Hi, im new to Garuda and Linux in general. Having difficulty getting my bluetooth headphones to connect.
Kernel: 6.6.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=28da6122-54e7-4fb7-b574-11e8abdea7c1 rw rootflags=subvol=@
Type: Desktop Mobo: ASRock model: X670E Pro RS serial: <superuser required>
UEFI: American Megatrends LLC. v: 1.24 date: 05/23/2023
Info: model: AMD Ryzen 9 7900 bits: 64 type: MT MCP arch: Zen 4 gen: 5
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 537 high: 3706 min/max: 400/5482 scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 3706 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 400 22: 400
23: 400 24: 400 bogomips: 177278
Device-1: NVIDIA AD104 [GeForce RTX 4070] vendor: Gigabyte driver: N/A
alternate: nouveau non-free: 545.xx+ status: current (as of 2023-10)
arch: Lovelace code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:2786
Device-2: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-2:2
chip-ID: 046d:085c class-ID: 0102 serial: <filter>
compositor: kwin_x11 driver: X: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa gpu: N/A display-ID: :0 screens: 1
Monitor-1: Unknown-1 mapped: None-1 res: 1920x1080 hz: 60 size: N/A
modes: 1920x1080
API: EGL v: 1.5 platforms: device: 0 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: swrast x11: drv: swrast inactive: wayland
API: OpenGL v: 4.5 vendor: mesa v: 23.2.1-arch1.2 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 61.04 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
Device-1: NVIDIA vendor: Gigabyte driver: snd_hda_intel v: kernel pcie:
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:22bc
Device-2: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 18:00.6
Device-3: Logitech C922 Pro Stream Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.2-zen1-1-zen status: kernel-api tools: N/A
bus-ID: 0d:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp13s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASRock driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 0e:00.0
IF: enp14s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-12:3 chip-ID: 0e8d:0616
lmp-v: 11 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.82 TiB used: 8.76 GiB (0.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 40.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 8.76 GiB (0.5%)
used: 8.76 GiB (0.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 62.51 GiB used: 1024 KiB (0.0%)
priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 24
System Temperatures: cpu: 47.8 C mobo: 38.0 C
Processes: 445 Uptime: 3m wakeups: 0 Memory: total: 64 GiB
available: 62.51 GiB used: 3.68 GiB (5.9%) Init: systemd v: 254
pm: pacman pkgs: 1222 libs: 361 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date: 2023-11-29
Last full system update: 2023-11-29
Failed units: systemd-vconsole-setup.service```
Thanks
