Hello I've got a DualSense controller (the PS5 controller) that I can do the initial pairing with my bluetooth just fine and it runs like you would want/expect it to. However whenever I either turn off the controller or turn off the pc and turn it back on I have to reconnect it and when I do it tries to but fails giving me the following error in the bluetooth system settings menu:
"br-connection-create-socket"
Does anyone know how to fix this its anoyying having to unpair and repair each time. Thank you for taking the time to read this and reach out!
Oh and here is my system specs:
Kernel: 6.0.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=8afab8b4-bd89-4267-9d65-f79cbafff52f rw [email protected]
resume=UUID=667e1ff1-c5e6-4567-af3c-5544d0ad441d loglevel=3
Desktop: KDE Plasma v: 5.26.3 tk: Qt v: 5.15.7 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG MAXIMUS X HERO (WI-FI AC) v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0802
date: 11/01/2017
Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88796
PBRSB-eIBRS: Not affected
vendor: Gigabyte driver: amdgpu v: kernel arch: RDNA-1 code: Navi
process: TSMC n7 (7nm) built: 2019-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: DP-1,DP-2 empty: DP-3,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:731f class-ID: 0300
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: left model: Asus VG248
serial: <filter> built: 2018 res: 1920x1080 hz: 60 dpi: 92 gamma: 1.2
Monitor-2: DP-2 mapped: DisplayPort-1 pos: primary,right model: HP X24ih
serial: <filter> built: 2020 res: 1920x1080 dpi: 93 gamma: 1.2
size: 527x297mm (20.75x11.69") diag: 605mm (23.8") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: AMD Radeon RX 5700 (navi10 LLVM
14.0.6 DRM 3.48 6.0.8-zen1-1-zen) direct render: Yes
driver: snd_hda_intel bus-ID: 1-5:3 v: kernel bus-ID: 00:1f.3
chip-ID: 9886:0038 class-ID: 0300 chip-ID: 8086:a2f0 class-ID: 0403
Device-2: AMD Navi 10 HDMI Audio driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab38
Device-3: Creative Labs driver: snd_hda_intel v: kernel bus-ID: 06:00.0
chip-ID: 1102:0010 class-ID: 0403
Device-4: Astro Gaming MixAmp Pro type: USB
Sound API: ALSA v: k6.0.8-zen1-1-zen running: yes
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: ASUSTeK
driver: rtw_8822be v: N/A modules: rtw88_8822be pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: d000 bus-ID: 08:00.0 chip-ID: 10ec:b822 class-ID: 0280
Device-1: ASUSTek Bluetooth Radio type: USB driver: btusb v: 0.8
bus-ID: 1-13:5 chip-ID: 0b05:185c class-ID: e001 serial: <filter>
Local Storage: total: 2.73 TiB used: 654.2 GiB (23.4%)
rev: 2B2QEXM7 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
ID-1: / raw-size: 896.81 GiB size: 896.81 GiB (100.00%)
used: 342.82 GiB (38.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 896.81 GiB size: 896.81 GiB (100.00%)
ID-4: /var/log raw-size: 896.81 GiB size: 896.81 GiB (100.00%)
ID-5: /var/tmp raw-size: 896.81 GiB size: 896.81 GiB (100.00%)
ID-1: swap-1 type: partition size: 34.41 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 31.28 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 31.0 C mobo: N/A gpu: amdgpu temp: 51.0 C
mem: 58.0 C
Processes: 341 Uptime: 12m wakeups: 0 Memory: 31.28 GiB
used: 3.77 GiB (12.1%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1593
libs: 524 tools: pamac,paru Shell: fish v: 3.5.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-07-10
Last full system update: 2022-11-16
Snapshots: Snapper (maybe)
