Hi, my Bluetooth headphones keep cutting out constantly, making them basically unusable. This has been happening from the start, not caused by any changes I made.
What I’ve tried:
- Started with default PipeWire setup - Bluetooth audio cuts out frequently
- Tried switching to PulseAudio thinking it might help - same issue, audio still cuts out
- Cleaned up the mess and went back to PipeWire properly
- PipeWire is now running correctly
- Bluetooth still cuts out constantly regardless of which audio server I use
Current issues:
- Audio plays but cuts out/stutters every few seconds
- Makes the headphones completely unusable
- Problem occurs with both PipeWire AND PulseAudio
- Regular wired audio works perfectly fine
Current setup:
- PipeWire 1:1.4.9-2 with pipewire-pulse, pipewire-alsa, wireplumber all running
- Bluetooth service active
- ASUS N56VM laptop with GT 630M (Fermi)
garuda-inxi output here :
Kernel: 6.18.1-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=abf2b038-780c-4028-97a0-aade9620e93a rw rootflags=subvol=@
quiet loglevel=3
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
Type: Laptop System: ASUSTeK product: N56VM v: 1.0
Mobo: ASUSTeK model: N56VM v: 1.0 serial: <superuser required>
uuid: <superuser required> Firmware: UEFI vendor: American Megatrends
v: N56VM.206 date: 04/13/2012
Info: model: Intel Core i7-3610QM bits: 64 type: MT MCP arch: Ivy Bridge
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3169 min/max: 1200/3300 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3169 2: 3169 3: 3169 4: 3169 5: 3169 6: 3169
7: 3169 8: 3169 bogomips: 36716
Flags-basic: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Device-1: Intel 3rd Gen Core processor Graphics vendor: ASUSTeK driver: i915
active: LVDS-1 empty: VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166
Device-2: NVIDIA GF108M [GeForce GT 620M/630M/635M/640M LE]
vendor: ASUSTeK driver: nvidia v: 390.157 alternate: nouveau,nvidia_drm
non-free: series: 390.xx+ status: legacy (EOL~2022-11-22) last:
release: 390.157 kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx
process: 40/28nm built: 2010-2016 pcie: gen: 2 speed: 5 GT/s lanes: 16
ports: active: none empty: HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:0de9
Device-3: Suyin UVC HD Webcam driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1.3:4 chip-ID: 064e:d213
Display: x11 server: X.Org v: 21.1.21 with: Xwayland v: 24.1.9
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: crocus
Screen-1: 0 s-res: 1366x768 s-dpi: 75 s-size: 463x260mm (18.23x10.24")
s-diag: 531mm (20.91")
Monitor-1: LVDS-1 mapped: LVDS-1-1 model: AU Optronics 0x24ec built: 2011
res: mode: 1366x768 hz: 60 scale: 100% (1) dpi: 101 gamma: 1.2
modes: 1366x768
API: EGL v: 1.5 hw: drv: intel crocus platforms: gbm: drv: crocus
API: OpenGL v: 4.2 compat-v: 4.6.0 vendor: nvidia mesa v: 390.157
glx-v: 1.4 direct-render: yes renderer: GeForce GT 630M/PCIe/SSE2
memory: 1.95 GiB
API: Vulkan v: 1.4.335 layers: 10 device: 0 type: integrated-gpu
name: Intel HD Graphics 4000 (IVB GT2) driver: mesa intel v: 25.3.1-arch1.2
device-ID: 8086:0166 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.1-arch1.2 (LLVM
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
vendor: ASUSTeK N56VZ driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Device-2: NVIDIA GF108 High Definition Audio vendor: ASUSTeK
bus-ID: 01:00.1 chip-ID: 10de:0bea class-ID: 0403
API: ALSA v: k6.18.1-zen1-2-zen status: kernel-api with: aoss
Device-1: Intel Centrino Wireless-N 2230 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:0887
Device-2: Qualcomm Atheros AR8161 Gigabit Ethernet vendor: ASUSTeK N56VZ
driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 04:00.0 chip-ID: 1969:1091 class-ID: 0200
Device-1: Intel Centrino Bluetooth Wireless Transceiver driver: btusb v: 0.8
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-1.1:3
chip-ID: 8087:07da class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: yes class-ID: 6c010c
Local Storage: total: 698.64 GiB used: 68.73 GiB (9.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9750420AS
size: 698.64 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SDM1 scheme: GPT
ID-1: / raw-size: 207.27 GiB size: 207.27 GiB (100.00%)
used: 68.7 GiB (33.1%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
used: 32.3 MiB (33.6%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 207.27 GiB size: 207.27 GiB (100.00%)
ID-4: /var/log raw-size: 207.27 GiB size: 207.27 GiB (100.00%)
ID-5: /var/tmp raw-size: 207.27 GiB size: 207.27 GiB (100.00%)
ID-1: swap-1 type: zram size: 11.56 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 77.0 C mobo: N/A
Fan Speeds (rpm): cpu: 3300
Memory: total: 12 GiB available: 11.56 GiB used: 3.5 GiB (30.2%)
Processes: 289 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 4.61 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1434 libs: 386 tools: octopi,paru Compilers:
clang: 21.1.6 gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.2.1
running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date: 2025-12-10
Garuda release: 251103
Last full system update: 2025-12-17
Relevant software: snapper NetworkManager dracut nvidia-390xx-dkms garuda-hardware-profile-standard
25/26 checks run in 2.00 seconds ⌛
Powered by garuda-health 🦅
(This has been written using AI, because im very bad at English, sorry.)
(And it can’t be a Hardware issue, because on another Distro (Pop_OS!) it works perfectly fine).
This is driving me crazy does anyone have any ideas what could be causing Bluetooth audio to cut out like this?
