Bluemail stuck on opening
Hello, amazing garuda community,
I have a problem with the latest version of Bluemail (downloaded from AUR).
I have installed the application as new (never used it before on linux), and it gets stuck in the first opening window, I can't click any button or go ahead to configure my email account.
Has anyone else had the same problem? Any suggestions to solve it?
Thanks!
Hi there,
Bluemail is already available in Chaotic-AUR, so it would be best to install it from there.
Secondly, I just installed bluemail, and it works flawlessly here. Can you please share output of
as well as run bluemail from terminal ( using command bluemail ofc ) and posting its output here as text.
Hi Naman,
thanks for reply! I have try to install in my laptop (i have garuda in my main desktop and laptop too) from Chaotic-aur, but seems the problem is the same (i use gnome version of garuda).
> System:
  Kernel: 5.18.16-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
    root=UUID=5fd15504-2df0-4898-891a-b6e92ff17f93 rw [email protected]
    resume=UUID=82a0b03a-c2f4-44c6-bc05-02cc24306b1a loglevel=3
  Desktop: GNOME v: 42.3.1 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM
    v: 42.0 Distro: Garuda Linux base: Arch Linux
  Type: Laptop System: Dell product: Latitude E7440 v: 00
  Mobo: Dell model: N/A serial: <superuser required> BIOS: Dell v: A27
    date: 10/09/2018
  ID-1: BAT0 charge: 42.2 Wh (100.0%) condition: 42.2/47.7 Wh (88.5%)
    volts: 8.6 min: 7.4 model: SMP DELL 909H538 type: Li-ion serial: <filter>
    status: charging
  Info: model: Intel Core i5-4310U bits: 64 type: MT MCP arch: Haswell
    gen: core 4 built: 2013-15 process: Intel 22nm family: 6
    model-id: 0x45 (69) stepping: 1 microcode: 0x26
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1521 high: 2710 min/max: 800/3000 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1256 2: 1275 3: 846
    4: 2710 bogomips: 20752
    vulnerable
  Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
    v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
    active: eDP-1 empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
    chip-ID: 8086:0a16 class-ID: 0300
  Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
    bus-ID: 2-4:2 chip-ID: 0c45:64d2 class-ID: 0e02
    compositor: gnome-shell driver: X: loaded: modesetting
    alternate: fbdev,intel,vesa gpu: i915 display-ID: :1 screens: 1
    s-diag: 414mm (16.31")
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1492 built: 2012 res: 1366x768
    hz: 60 dpi: 112 gamma: 1.2 size: 309x174mm (12.17x6.85") diag: 355mm (14")
    ratio: 16:9 modes: 1366x768
  Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
  Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
  Sound Server-1: ALSA v: k5.18.16-zen1-1-zen running: yes
  Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
    port: f080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
  Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:08b1 class-ID: 0280
    bus-ID: 1-1.3:3 chip-ID: 8087:07dc class-ID: e001
  Report: bt-adapter ID: hci0 rfk-id: 4 state: down
    address: <filter>
    v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A
    class-ID: 0104
  Local Storage: total: 223.57 GiB used: 36.5 GiB (16.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G
    type: SSD serial: <filter> rev: 61K1 scheme: MBR
  ID-1: / raw-size: 214.77 GiB size: 214.77 GiB (100.00%) used: 36.5 GiB
    (17.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 214.77 GiB size: 214.77 GiB (100.00%) used: 36.5
    GiB (17.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-3: /var/log raw-size: 214.77 GiB size: 214.77 GiB (100.00%) used: 36.5
  ID-4: /var/tmp raw-size: 214.77 GiB size: 214.77 GiB (100.00%) used: 36.5
  ID-1: swap-1 type: zram size: 7.7 GiB used: 256 KiB (0.0%) priority: 100
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 65.0 C mobo: 47.0 C sodimm: SODIMM C
  Fan Speeds (RPM): cpu: 4100
  Processes: 282 Uptime: 8m wakeups: 1 Memory: 7.7 GiB used: 3.65 GiB (47.4%)
  Init: systemd v: 251 default: graphical tool: systemctl Compilers:
  gcc: 12.1.1 Packages: pacman: 1375 lib: 362 Shell: fish v: 3.5.1
  default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.20
Garuda (2.6.5-1):
  System install date:     2022-05-31
  Last full system update: 2022-08-05 ↻
> 5/8/2022, 09:05:11 :: Main thread initialized
5/8/2022, 09:05:11 :: Getting system flags
5/8/2022, 09:05:11 :: isLinux true
5/8/2022, 09:05:11 :: isMac false
5/8/2022, 09:05:11 :: isWindows false
5/8/2022, 09:05:11 :: isWindowsExeBuild false
5/8/2022, 09:05:11 :: isWindowsStoreBuild false
5/8/2022, 09:05:11 :: Retrieving process agrs
5/8/2022, 09:05:11 :: #0: || /opt/bluemail/bluemail || type: string -- /opt/bluemail/bluemail
5/8/2022, 09:05:11 :: #1: || ofc || type: string -- ofc
5/8/2022, 09:05:11 :: Retrieving LoginItemSettings
5/8/2022, 09:05:11 :: {"openAtLogin":false,"openAsHidden":false,"restoreState":false,"wasOpenedAtLogin":false,"wasOpenedAsHidden":false}
5/8/2022, 09:05:17 :: [splash] dataLoadedCallback 1
5/8/2022, 09:05:18 :: [splash] dataLoadedCallback 2
5/8/2022, 09:05:18 :: [splash] dataLoadedCallback 3
5/8/2022, 09:05:18 :: [splash] dataLoadedCallback 4
5/8/2022, 09:05:18 :: [splash] dataLoadedCallback 5
5/8/2022, 09:05:18 :: [splash] dataLoadedCallback 6
^C5/8/2022, 09:05:30 :: APP before-quit, uptimeSeconds: 19
5/8/2022, 09:05:31 :: APP will-quit, uptimeSeconds: 20
5/8/2022, 09:05:31 :: APP quit, uptimeSeconds: 20, exitCode: [object Object]
Here is the output, the problem is the same i had on my desktop.
Thanks!
Post always your terminal in- and output as text like
Kernel: 5.18.15-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters:
looks like
    parameters:
in forum.
I have edited your post.
Oh, sorry, I didn't know that. Thank you
I wonder if the problem is in gnome or if there is something in the network connection. I read about a similar problem on Windows, and they say there are some changes to be made to the connection permissions (something like that). Anyway, I tried leaving the application open but even after 1 hour it is still stuck on the welcome pages and the buttons are still not clickable.
It looks normal upto this point. Then maybe it has stuck, so you pressed ctrl+c
Might be, I am using Cinnamon, and it started flawlessly right out of the box. I installed from Chaotic AUR
Also, you can try contacting their support regarding this issue. Maybe, they already know it....
I think it's a gnome problem because I tried to install it on a virtual machine with fedora (gnome version) and had the same problem.
I sent an e-mail to the support team, I hope they get it.
I made one last attempt with the snap version of Bluemail, and I have the exact same problems.
I think there is a problem in every version with gnome.
