Hey there,
I'm currently trying to revive on of the things I bought a while back. It's a bluetooth audio transmitter which I'm currently trying to use to stream audio from another device to my bluetooth receiver and into my headphones.
Sadly this audio output is horribly distorted and cuts out all the time as if it had a very bad connection, but that transmitter currently resides just next to my bluetooth dongle.
I tried the arch wiki troubleshooting suggestion, but to no avail (PipeWire - ArchWiki). What else could I do?
Here a sample of what I can hear (this should be a continuous testing tone): https://chonkyrabbit.eu/files/_share/audio-stutter.mp3
Does anyone have an idea what I could try here?
Thanks!
Kernel: 6.1.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: root=PARTUUID=fec66b8f-995b-8043-94b0-fcc9535362ba rw
add_efi_memmap [email protected] [email protected]\boot\amd-ucode.img
systemd.unified_cgroup_hierarchy=1 loglevel=3 sysrq_always_enabled=1
iommu=soft initrd=\@\boot\initramfs-linux-zen.img
Desktop: Hyprland info: waybar vt: 1 dm: greetd Distro: Garuda Linux
Type: Desktop System: Gigabyte product: AX370-Gaming 3 v: N/A
Mobo: Gigabyte model: AX370-Gaming 3-CF v: x.x
serial: <superuser required> UEFI: American Megatrends v: F50a
date: 11/27/2019
Info: model: AMD Ryzen 5 2600X bits: 64 type: MT MCP arch: Zen+ gen: 2
model-id: 8 stepping: 2 microcode: 0x800820D
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 3514 high: 4117 min/max: 2200/3600 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4092 2: 2060
3: 4117 4: 4100 5: 4078 6: 2744 7: 4112 8: 2058 9: 4114 10: 3930
11: 4032 12: 2732 bogomips: 86226
Device-1: AMD Baffin [Radeon RX 550 640SP / 560/560X] vendor: ASUSTeK
active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 08:00.0 chip-ID: 1002:67ff
class-ID: 0300 temp: 37.0 C
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-3.4:7 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: wayland server: Xwayland v: 22.1.7 compositor: Hyprland driver:
X: loaded: amdgpu unloaded: modesetting,radeon alternate: fbdev,vesa
dri: radeonsi gpu: amdgpu display-ID: 1
Monitor-1: DVI-D-1 model: Apple Cinema HD Display serial: <filter>
built: 2003 res: 1920x1200 dpi: 99 gamma: 1.2
size: 495x310mm (19.49x12.2") diag: 584mm (23") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
Monitor-2: HDMI-A-1 model: Samsung SyncMaster serial: <filter>
built: 2007 res: 1680x1050 dpi: 90 gamma: 1.2
size: 474x296mm (18.66x11.65") diag: 559mm (22") ratio: 16:10 modes:
max: 1680x1050 min: 720x400
API: EGL/GBM Message: No known Wayland EGL/GBM data sources.
Device-1: AMD Baffin HDMI/DP Audio [Radeon RX 550 640SP / 560/560X]
vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 1-1:2 pcie:
chip-ID: 0d8c:9700 gen: 3 class-ID: 0300 speed: 8 GT/s serial: <filter>
lanes: 8 bus-ID: 08:00.1 chip-ID: 1002:aae0 class-ID: 0403
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.3
Device-3: C-Media USB Microphone type: USB
Device-4: Yamaha MX Series type: USB driver: snd-usb-audio bus-ID: 1-9:3
chip-ID: 0499:1711 class-ID: 0103
Device-5: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.1.8-zen1-1-zen running: yes
lanes: 1 port: f000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-1: Broadcom BCM20702A0 Bluetooth 4.0 type: USB driver: btusb v: 0.8
bus-ID: 3-4.1:12 chip-ID: 0a5c:21e8 class-ID: fe01 serial: <filter>
Report: bt-adapter ID: hci4 rfk-id: 4 state: up address: <filter>
Local Storage: total: 2.96 TiB used: 611.32 GiB (20.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 1B6Q scheme: GPT
model: WD20EFRX-68EUZN0 size: 1.82 TiB block-size: physical: 4096 B
rev: 0A82 scheme: GPT
ID-1: / raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
used: 37.84 GiB (19.4%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 19.1 MiB (6.4%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 736.18 GiB size: 736.18 GiB (100.00%)
used: 169.25 GiB (23.0%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
ID-4: /var/log raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-5: /var/tmp raw-size: 195.03 GiB size: 195.03 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.29 GiB used: 19.5 MiB (0.1%)
System Temperatures: cpu: 48.1 C mobo: N/A gpu: amdgpu temp: 38.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1493
Processes: 372 Uptime: 1h 50m wakeups: 0 Memory: 31.29 GiB
used: 4.21 GiB (13.5%) Init: systemd v: 252 default: graphical
pkgs: 1515 libs: 471 tools: yay Shell: Zsh v: 5.9 running-in: kitty
inxi: 3.3.24
Garuda (2.6.14-1):
System install date: 2023-01-08
Last full system update: 2023-01-29
