Kernel: 6.4.4-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=f199b624-ffa0-40b4-945c-c4e71ca3d9ec rw rootflags=subvol=@
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: XPS 9320 v: N/A
Mobo: Dell model: 0V0059 v: A00 serial: <superuser required> UEFI: Dell
v: 1.11.0 date: 12/09/2022
ID-1: BAT0 charge: 54.9 Wh (100.0%) condition: 54.9/54.4 Wh (100.9%)
volts: 13.2 min: 11.6 model: SMP DELL J7H5M23 type: Li-poly serial: <filter>
status: full
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x42A
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2337 high: 2500 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: performance cores: 1: 2500 2: 2500 3: 2500
4: 2500 5: 412 6: 1993 7: 2500 8: 2500 9: 2500 10: 2500 11: 2500 12: 2500
13: 2500 14: 2500 15: 2500 16: 2500 bogomips: 79872
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Display: x11 server: X.Org v: 21.1.8 compositor: Picom v: git-b700a
driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: Sharp 0x1548 built: 2021 res: 1920x1200 hz: 60
dpi: 169 gamma: 1.2 size: 288x180mm (11.34x7.09") diag: 340mm (13.4")
ratio: 16:10 modes: 1920x1200
API: OpenGL v: 4.6 Mesa 23.1.4 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
Device-1: Intel Alder Lake Imaging Signal Processor vendor: Dell driver: N/A
bus-ID: 00:05.0 chip-ID: 8086:465d class-ID: 0480
Device-2: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.4.4-zen1-1-zen status: kernel-api
Server-1: PipeWire v: 0.3.75 status: active with: 1: pipewire-pulse
status: active 2: wireplumber status: active 3: pw-jack type: plugin
Device-1: Intel driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 476.94 GiB used: 25.21 GiB (5.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 512GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 36308229 temp: 54.9 C
ID-1: / raw-size: 457.45 GiB size: 457.45 GiB (100.00%)
used: 25.12 GiB (5.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 240 MiB size: 236 MiB (98.33%)
used: 98.8 MiB (41.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 457.45 GiB size: 457.45 GiB (100.00%)
ID-4: /var/log raw-size: 457.45 GiB size: 457.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 457.45 GiB size: 457.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.24 GiB used: 1.5 MiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: 42.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 6124
Processes: 356 Uptime: 13m wakeups: 29862 Memory: total: 16 GiB note: est.
available: 15.24 GiB used: 2.36 GiB (15.5%) Init: systemd v: 253
default: graphical tool: systemctl Compilers: gcc: 13.1.1 Packages: 1394
pm: pacman pkgs: 1385 libs: 350 tools: pamac,paru,yay pm: snap pkgs: 9
Shell: fish v: 3.6.1 running-in: alacritty inxi: 3.3.28
System install date: 2023-02-16
Last full system update: 2023-07-24 ↻
Failed units: v4l2-relayd.service
I have installed Bluemail through snap and what I get is the following. maybe missing some fonts but not sure which one. any idea?
