solve my problem, but I've wanted to avoid all that work. Of course, at this point, I've probably done at least that much work trying to fix it.
Nevertheless, any guidance you can offer I will appreciate.
