Not quite a tech support issue with Garuda per se, and I'm not really sure where exactly to put this so I put it in KDE because that's what I use and it seems to be a relatively active section. Maybe unsupported software? IDK.
Anyway, I've been loving Garuda and one of my favorite features about it is the option to select Bluetooth codecs with headphones (so I can choos AptX, AptX HD, etc right there in the taskbar). I have a different system running Manjaro, and It'd be incredible to have that feature in Manjaro as well. Hours of Googleing serve up a could of archived projects that won't build, and I would think that it would be impossible to do, if I weren't already doing it on Garuda. I know that this isn't really an issue with Garuda itself, but Manjaro forums are not a help.
Long story short, is there any way I could select Bluetooth codecs on Manjaro in the way that Garuda so helpfully lets you?
Thank you so so much!
