I have downloaded garuda as my primary os almost for 1 month but since install i cant use wifi and bluetooth as garuda is not able to detect the hardware i use wifi dongle right now to post this but being old it can not provide me good speed. i have already tried things i can access in the web but nothing works. i have already tried rfkill and i can see the hardware there but not in the network manager and cant find any driver to put in blacklist.
We will need to see the garuda-inxi output and we will need to know the model number of the wifi card as well as the lspci output.
sorry here you go
Kernel: 6.12.50-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=ae48ca0f-8e6d-4e13-bea0-d1a9ec9ab3e1 rw rootflags=subvol=@
quiet loglevel=3
Type: Laptop System: ASUSTeK product: Vivobook_ASUSLaptop M1502YA_M1502YA
Mobo: ASUSTeK model: M1502YA v: 1.0 serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: M1502YA.311
date: 01/22/2025
ID-1: BAT0 charge: 29.2 Wh (67.7%) condition: 43.1/42.1 Wh (102.5%)
power: 12.6 W volts: 11.76 min: 11.85 model: ASUSTeK ASUS Battery
type: Li-ion serial: N/A charging: status: discharging control: start: N/A
end: 100% cycles: 9
Info: model: AMD Ryzen 7 5825U with Radeon Graphics bits: 64 type: MT MCP
microcode: 0xA500012
Speed (MHz): avg: 400 min/max: 400/2000 boost: enabled scaling:
4: 400 5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400
14: 400 15: 400 16: 400 bogomips: 63896
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Barcelo vendor: ASUSTeK
built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: eDP-1
empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15e7 class-ID: 0300
temp: 45.0 C
Device-2: IMC Networks USB2.0 HD UVC WebCam driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-3:3 chip-ID: 13d3:54a1
Monitor-1: eDP-1 model: ChiMei InnoLux 0x15e7 built: 2023 res:
size: 344x193mm (13.54x7.6") diag: 394mm (15.5") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.4-arch1.1
renoir ACO DRM 3.61 6.12.50-1-lts) device-ID: 1002:15e7 memory: 500 MiB
unified: no display-ID: :1.0
API: Vulkan v: 1.4.321 layers: 5 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 25.2.4-arch1.1
device-ID: 1002:15e7 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 20.1.8 256 bits) driver: mesa llvmpipe v: 25.2.4-arch1.1 (LLVM
Device-1: Advanced Micro Devices [AMD/ATI] Renoir/Cezanne HDMI/DP Audio
bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: ASUSTeK
lanes: 16 bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.12.50-1-lts status: kernel-api tools: N/A
Server-1: PipeWire v: 1.4.8 status: active with: 1: wireplumber
status: active 2: pipewire-alsa type: plugin 3: pw-jack type: plugin
tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0-43-g3e2bb status: off with: pulseaudio-alsa
type: plugin tools: pacat,pactl
Device-1: MEDIATEK vendor: AzureWave driver: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 14c3:7902
Device-2: Realtek RTL8188FTV 802.11b/g/n 1T1R 2.4G WLAN Adapter
driver: rtl8xxxu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
bus-ID: 1-4:2 chip-ID: 0bda:f179 class-ID: 0000 serial: <filter>
IF: wlp3s0f3u4 state: up mac: <filter>
rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 13d3:3579
Report: btmgmt ID: hci0 rfk-id: 117 state: up address: N/A
Local Storage: total: 476.94 GiB used: 27.14 GiB (5.7%)
model: MTFDKBA512QGN-1BN1AABGA size: 476.94 GiB block-size: physical: 512 B
fw-rev: V8MA000 temp: 35.9 C scheme: GPT
ID-1: / raw-size: 349.82 GiB size: 349.82 GiB (100.00%)
used: 27.13 GiB (7.8%) fs: btrfs dev: /dev/nvme0n1p9 maj-min: 259:9
used: 1.4 MiB (0.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 349.82 GiB size: 349.82 GiB (100.00%)
ID-4: /var/log raw-size: 349.82 GiB size: 349.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 349.82 GiB size: 349.82 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.03 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 45.8 C mobo: N/A gpu: amdgpu temp: 45.0 C
Fan Speeds (rpm): cpu: 1800
Memory: total: 16 GiB note: est. available: 15.03 GiB used: 4.21 GiB (28.0%)
Processes: 405 Power: uptime: 1h 22m states: freeze,mem,disk
suspend: s2idle wakeups: 129 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 5.98 GiB
services: power-profiles-daemon,upowerd Init: systemd v: 258
Packages: 1424 pm: pacman pkgs: 1419 libs: 420 tools: octopi,paru
pm: flatpak pkgs: 5 Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Bash
v: 5.3.3 default: fish v: 4.1.1 running-in: konsole inxi: 3.3.39
Garuda (2.11.1-1):
System install date: 2025-09-24
Garuda release: 250916
Last full system update: 2025-10-03 ↻
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard
23/24 checks run in 2.76 seconds ⌛
Powered by garuda-health 🦅
--- LOW ---
- System is using PipeWire, but pipewire-support is not installed (fix available)
--- INFO ---
lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne IOMMU
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:02.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:02.4 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne PCIe GPP Bridge
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Renoir PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Renoir Internal PCIe GPP Bridge to Bus
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 51)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Cezanne Data Fabric; Function 7
01:00.0 Network controller: MEDIATEK Corp. Device 7902
02:00.0 Non-Volatile memory controller: Micron Technology Inc 2500 NVMe SSD (DRAM-less) (rev 01)
03:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Barcelo (rev c1)
03:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Renoir/Cezanne HDMI/DP Audio Controller
03:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Raven/Raven2/FireFlight/Renoir/Cezanne Platf
orm Security Processor
03:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
03:00.4 USB controller: Advanced Micro Devices, Inc. [AMD] Renoir/Cezanne USB 3.1
03:00.5 Multimedia controller: Advanced Micro Devices, Inc. [AMD] Audio Coprocessor (rev 01)
03:00.6 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h/19h/1ah HD Audio Controller
This could very possibly be a result of dual booting with Windows. Windows has the nasty habit of clinging onto networking hardware and not releasing it for Linux to use.
Search the networking sub-forum and you should find various recommendations to help free up the network device and prevent Windows from doing this again in the future.
i am single booting it and have already deleted windows before install of garuda. English is not my primary language so pls adjust.
